Home » Eclipse Projects » Eclipse 4 » XWT: Preview & Run-time views are different
XWT: Preview & Run-time views are different [message #571697] Thu, 25 March 2010 01:25 Go to next message
I have simple UI element, which has two button and a text widgets. The XWT designer and the Preview shows the button and text size (width and height) as I expected. But the run-time widget sizes are not shown as I defined. The default widget size is being shown.
Anyone has any idea, what is the correct way to define the widget width and height?
Demo.xwt
<Composite xmlns="http://www.eclipse.org/xwt/presentation"
xmlns:x="http://www.eclipse.org/xwt" xmlns:c="clr-namespace:demo.xwt"
xmlns:j="clr-namespace:java.lang" x:Class="demo.xwt.Demo">
<Composite.layout>
<GridLayout numColumns="2" />
</Composite.layout>
<Text x:style="SWT.NONE" weight="400" height="150" />
<Button x:style="SWT.PUSH" x:Name="NotifyButton1" text="Notify" width="200" Height="50" />
<Button x:style="SWT.PUSH" x:Name="NotifyButton2" text="Notify" width="200" Height="50" />
</Composite>
Demo.java
public class Demo extends Composite {
public Demo(Composite parent, int style) {
super(parent, style);
Simple main method:
URL content = Demo.class.getResource("Demo.xwt");
try {
XWT.open(content);
} catch (Exception e) {
e.printStackTrace();
Re: XWT: Preview & Run-time views are different [message #571767 is a reply to message #571697] Thu, 25 March 2010 07:56 Go to previous messageGo to next message
You should use GridData for GridLayout instead of specifying size directly.
In general Layout manages location and size, so your width/height are overridden.
You want something like this
<Composite xmlns="http://www.eclipse.org/xwt/presentation" xmlns:x="http://www.eclipse.org/xwt">
<Composite.layout>
<GridLayout numColumns="1"/>
</Composite.layout>
<Text x:Style="BORDER">
<Text.layoutData>
<GridData grabExcessHorizontalSpace="true" horizontalAlignment="FILL" heightHint="150"/>
</Text.layoutData>
</Text>
<Button x:Name="NotifyButton1" text="Notify">
<Button.layoutData>
<GridData widthHint="200" heightHint="50"/>
</Button.layoutData>
</Button>
<Button x:Name="NotifyButton2" text="Notify">
<Button.layoutData>
<GridData heightHint="50" widthHint="200"/>
</Button>
</Composite>
Konstantin Scheglov,
Instantiations, Inc.
Re: XWT: Preview & Run-time views are different [message #571876 is a reply to message #571767] Thu, 25 March 2010 16:21 Go to previous messageGo to next message
Thank you so much again, Konstantin. This was very helpful.
Re: Preview & Run-time views are different [message #573427 is a reply to message #571697] Thu, 08 April 2010 03:16 Go to previous message
How do you set the width and height, via XWT Visual Designer? If so, it
could be a bug of the tool and please report a bug.
Yves
"can kayacan" <kayacanc@hotmail.com> wrote in message
news:hoes53$hh2$1@build.eclipse.org...
> and height?
> Demo.xwt
> <Composite.layout>
> </Composite.layout>
> </Composite>
> Demo.java
> Simple main method: public static void main(String[] args) {
> try {
> XWT.open(content);
Previous Topic:Form support in XWT Designer
Next Topic:XWT: Preview & Run-time views are different
Current Time: Sun Jul 20 23:53:36 EDT 2025
Powered by FUDForum. Page generated in 0.58181 seconds
