Home » Archived » DSDP - Mobile Tools for Java (MTJ) » mtj create package but without html
mtj create package but without html [message #27870] Thu, 12 March 2009 08:35 Go to next message
eclipse 3.4, mtj 1.0m5
mtj can't copy html file from /res to build/ ..?
when i renmae the exmple.html to exmple.txt its copy automation, but
..html doesn't work..?
Re: mtj create package but without html [message #27910 is a reply to message #27870] Thu, 12 March 2009 08:43 Go to previous messageGo to next message
update:
can't copy html file from /res to bin/
Re: mtj create package but without html [message #28029 is a reply to message #27910] Wed, 18 March 2009 13:33 Go to previous messageGo to next message
I've created a MIDlet project using MTJ 1.0 M5 on a Eclipse SDK 3.4, with
two files on the /res foder (a.txt and a.html) and both were correctly
copied to the final jar package.
Could you check if your /res folder is configured as a source folder in
the "Java Build Path" property page? You can also checked in the
included/excluded rules also available in that page.
You could also try to refresh your workspace, it may be out of sync with
the file system.
Re: mtj create package but without html [message #28146 is a reply to message #28029] Mon, 23 March 2009 06:27 Go to previous messageGo to next message
hi thank for your reply.
but not rules in project, and refresh\restart\clean\rebuild the
workspace.. but not effect..
maybe conflict with some plug-in(jdt/cdt/svn/ve/wdt installed from
download.eclipse.org),
sorry for this, now i known its my problem, let me more test..
arli
Diego Madruga Sandin wrote:
> with two files on the /res foder (a.txt and a.html) and both were
> correctly copied to the final jar package.
> the file system.
Re: mtj create package but without html [message #28185 is a reply to message #28146] Fri, 27 March 2009 10:26 Go to previous message
Originally posted by: craigjunk.setera.org
You may also want to make sure that another application on your computer
does not have the file open as well. This might cause an operating
system lock that could cause this type of issue.
Craig
> arli
Re: mtj create package but without html [message #571927 is a reply to message #27870] Thu, 12 March 2009 08:43 Go to previous message
update:
Re: mtj create package but without html [message #571978 is a reply to message #27910] Wed, 18 March 2009 13:33 Go to previous message
the file system.
Re: mtj create package but without html [message #572062 is a reply to message #28029] Mon, 23 March 2009 06:27 Go to previous message
arli
> the file system.
Re: mtj create package but without html [message #572093 is a reply to message #28146] Fri, 27 March 2009 10:26 Go to previous message
Craig
> arli
Previous Topic:PersistenceException when importing devices
Next Topic:No javaME project
Current Time: Thu Jul 24 17:57:38 EDT 2025
Powered by FUDForum. Page generated in 0.04360 seconds
