| [jaxws] error creating web service from pojo [message #493531] |
Mon, 26 October 2009 12:10  |
I am using the latest (sept 11 2009) version of the JAX-WS Tools Project for Eclipse 3.5.1. I am actually using Spring's STS 2.2.0, which is based on Eclipse 3.5.1.
Last week, my experience with the feature was great: wrote a pojo with @WebService and @WebMethod annos, right-clicked and said generate web service. Wrapper code and additional annotations flew out. It was great.
Today I get a problem when running the jaxws code gen (message and stacktrace from .log file at the bottom). I can't really tell what the problem is except that it can't create the javaw process. (error=87, the parameter is incorrect). I don't see anyone talking about this particular problem and I can't find out what the parameters might be that are incorrect. I can only think that it is a setting or something in my project.
Any help? Let me know what info I can provide.
log excerpt:
!ENTRY org.eclipse.debug.core 4 125 2009-10-26 10:39:53.681
!MESSAGE Exception occurred executing command line.
!STACK 0
java.io.IOException: Cannot run program "C:\Program Files\Java\jdk1.6.0_16\bin\javaw.exe": CreateProcess error=87, The parameter is incorrect
at java.lang.ProcessBuilder.start(ProcessBuilder.java:459)
at java.lang.Runtime.exec(Runtime.java:593)
at java.lang.Runtime.exec(Runtime.java:509)
at org.eclipse.debug.core.DebugPlugin.exec(DebugPlugin.java:803)
at org.eclipse.jdt.launching.AbstractVMRunner.exec(AbstractVMRunner.java:70)
at org.eclipse.jdt.internal.launching.StandardVMRunner.run(StandardVMRunner.java:317)
at org.eclipse.jst.ws.internal.cxf.core.utils.LaunchUtils.launch(LaunchUtils.java:103)
at org.eclipse.jst.ws.internal.cxf.creation.core.commands.Java2WSCommand.execute(Java2WSCommand.java:87)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.runCommand(CommandFragmentEngine.java:419)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.visitTop(CommandFragmentEngine.java:359)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.moveForwardToNextStop(CommandFragmentEngine.java:212)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager$6.run(SimpleCommandEngineManager.java:294)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:944)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager.runForwardToNextStop(SimpleCommandEngineManager.java:264)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.runForwardToNextStop(WizardPageManager.java:91)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.getNextPage(WizardPageManager.java:154)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizardPage.getNextPage(SimpleWizardPage.java:136)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:823)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.wst.command.internal.env.ui.widgets.popup.DynamicPopupWizard.run(DynamicPopupWizard.java:130)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: java.io.IOException: CreateProcess error=87, The parameter is incorrect
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(ProcessImpl.java:81)
at java.lang.ProcessImpl.start(ProcessImpl.java:30)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:452)
... 58 more
| Re: [jaxws] error creating web service from pojo [message #494956 is a reply to message #494195] |
Tue, 03 November 2009 06:39   |
Hi Jeff,
Thanks for the positive comment What do you have in mind for the visibility stuff? The JAXWS code effectively calls out to a tool within the runtime's installation and delegates the generation to it entirely. What you are seeing here is a FAIL on the attempt to actually launch the tool. Of course, behind the scenes, we do build a classpath with which the tool must be launched, and it's most likely that classpath
that is ending up as overly long for poor old Windows. But I'm sure the Spring part updates the classpath too, so that adds more to mix. And if the file locations of the JARs have long pathnames, well then the classpath will be a monster, character-count wise.
So I'm not too sure that this is 'fixable' as such, since the classpath will be the target of other pieces of technology. But what might make sense is some kind of a warning at some stage, so that the developer doesn't get startled with this kind of cryptic fail. It's always worth putting in a bugzilla, just for tracking purposes, to see if anyone comes up with any bright ideas.
cheers
--oh
| Re: [jaxws] error creating web service from pojo [message #570653 is a reply to message #494195] |
Hi Jeff,
Thanks for the positive comment :) What do you have in mind for the visibility stuff? The JAXWS code effectively calls out to a tool within the runtime's installation and delegates the generation to it entirely. What you are seeing here is a FAIL on the attempt to actually launch the tool. Of course, behind the scenes, we do build a classpath with which the tool must be launched, and it's most likely that classpath
cheers
--oh
| Re: [jaxws] error creating web service from pojo [message #1807325 is a reply to message #731809] |
Tue, 28 May 2019 03:55  |
Sivakumar wrote on Mon, 03 October 2011 07:24Hi jeff,
did you overcome with this issue..?
i am also facing the same problem on the same thing.
please share if you find the solution.
Thank you...
It was said above that beter way for a solution is to put in a bugzilla to see if anyone comes up with any helpful ideas on the issue.
Good luck!
FUDForum. Page generated in 0.05610 seconds
