Home » Eclipse Projects » Platform - User Assistance (UA) » Help->Search preferences
Help->Search preferences [message #469540] Thu, 30 August 2007 16:12 Go to next message
I'm wondering if there is any way to control the default settings for the
Help->Search tab without changing any Java code. I would like to control
the
default values for the "Show result categories" and "Show result
descriptions"
buttons, so that these are set a particular way when the end-user first
uses the help system.
I noticed that when I change the values of these buttons in the UI, a file
containing something like the following
<xml version="1.0" encoding="UTF-8">
<section name="Workbench">
<item key="show-categories" value="false"/>
<item key="no-description" value="false"/>
</section>
is written as
Workspace/.metadata/.plugins/org.eclipse.help.ui/dialog_sett ings.xml
My first instinct was to add the following to our plugin_customization.ini
file:
org.eclipse.help.ui/Workbench/show-categories=false
org.eclipse.help.ui/Workbench/no-description=false
but to no avail. (I also tried a couple of variations on this string,
trying to find the right identifier by hit-or-miss. I can't seem to find
any documentation describing how to determine the identifier for a
particular property.)
So: Is this possible, or would specifying the default values of those
buttons require changes to Java code? If it is possible, I'd love to learn
how to find the correct identifier strings.
Thanks for any help,
Doug Dirks
Re: Help->Search preferences [message #469541 is a reply to message #469540] Tue, 04 September 2007 16:13 Go to previous message
Unfortunately there is not an easy way to change the defaults. The
values are actually saved in cookies, this is so the infocenter and
Eclipse help system will work the same way. The default values are hard
coded in the source and we don't have a preference setting for these.
Re: Help->Search preferences [message #572815 is a reply to message #469540] Tue, 04 September 2007 16:13 Go to previous message
Previous Topic:Kudos
Next Topic:launch help url in internal browser
Current Time: Wed Jun 04 15:56:57 EDT 2025
Powered by FUDForum. Page generated in 0.03093 seconds
