Home » Archived » Riena » new objects and IObjectID
new objects and IObjectID [message #2881] Tue, 20 May 2008 16:18 Go to next message
Originally posted by: ekkehard.gentz-software.de
the next question ;-)
I read that each object must have a unique IObjectID
and the client has to create a temp IObjectID for new objects.
am I right that these temp IObjectID have to be unique inside one OT
and that the client is responsible for this ?
and I have to use ObjectTransaction.setObjectIdUpdate()
first time at server after getting the new ID from Hibernate
second time at client after import server-delta, commitToObjects
(and of course to all @EMBEDDED objects)
thx
ekke
Re: new objects and IObjectID [message #3005 is a reply to message #2881] Mon, 26 May 2008 07:11 Go to previous messageGo to next message
nearly right
- you have to create temp unique ids on the client
- you have to call setObjectIdUpdate() when you set the real object id on the server
- however that becomes part of the OT and therefore gets into the delta
- so once you stored the data on the server, the objectid is modified
- you extract a delta and apply that on the client
- that will also make the objectids change on the client (automagically)
- same with setVersionUpdate (set on the server, gets automagially updated on the client with the next delta)
christian
> thx
> ekke
Re: new objects and IObjectID [message #3052 is a reply to message #3005] Mon, 26 May 2008 13:56 Go to previous message
the @ID field will be set from Hibernate (Database)
at the moment there's no setter
so I also have to add a private setter - so the client will be able
to set the ID from OT after getting server - delta
thx for info
ekke
Christian Campo wrote:
> nearly right
the server
> christian
>> thx
>> ekke
Re: new objects and IObjectID [message #571506 is a reply to message #2881] Mon, 26 May 2008 07:11 Go to previous message
nearly right
christian
> thx
> ekke
Re: new objects and IObjectID [message #571616 is a reply to message #3005] Mon, 26 May 2008 13:56 Go to previous message
thx for info
ekke
> nearly right
the server
> christian
>> thx
>> ekke
Previous Topic:Embedded Objects - Value Objects
Next Topic:riena server outside eclipse
Current Time: Sun Jul 20 17:17:51 EDT 2025
Powered by FUDForum. Page generated in 0.05605 seconds
