Home » Modeling » Epsilon » ETL rule execution
ETL rule execution [message #23160] Thu, 23 July 2009 06:53 Go to next message
Hi again,
Just a quick question which I couldn't find an answer to in the Epsilon
book (I might have missed it though):
Does a non-abstract, non-lazy ETL rule only get fired once during a
transformation -- and then the result is cached somewhere? I ask as I was
curious as to whether the following code fragment is bad practice...
var x := sourceComponent.equivalents('ruleX').select(i |
i.isKindOf(SomeClass));
var y := sourceComponent.equivalents('ruleX').select(i |
i.isKindOf(OtherClass));
So, does ruleX get fired 2 times internally, or does its result get stored
somewhere and is just (selectively) retrieved 2 times -- or perhaps I've
just totally missed the target :)?!
I guess this question touches upon some differences between rules and
operations... maybe?
Thanks in advance,
Edd
Re: ETL rule execution [message #23202 is a reply to message #23160] Thu, 23 July 2009 11:19 Go to previous message
Hi Edd,
Edward Turner wrote:
> Hi again,
That is correct.
I ask as I
> was curious as to whether the following code fragment is bad practice...
> stored somewhere and is just (selectively) retrieved 2 times -- or
> perhaps I've just totally missed the target :)?!
No. It actually runs only once and the second time you get the cached
results.
You can have cached operations as well (i.e. run first time only, then
return cached result) by attaching the @cached annotation. E.g.
@cached
operation foo() {
> Thanks in advance,
> Edd
Dimitris
Re: ETL rule execution [message #571011 is a reply to message #23160] Thu, 23 July 2009 11:19 Go to previous message
Hi Edd,
> Hi again,
That is correct.
I ask as I
results.
@cached
operation foo() {
> Thanks in advance,
> Edd
Dimitris
Previous Topic:ETL rule execution
Next Topic:[EuGENia] significance of Synchronize GMF Gen model
Current Time: Fri Jul 25 22:08:28 EDT 2025
Powered by FUDForum. Page generated in 0.06661 seconds
