Home » Eclipse Projects » Mylyn » dev build and XPlanner connector preview
dev build and XPlanner connector preview [message #12665] Fri, 13 July 2007 21:53 Go to next message
Originally posted by: beatmik.acm.org
Today's dev build is the first preview release of the XPlanner
connector, available from the dev/extras update site:
http://eclipse.org/mylyn/downloads/builds.php
Congratulations to Helen Bershadskaya and CodeGear for getting this
contribution ready for feedback! Please file new bugs against the
XPlanner component in Bugzilla or provide general comments on:
130240: [connector] XPlanner
https://bugs.eclipse.org/bugs/show_bug.cgi?id=130240
Mik
Mik Kersten
Project Lead, http://eclipse.org/mylyn
Re: dev build and XPlanner connector preview [message #12707 is a reply to message #12665] Sat, 14 July 2007 04:31 Go to previous messageGo to next message
Are there any special requirement on the server side ?
I'm trying to connect to an existing XPlanner but it fails with invalid
username or password. I'm not behind a proxy and the username/password
are working from a web browser.
I'm a little confused about the difference between username/password and
http authentication, even with these two fields with the same values the
connection fails. The server uses http authentication (I don't see the
XPlanner login form).
Marco.
Re: dev build and XPlanner connector preview [message #14044 is a reply to message #12707] Mon, 16 July 2007 15:00 Go to previous messageGo to next message
No, as long as you are using XPlanner version .7 (we have been using .7b4)
I believe http authentication provides extra security for the
connection. See
http://en.wikipedia.org/wiki/HTTP_cookie#HTTP_authentication for a brief
description.
If this type of connection isn't working with the XPlanner connector,
you probably want to enter a bug for it. It is entirely possible this
is the case, since we did not test this path (was not an issue here).
Thanks a lot
-Helen
Re: dev build and XPlanner connector preview [message #14308 is a reply to message #14044] Wed, 18 July 2007 03:31 Go to previous messageGo to next message
Opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=196909
Marco.
Re: dev build and XPlanner connector preview [message #15825 is a reply to message #14308] Wed, 18 July 2007 13:57 Go to previous message
Thank you very much, Marco.
> Regards,
> Marco.
Re: dev build and XPlanner connector preview [message #572047 is a reply to message #12665] Sat, 14 July 2007 04:31 Go to previous message
Marco.
Re: dev build and XPlanner connector preview [message #572285 is a reply to message #12707] Mon, 16 July 2007 15:00 Go to previous message
connection. See
description.
Thanks a lot
-Helen
Re: dev build and XPlanner connector preview [message #572954 is a reply to message #14044] Wed, 18 July 2007 03:31 Go to previous message
Marco.
Re: dev build and XPlanner connector preview [message #573227 is a reply to message #14308] Wed, 18 July 2007 13:57 Go to previous message
> Regards,
> Marco.
Previous Topic:How does the Alt+click work?
Next Topic:When should a task appear in the Synchonize view?
Current Time: Sat Jul 19 01:14:51 EDT 2025
Powered by FUDForum. Page generated in 0.13349 seconds
