COSMOS on macos [message #572706] |
Fri, 08 May 2009 20:55 |
I've got the exception below running the COSMOS Web UI on macosx
10.5.6. This seems to be an AXIS bug, AXIS2-3453. In fact, upgrading AXIS
from 1.3 to 1.4.1 made the error go away.
Are there any plans to upgrade the COSMOS axis version?
org.eclipse.cosmos.dc.provisional.cmdbf.exception.CMDBfExcep tion:
java.util.regex.PatternSyntaxException: Dangling meta character '*' near
index 0
*.local
at
org.eclipse.cosmos.dc.provisional.cmdbf.query.client.QuerySe rviceClient.graphQuery(QueryServiceClient.java:119)
at Invoke.main(Invoke.java:42)
Caused by: java.util.regex.PatternSyntaxException: Dangling meta character
'*' near index 0
*.local
at java.util.regex.Pattern.error(Pattern.java:1650)
at java.util.regex.Pattern.sequence(Pattern.java:1787)
at java.util.regex.Pattern.expr(Pattern.java:1687)
at java.util.regex.Pattern.compile(Pattern.java:1397)
at java.util.regex.Pattern.<init>(Pattern.java:1124)
at java.util.regex.Pattern.compile(Pattern.java:817)
at java.util.regex.Pattern.matches(Pattern.java:919)
at java.lang.String.matches(String.java:1921)
at
org.apache.axis2.transport.http.ProxyConfiguration.validateN onProxyHosts(ProxyConfiguration.java:261)
Gian
FUDForum. Page generated in 0.03204 seconds
