| Performance issues with loading xsds [message #56870] |
Tue, 04 January 2005 15:33  |
I am loading some very large XSDs using Eclipse just using the API and am
seeing that the schemas are taking a long time to load. I am calling
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.FALSE) since I don't need to track locations. I was wondering if
there was any other flag I could set that could speed things up
substantially.
The model that I am loading does not need to be manipulated in any way -
it's solely for read purposes only.
Hayden Marchant
| Re: Performance issues with loading xsds [message #57160 is a reply to message #56925] |
Tue, 18 January 2005 12:19  |
--------------030506070305010403020103
Hayden,
No, there aren't any flags that will significantly boost performance.
But we do hope to have time to do some tuning in the 2.1 development cycle:
82613 <https://bugs.eclipse.org/bugs/show_bug.cgi?id=82613>
Hayden Marchant wrote:
> Elena,
> The XML Parser is not the heavy part of the parsing - it is taking
> about 6% of the total CPU time. I was wondering if there was anything
> else I could do about performance that could really help.
> I'm sure that there must be a tiny little flag that I could set that
> might save me :)
> Elena Litani wrote:
>> Hi Hayden,
>> "Hayden Marchant" <hayden.marchant@unicorn.com> wrote in message
>> news:creuj9$uj6$1@www.eclipse.org...
>>> I was wondering if
>>> substantially.
>> If you are parsing your model more than once, you should use the
>> XMLResource.OPTION_USE_PARSER option to specify a parser pool
>> implementation
>> that caches instances of an XML parser for each subsequent parse. The
>> default implemenatation of parser pool is the
>> org.eclipse.emf.ecore.xmi.impl.XMLParserPoolImpl (default constructor is
>> available).
>>> way -
>> If your application only needs to read and query schemas, you might
>> want to
>> look at the Xerces XML Schema API:
>> http://xml.apache.org/xerces2-j/faq-grammars.html#faq-5
>> Thanks,
>> Elena
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Hayden,<br>
<br>
| Re: Performance issues with loading xsds [message #593491 is a reply to message #56870] |
Tue, 04 January 2005 16:53  |
Hi Hayden,
> I was wondering if
> substantially.
XMLResource.OPTION_USE_PARSER option to specify a parser pool implementation
available).
If your application only needs to read and query schemas, you might want to
Elena
| Re: Performance issues with loading xsds [message #593500 is a reply to message #56898] |
Wed, 05 January 2005 03:04  |
Elena,
The XML Parser is not the heavy part of the parsing - it is taking about
6% of the total CPU time. I was wondering if there was anything else I
I'm sure that there must be a tiny little flag that I could set that might
save me :)
Elena Litani wrote:
> Hi Hayden,
>> I was wondering if
>> substantially.
> available).
> Elena
| Re: Performance issues with loading xsds [message #593613 is a reply to message #56925] |
Hayden,
> Elena,
> might save me :)
> Elena Litani wrote:
>> Hi Hayden,
>>> I was wondering if
>>> substantially.
>> implementation
>> available).
>>> way -
>> want to
>> Thanks,
>> Elena
<html>
<head>
<title></title>
</head>
Hayden,<br>
<br>
FUDForum. Page generated in 0.29921 seconds
