Home » Eclipse Projects » Eclipse 4 » org.eclipse.e4.xwt.XWTException(All forms being executed throws XWTException)
org.eclipse.e4.xwt.XWTException [message #521811] Thu, 18 March 2010 15:04 Go to next message
I have this example from the test examples:
<Composite xmlns="http://www.eclipse.org/xwt/presentation"
xmlns:j="clr-namespace:test.ui"
xmlns:x="http://www.eclipse.org/xwt">
<Composite.layout>
<GridLayout numColumns="1" />
</Composite.layout>
<Section name="Section" x:style="Section.TITLE_BAR|Section.TWISTIE|Section.EXPANDED "
text="Section Two">
<Section.client>
<Label name="Section.Label" text="test" />
</Section.client>
</Section>
</Composite>
with the following code-behind:
package snippets.e4.forms;
import java.net.URL;
import org.eclipse.e4.xwt.IConstants;
import org.eclipse.e4.xwt.XWT;
public class Section
public static void main( String[] args )
URL url = Section.class.getResource( Section.class.getSimpleName() + IConstants.XWT_EXTENSION_SUFFIX );
try
XWT.open( url );
catch( Exception e )
e.printStackTrace();
Running the code-behind throws this exception:
org.eclipse.e4.xwt.XWTException: Type Section is not found.
at org.eclipse.e4.xwt.XWTLoader.getMetaclass(XWTLoader.java:899 )
at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(Resource Loader.java:419)
at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(Resource Loader.java:648)
at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(Resource Loader.java:449)
at org.eclipse.e4.xwt.javabean.ResourceLoader.createCLRElement( ResourceLoader.java:353)
at org.eclipse.e4.xwt.internal.core.Core.createCLRElement(Core. java:606)
at org.eclipse.e4.xwt.internal.core.Core.load(Core.java:646)
at org.eclipse.e4.xwt.internal.core.Core.load(Core.java:633)
at org.eclipse.e4.xwt.XWTLoader.loadWithOptions(XWTLoader.java: 835)
at org.eclipse.e4.xwt.XWTLoader$1.run(XWTLoader.java:768)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.e4.xwt.XWTLoader.open(XWTLoader.java:762)
at org.eclipse.e4.xwt.XWTLoader.open(XWTLoader.java:714)
at org.eclipse.e4.xwt.XWT.open(XWT.java:411)
at snippets.e4.forms.Section.main(Section.java:17)
A similar exception is thown for all my forms.
My dependencies in e4 are:
javax.inject;bundle-version="1.0.0",
org.eclipse.core.resources;bundle-version="3.6.0",
org.eclipse.core.runtime;bundle-version="3.6.0",
org.eclipse.swt;bundle-version="3.6.0",
org.eclipse.core.databinding;bundle-version="1.3.0",
org.eclipse.core.databinding.beans;bundle-version="1.2.0",
org.eclipse.jface;bundle-version="3.6.0",
org.eclipse.jface.databinding;bundle-version="1.4.0",
org.eclipse.e4.ui.services;bundle-version="0.9.1",
org.eclipse.e4.ui.workbench;bundle-version="0.9.1",
org.eclipse.e4.core.services;bundle-version="0.9.1",
org.eclipse.e4.ui.workbench.swt;bundle-version="0.9.1",
org.eclipse.core.databinding.property;bundle-version="1.2.100 ",
org.eclipse.e4.ui.css.core;bundle-version="0.9.0",
org.w3c.css.sac;bundle-version="1.3.0",
org.eclipse.e4.core.commands;bundle-version="0.9.0",
org.eclipse.e4.ui.bindings;bundle-version="0.9.0",
org.junit4;bundle-version="4.7.0",
org.eclipse.e4.xwt;bundle-version="0.9.1",
com.ibm.icu;bundle-version="4.2.1",
org.eclipse.e4.xwt.tests;bundle-version="0.9.1",
org.eclipse.e4.xwt.forms;bundle-version="0.9.1",
org.eclipse.ui.forms;bundle-version="3.5.0"
I don't know exactly why the xwt and swt form packages are not being recognized.
Similarl, the form fails to be displayed in the XWT editor.
Any help will be appreciated.
Re: org.eclipse.e4.xwt.XWTException [message #521844 is a reply to message #521811] Thu, 18 March 2010 17:43 Go to previous messageGo to next message
I'm not 100% sure, but as I understand source, only flags from SWT class can be used without qualifier, for all other style constants you have to use package/class qualifier. See example below.
Note, however, that Section is created without FormToolkit, so looks not very good. Would be good to have support for static/instance factories in XWT.
<Shell xmlns="http://www.eclipse.org/xwt/presentation" xmlns:x="http://www.eclipse.org/xwt"
	 xmlns:p1="clr-namespace:org.eclipse.ui.forms.widgets">
	<Shell.layout>
		<RowLayout/>
	</Shell.layout>
	<p1:Section text="My Section title" x:Style="(p1:Section).EXPANDED | (p1:Section).TWISTIE | (p1:Section).TITLE_BAR">
		<p1:Section.layoutData>
			<RowData width="330" height="248"/>
		</p1:Section.layoutData>
		<Section.client>
			<Button text="test"/>
		</Section.client>
	</p1:Section>
</Shell>
[Updated on: Thu, 18 March 2010 17:45] by Moderator
Re: org.eclipse.e4.xwt.XWTException [message #521866 is a reply to message #521811] Thu, 18 March 2010 20:25 Go to previous messageGo to next message
You need org.eclipse.e4.xwt.forms plugin. You can find examples in the
package org.eclipse.e4.xwt.test.forms
yves
"St Clair Clarke" <st_clair@flowja.com> wrote in message
news:hnttfe$g3b$1@build.eclipse.org...
> Hello,
> <Composite.layout>
> </Composite.layout>
> text="Section Two">
> <Section.client>
> </Section.client>
> </Section>
> </Composite>
> try
> XWT.open( url );
> Loader.java:419)
> Loader.java:648)
> Loader.java:449)
> (Realm.java:332)
> recognized.
> Thanks
Re: org.eclipse.e4.xwt.XWTException [message #521896 is a reply to message #521866] Fri, 19 March 2010 04:18 Go to previous messageGo to next message
Yves YANG wrote on Fri, 19 March 2010 03:25
Ah... It uses special class XWTForms for rendering.
Hm... Do you think that this is good?
I personally would prefer to have single rendering entry point, which will discover new supported classes automatically (using extensions) or manually.
Re: org.eclipse.e4.xwt.XWTException [message #522056 is a reply to message #521844] Fri, 19 March 2010 14:56 Go to previous messageGo to next message
Hello KC,
Thanks for the info.
However, if you look at the unmodified code from xwt cvs, you will notice it is significantly different from yours. And when it renders it does so looking like the section created by WBP.
    <Composite.layout>
    </Composite.layout>
	<Section name="Section" x:style="Section.TITLE_BAR|Section.TWISTIE|Section.EXPANDED"
        text="Section Two">
        <Section.client>
        </Section.client>
    </Section>
</Composite>
I am going to post Yves to tell me where can I find the namespace package test.ui above as I think somethings are in that package that I fail to see.
Moving the code from xwt CVS to another e4 and attempting to run the cod fails though.
When I put the xmlns:p1="clr-namespace:org.eclipse.ui.forms.widgets"> namespace the section looks like simple text rendering.
Let me know what you think.
Thanks.
St Clair
Re: org.eclipse.e4.xwt.XWTException [message #522057 is a reply to message #521866] Fri, 19 March 2010 15:02 Go to previous messageGo to next message
Hello Yves,
If you look at the penultimate line in the dependencies list in my initial post, note that the class you mentioned is present, yet none of the snippets run.
I note in the test snippets, no explicite namespace is created for the org.eclipse.e4.xwt.test.forms package.
Something else is still missing.
Re: org.eclipse.e4.xwt.XWTException [message #522060 is a reply to message #522056] Fri, 19 March 2010 15:12 Go to previous messageGo to next message
St Clair Clarke wrote on Fri, 19 March 2010 21:56
Hello KC,
Look carefully on Form_Section.java
public class Form_Section {
		URL url = Form_Section.class.getResource(Form_Section.class.getSimpleName()
				+ IConstants.XWT_EXTENSION_SUFFIX);
		try {
			XWTForms.open(url);
		} catch (Exception e) {
Note, that it uses XWTForms for rendering.
This is why it can use Section styles (without causing exception like you posted) and it looks nice (because internally it creates Section using default FormToolkit, not just new Section class without decoration).
Re: org.eclipse.e4.xwt.XWTException [message #522078 is a reply to message #522060] Fri, 19 March 2010 16:28 Go to previous messageGo to next message
Hello KC,
Thanks. And the fault was mine. Just missed that important piece of code.
All the forms are now working, but I noticed something peculiar.
None of the forms are displayed in the designer. The designer just has a text saying Loading...
This is also what the cvs checkout does.
Any idea why the forms are not being rendered in the Designer?
Re: org.eclipse.e4.xwt.XWTException [message #522084 is a reply to message #522078] Fri, 19 March 2010 16:55 Go to previous messageGo to next message
St Clair Clarke wrote on Fri, 19 March 2010 23:28
Yes, this was surprise for me too.
As we know now, support for Forms lives in separate plugin which does not contribute anything into main XWT. Instead you should "pull" this support by using special renderer - XWTForms. As I can see, this is not done in org.eclipse.e4.xwt.tools.ui.designer plugin. So, no rendering for Forms.
I've noticed also that org.eclipse.e4.xwt.tools.ui.designer has class org.eclipse.e4.xwt.tools.ui.designer.loader.ResourceVisitor which is almost identical to the org.eclipse.e4.xwt.javabean.ResourceLoader in XWT library itself. So, probably, currently designer is just quick and dirty implementation to prove concept of XML based SWT UI editing and not all features are supported.
Re: org.eclipse.e4.xwt.XWTException [message #523603 is a reply to message #522057] Sat, 27 March 2010 02:14 Go to previous messageGo to next message
news:ho0hni$tb1$1@build.eclipse.org...
> Hello Yves,
> snippets run.
If you use the default namespace, its corresponding Java class must be
registered to the XWT. XWTForms is a help class to register some eclipse
Forms classes be
fore calling XWT.load()/open()
yves
> Thanks
Re: org.eclipse.e4.xwt.XWTException [message #523604 is a reply to message #521896] Sat, 27 March 2010 02:17 Go to previous messageGo to next message
"Konstantin Scheglov" <Konstantin.Scheglov@gmail.com> wrote in message
news:hnvc15$md7$1@build.eclipse.org...
> manually.
As I said in the reponse to St Clair, we need to register some classes of
eclipose forms before calling XWT. XWTForms is just a help class.
Best regards
> Konstantin Scheglov,
> Instantiations, Inc.
Re: org.eclipse.e4.xwt.XWTException [message #523655 is a reply to message #523604] Sun, 28 March 2010 04:42 Go to previous messageGo to next message
Yves YANG wrote on Sat, 27 March 2010 09:17
OK
Thank you for clarifying this.
Re: org.eclipse.e4.xwt.XWTException [message #523673 is a reply to message #523603] Sun, 28 March 2010 10:38 Go to previous messageGo to next message
Hello Yves,
Thanks for the reply. Please reply with a small example of how this registration should be done.
I have tried to to this in the code-behind class of the corresponding XWT forms but then the XWT.register() does not allow it.
St Clair
Re: org.eclipse.e4.xwt.XWTException [message #571059 is a reply to message #521866] Fri, 19 March 2010 04:18 Go to previous messageGo to next message
Re: org.eclipse.e4.xwt.XWTException [message #571156 is a reply to message #521866] Fri, 19 March 2010 15:02 Go to previous messageGo to next message
Hello Yves,
Re: org.eclipse.e4.xwt.XWTException [message #571979 is a reply to message #571156] Sat, 27 March 2010 02:14 Go to previous messageGo to next message
> Hello Yves,
> snippets run.
Forms classes be
yves
> Thanks
Re: org.eclipse.e4.xwt.XWTException [message #572016 is a reply to message #521896] Sat, 27 March 2010 02:17 Go to previous messageGo to next message
> manually.
Best regards
Re: org.eclipse.e4.xwt.XWTException [message #572127 is a reply to message #523604] Sun, 28 March 2010 04:43 Go to previous messageGo to next message
OK
Re: org.eclipse.e4.xwt.XWTException [message #572200 is a reply to message #523603] Sun, 28 March 2010 10:38 Go to previous message
Hello Yves,
St Clair
Previous Topic:Re: Eclipse E4 product export
Next Topic:Re: Eclipse E4 product export
Current Time: Wed Jul 23 07:34:35 EDT 2025
Powered by FUDForum. Page generated in 0.47321 seconds
