Problem using maven-jibx-plugin [message #498815] |
Wed, 18 November 2009 12:28  |
Hello, I have problem executing a compile with the maven-jibx-plugin
The build section contains this declaration :
<plugin>
<groupId>org.jibx</groupId>
<artifactId>maven-jibx-plugin</artifactId>
<version>1.1.5</version>
<executions>
<execution>
<phase>compile</phase>
<goals>
<goal>bind</goal>
</goals>
</execution>
</executions>
<configuration>
<includes>
<include>binding*.xml</include>
</includes>
<verbose>true</verbose>
</configuration>
</plugin>
The event log isn't really helpfull, setting the filter at "debug" isn't either, i just end up with these events !
18:05:22 CET Starting Starting phaseExecution process-resources
18:05:22 CET Starting Starting mojoExecution resources:resources
18:05:22 CET info Using default encoding to copy filtered resources.
18:05:22 CET Finished Finished mojoExecution resources:resources
18:05:22 CET Finished Finished phaseExecution process-resources
18:05:22 CET Starting Starting phaseExecution compile
18:05:23 CET Starting Starting mojoExecution compiler:compile
18:05:23 CET info Nothing to compile - all classes are up to date
18:05:23 CET Finished Finished mojoExecution compiler:compile
18:05:23 CET Finished Finished phaseExecution compile
18:05:23 CET Starting Starting phaseExecution process-classes
18:05:24 CET Starting Starting mojoExecution jibx:bind
18:05:24 CET info Running JiBX binding compiler (single-module mode) on 2 binding file(s)
18:05:25 CET Error An error occurred in phase mojoExecution with the exception org.apache.maven.plugin.MojoExecutionException: Binding binding-menu.xml is unusable because of validation errors
18:05:25 CET Error An error occurred in phase projectExecution with the exception org.apache.maven.lifecycle.LifecycleExecutionException: Internal error in the plugin manager executing goal 'org.jibx:maven-jibx-plugin:1.1.5:bind': Mojo execution failed.
18:05:25 CET Error An error occurred in phase mavenExecution with the exception org.apache.maven.lifecycle.LifecycleExecutionException: Internal error in the plugin manager executing goal 'org.jibx:maven-jibx-plugin:1.1.5:bind': Mojo execution failed.
18:05:25 CET Error An error occurred in phase reactorExecution with the exception org.apache.maven.lifecycle.LifecycleExecutionException: Internal error in the plugin manager executing goal 'org.jibx:maven-jibx-plugin:1.1.5:bind': Mojo execution failed.
Doing a mvn clean package in the commadn line (Maven 2.0.10) is just working. I also tried to set the phase to process-classes, without success.
After some time I read on this JiBx usergroup ( http://old.nabble.com/Binding-binding.xml-is-unusable-becaus e-of-validation-errors-td14892163.html) the error "Binding binding-menu.xml is unusable because of validation errors" might be due to the path Jibx is looking for the classes.
Maybe the plugin cannot found the classes as they might not yet be generated by the eclipse compiler.
Is IAM taking care of the maven phases inside Eclipse?
Thx in advance for any help
For eventual readers, i found a workaround :
1. I set the maven-plugin-phase to process-classes
2. Eclipse does the compiling job (with the debug info)
3. In the command line, I execute "mvn process-classes" (Doing so in Eclipse with Execute Goal raises the above mentioned error)
4. In Eclipse it's now possible to run the application in debug mode!
It's far from perfect but it is working. Don't yet know if it's going to be accepted by the staff.
Re: Problem using maven-jibx-plugin [message #571377 is a reply to message #498887] |
Thu, 19 November 2009 06:41  |
Actually I have problems running this command line version :
C:\devhome\working_directory\10.0\ProjectAdmin-Build\Project Admin >set M2_HOME=c:\devhome\app\apache-maven-2.1-SNAPSHOT
C:\devhome\working_directory\10.0\ProjectAdmin-Build\Project Admin >set PATH=c:\devhome\app\apache-maven-2.1-SNAPSHOT\bin;%P
ATH%
C:\devhome\working_directory\10.0_BP\ProjectAdmin-Build\Proj ectAdmin >mvn clean process-classes
[INFO] Scanning for projects...
[INFO] Attempting to resolve a version for plugin: org.codehaus.mojo:cobertura-maven-plugin using meta-version: LATEST
[INFO] Using version: 2.3 of plugin: org.codehaus.mojo:cobertura-maven-plugin
[INFO] ------------------------------------------------------------ ------------
[INFO] Building ProjectAdmin
[INFO]
[INFO] Id: com.vsct.wdi:ProjectAdmin:war:10.0-SNAPSHOT
[INFO] task-segment: [clean, process-classes]
[INFO] [clean:clean]
[INFO] Deleting file set: C:\devhome\working_directory\10.0\ProjectAdmin-Build\Project Admin\src\main\webapp\WEB-INF\classes (included: [**], excluded: [])
[INFO] [cobertura:clean]
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
constituent[0]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/aspectjrt -1.5.3.jar
constituent[1]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/commons-c li-1.0.jar
constituent[2]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/commons-l ogging-api-1.1.jar
constituent[3]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/doxia-sin k-api-1.0-alpha-9.jar
constituent[4]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/jsch-0.1. 27.jar
constituent[5]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/jtidy-4au g2000r7-dev.jar
constituent[6]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/log4j-1.2 .12.jar
constituent[7]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/maven-art ifact-3.0-alpha-1.jar
constituent[8]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/maven-cor e-2.1-SNAPSHOT.jar
constituent[9]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/maven-emb edder-2.1-SNAPSHOT.jar
constituent[10]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/maven-lif ecycle-2.1-SNAPSHOT.jar
constituent[11]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/maven-mod el-2.1-SNAPSHOT.jar
constituent[12]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/maven-plu gin-api-2.1-SNAPSHOT.jar
constituent[13]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/maven-pro file-2.1-SNAPSHOT.jar
constituent[14]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/maven-pro ject-2.1-SNAPSHOT.jar
constituent[15]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/maven-rep orting-api-2.1-SNAPSHOT.jar
constituent[16]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/maven-too lchain-2.1-SNAPSHOT.jar
constituent[17]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/maven-wor kspace-2.1-SNAPSHOT.jar
constituent[18]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/plexus-co ntainer-default-1.0-alpha-47.jar
constituent[19]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/plexus-in teractivity-api-1.0-alpha-6.jar
constituent[20]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/plexus-in terpolation-1.0.jar
constituent[21]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/plexus-ut ils-1.5.1.jar
constituent[22]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/wagon-fil e-1.0-beta-2.jar
constituent[23]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/wagon-htt p-lightweight-1.0-beta-2.jar
constituent[24]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/wagon-htt p-shared-1.0-beta-2.jar
constituent[25]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/wagon-pro vider-api-1.0-beta-2.jar
constituent[26]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/wagon-ssh -1.0-beta-2.jar
constituent[27]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/wagon-ssh -common-1.0-beta-2.jar
constituent[28]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/wagon-ssh -external-1.0-beta-2.jar
constituent[29]: file:/c:/devhome/app/apache-maven-2.1-SNAPSHOT/lib/xbean-ref lect-3.4.jar
at org.apache.maven.project.artifact.MavenMetadataSource$Projec tRelocation.access$0(MavenMetadataSource.java:573)
at org.apache.maven.project.artifact.MavenMetadataSource.retrie veRelocatedArtifact(MavenMetadataSource.java:105)
at org.apache.maven.artifact.resolver.DefaultArtifactCollector. recurse(DefaultArtifactCollector.java:513)
at org.apache.maven.artifact.resolver.DefaultArtifactCollector. recurse(DefaultArtifactCollector.java:554)
at org.apache.maven.artifact.resolver.DefaultArtifactCollector. collect(DefaultArtifactCollector.java:132)
at org.apache.maven.artifact.resolver.DefaultArtifactResolver.r esolveTransitively(DefaultArtifactResolver.java:347)
at org.apache.maven.artifact.resolver.DefaultArtifactResolver.r esolveTransitively(DefaultArtifactResolver.java:321)
at org.apache.maven.artifact.resolver.DefaultArtifactResolver.r esolveTransitively(DefaultArtifactResolver.java:289)
at org.apache.maven.plugin.DefaultPluginManager.resolveTransiti veDependencies(DefaultPluginManager.java:1455)
at org.apache.maven.plugin.DefaultPluginManager.executeMojo(Def aultPluginManager.java:522)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeG oalAndHandleFailures(DefaultLifecycleExecutor.java:498)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeT askSegmentForProject(DefaultLifecycleExecutor.java:265)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeT askSegments(DefaultLifecycleExecutor.java:191)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute( DefaultLifecycleExecutor.java:149)
at org.apache.maven.DefaultMaven.execute_aroundBody0(DefaultMav en.java:223)
at org.apache.maven.DefaultMaven.execute_aroundBody1$advice(Def aultMaven.java:304)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:1)
at org.apache.maven.embedder.MavenEmbedder.execute_aroundBody2( MavenEmbedder.java:904)
at org.apache.maven.embedder.MavenEmbedder.execute_aroundBody3$ advice(MavenEmbedder.java:304)
at org.apache.maven.embedder.MavenEmbedder.execute(MavenEmbedde r.java:1)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:176)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:63)
at sun.reflect.NativeMethodAccessorImpl.invoke0(NativeMethod)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnha nced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Lau ncher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithEx itCode(Launcher.java:408)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launc her.java:351)
at org.codehaus.classworlds.Launcher.main(Launcher.java:31)
However for information I also tried maven 2.2.1, and it is working fine.
FUDForum. Page generated in 0.07176 seconds
