Home » Archived » AM3 » Refactoring deprecated AM3 branch to use ATL 3.0 API
Refactoring deprecated AM3 branch to use ATL 3.0 API [message #482682] |
Thu, 27 August 2009 10:23  |
<html>
<head>
</head>
Hi everybody, I'm trying to rewrite some parts of AM3's deprecated
packages branch to use ATL 3.0.<br>
I have managed to modify most parts to use the new API, but I have
doubts on a particular piece of code.<br>
The code in hands is in class
org.eclipse.gmt.am3.tools.ant.ATLModelTransformationTask, and is this
one:<br>
<br>
<font face="Courier New, Courier, monospace"> ...<br>
if(vm == null)<br>
<font color="#ff0000">vm = AtlVM.ATLVM_REGULAR; </font>
<br>
...<br>
if (!debug.booleanValue())<br>
<font color="#ff0000">AtlVM.getVM(vm).launch(asmUrl, libs,
models, params, superimps, options);</font><br>
...<br>
</font><br>
I guess I can rewrite the first red line as<br>
<br>
<font face="Courier New, Courier, monospace"> vm =
ATLLaunchConstants.REGULAR_VM_NAME;<br>
<br>
</font>but I don't believe this is the correct way to go, I think I
should change the structure somehow.<br>
Can anyone give me a pointer on this?.<br>
Thanks,<br>
Juan Pedro<br>
</body>
</html>
Re: Refactoring deprecated AM3 branch to use ATL 3.0 API [message #482946 is a reply to message #482682] |
Fri, 28 August 2009 12:03   |
Hi Juan,
First, thank you very much for your contribution. I'm sure it will be
used by many AM3 & ATL developers :-)
> org.eclipse.gmt.am3.tools.ant.ATLModelTransformationTask, and is this one:
> if(vm == null)
> AtlVM.getVM(vm).launch(asmUrl, libs, models, params,
> vm = ATLLaunchConstants.REGULAR_VM_NAME;
> but I don't believe this is the correct way to go, I think I should
From my point of view, what you propose is good because it keeps
exactly the same behavior as the previous version. I don't think it is
necessary to modify the current structure of the plugin, at least in a
first time.
Of course, it would be great if you could contribute your upgrades by
submitting a patch via Bugzilla!
Hugo
> Juan Pedro
Hugo Bruneliere - R&D Engineer
AtlanMod research team (INRIA & EMN) - Room B206
École des Mines de Nantes
4, rue Alfred Kastler
44307 Nantes Cedex 3 - France
Office: +33 (0)2 51 85 82 21
EMail: hugo.bruneliere@inria.fr
Re: Refactoring deprecated AM3 branch to use ATL 3.0 API [message #483228 is a reply to message #482946] |
Mon, 31 August 2009 12:20   |
--------------010402090705050600050704
Hi Hugo, thank you for your support.
If I take the mentioned approach, the following instruction:
AtlVM.getVM(vm).launch(asmUrl, libs, models, params, superimps, options);
Is no longer supported (AtlVM is no longer there in ATL 3.0), so I need
a suggestion in how to rewrite that instruction.
These alternatives might work, but not sure which is best:
RegularVMLauncher.launch(java.lang.String mode,
org.eclipse.core.runtime.IProgressMonitor
monitor,
java.util.Map<java.lang.String,java.lang.Object> options,
java.lang.Object... modules);
or
AtlLauncher.getDefault().launch(java.net.URL asmurl, java.util.Map
libraries, java.util.Map models, java.util.Map asmParams, java.util.List
superimpose, java.util.Map options)
The first alternative is using the regular VM, but parameters are not
the same, and as documentation is scarce, I don't know how to convert them.
On the other side, the second alternative takes the same parameters, but
my feeling is that it will use the new VM (as it is the default one),
and not regular VM.
There may be other (more correct) alternatives, but I'm not acquainted
with the new API, and those are the ones I found so far.
Do you have any suggestions for this instruction?.
I'll love to contribute once I finish refactoring.
Thanks for your help.
Juan Pedro
Hugo Bruneliere escribi
Re: Refactoring deprecated AM3 branch to use ATL 3.0 API [message #483633 is a reply to message #483228] |
Wed, 02 September 2009 07:50   |
Hi Juan,
> monitor,
> or
> and not regular VM.
In order to get the launcher of the Regular VM (but which conforms to
the new ILauncher interface), you can use the "getLauncher()" method of
the org.eclipse.m2m.atl.core.service.CoreService class:
ILauncher atlLauncher =
CoreService.getLauncher(ATLLaunchConstants.REGULAR_VM_NAME);
//of course, ATLLaunchConstants.EMF_VM_NAME also exists
atlLauncher.launch(...);
Hugo
> Regards,
> Juan Pedro
> Hugo Bruneliere escribió:
>> Hi Juan,
>>> one:
>>> if(vm == null)
>>> vm = AtlVM.ATLVM_REGULAR; ...
>> first time.
>> Cheers,
>> Hugo
>>> Thanks,
>>> Juan Pedro
Re: Refactoring deprecated AM3 branch to use ATL 3.0 API [message #483669 is a reply to message #483633] |
Wed, 02 September 2009 10:30   |
--------------060100000503070907070001
Thank you very much, Hugo.
I ended up with this piece of code (let me know if you consider it
appropriated):
try
//AtlVM.getVM(vm).launch(asmUrl, libs, models, params,
//AtlLauncher.getDefault().launch(asmUrl, libs, models,
ASM asm = new ASMXMLReader().read(new
BufferedInputStream(asmUrl.openStream()));
superimps.add(0, asm); //New ILauncher.launch(..) method
takes a list of modules where the first module of the set is overriden
by the next ones
ILauncher atlL =
atlL.launch(ILauncher.RUN_MODE, new
NullProgressMonitor(), options, superimps);
} catch (IOException e)
ATLLogger.log(Level.SEVERE, e.getLocalizedMessage(), e);
} catch (ATLCoreException e) {
e.printStackTrace();
I will do a partial test of my refactorization with an AMW
refactorization I'm also performing (it may take a while, though, as I
have other thing in hand).
Perhaps (if you already have test suites for AM3) you may like me to
send it to you so you could start testing it already?. Just let me know.
How is everyone in EDM-Nantes?, send my regards.
Mer
Re: Refactoring deprecated AM3 branch and AMW model handler to use ATL 3.0 API [message #484148 is a reply to message #483669] |
Fri, 04 September 2009 08:22   |
Hi Juan Pedro,
> appropriated):
> try
> by the next ones
> ILauncher atlL =
Unfortunately, as we are not continuing the development of these
plug-ins anymore, we don't have such a test suite. However, one simple
way of validating your new implementation is to manually test each of
the injectors, extractors, and other converters (concerning KM3, ATL,
XML, etc) on a given set of files/models/metamodels. Thus, you will be
able to ensure that the general behavior of these plug-ins has not been
altered.
Similarly, for AMW, you can try to run some of the use cases available
from the AMW website using both ATL 3.0 and your new implementation of
the AMW model handler.
> Merçi ;-),
Everything goes well at EMN. Thanks!
Hugo
> Juan Pedro
>> Hi Juan,
>>> options);
>>> need a suggestion in how to rewrite that instruction.
>>> org.eclipse.core.runtime.IProgressMonitor monitor,
>>> or
>>> java.util.List superimpose, java.util.Map options)
>>> them.
>>> but my feeling is that it will use the new VM (as it is the default
>>> one), and not regular VM.
>>> acquainted with the new API, and those are the ones I found so far.
>> of the org.eclipse.m2m.atl.core.service.CoreService class:
>> Cheers,
>> Hugo
>>> Regards,
>>> Juan Pedro
>>>> Hi Juan,
>>>> be used by many AM3 & ATL developers :-)
>>>>> this one:
>>>>> if(vm == null)
>>>> is necessary to modify the current structure of the plugin, at least
>>>> in a first time.
>>>> by submitting a patch via Bugzilla!
>>>> Cheers,
>>>> Hugo
>>>>> Thanks,
>>>>> Juan Pedro
Re: Refactoring deprecated AM3 branch and AMW model handler to use ATL 3.0 API [message #487148 is a reply to message #484148] |
Tue, 22 September 2009 03:26   |
Hi Juan Pedro,
I am wondering whether you have checked the AmwModelHandler behavior on
ATL 3.0?
After some experimentations, it seems to me the handler methods are not
available in ATL 3.0. Do you plan to settle these functionalities?
Hugo Bruneliere a écrit :
> Hi Juan Pedro,
>> appropriated):
>> try
>> superimps.add(0, asm); //New ILauncher.launch(..) method takes a list
>> of modules where the first module of the set is overriden by the next
>> ones
>> ILauncher atlL =
> altered.
>> Merçi ;-),
> Cheers,
> Hugo
>> Juan Pedro
>>> Hi Juan,
>>>> options);
>>>> or
>>>> not the same, and as documentation is scarce, I don't know how to
>>>> convert them.
>>> Cheers,
>>> Hugo
>>>> Regards,
>>>> Juan Pedro
>>>>> Hi Juan,
>>>>>> this one:
>>>>>> if(vm == null)
>>>>> least in a first time.
>>>>> Cheers,
>>>>> Hugo
>>>>>> Thanks,
>>>>>> Juan Pedro
Kelly Garces - Phd. student
AtlanMod & AsCoLa research teams
Re: Refactoring deprecated AM3 branch and AMW model handler to use ATL 3.0 API [message #490086 is a reply to message #487148] |
Wed, 07 October 2009 05:43   |
Hi Juan Pedro,
Do you have some latest news on your refactoring work around AMW and
"old" AM3?
Is it still in progress?
Please, don't hesitate if you need any specific information from our side.
Hugo
Kelly Garces a écrit :
> Hi Juan Pedro,
> ATL 3.0?
> Regards,
>> Hi Juan Pedro,
>>> appropriated):
>>> try
>>> ones
>>> ILauncher atlL =
>>> I have other thing in hand).
>> been altered.
>>> Merçi ;-),
>> Cheers,
>> Hugo
>>> Juan Pedro
>>>> Hi Juan,
>>>>> options);
>>>>> or
>>>>> convert them.
>>>>> parameters, but my feeling is that it will use the new VM (as it is
>>>>> the default one), and not regular VM.
>>>> to the new ILauncher interface), you can use the "getLauncher()"
>>>> method of the org.eclipse.m2m.atl.core.service.CoreService class:
>>>> Cheers,
>>>> Hugo
>>>>> Regards,
>>>>> Juan Pedro
>>>>>> Hi Juan,
>>>>>>> deprecated packages branch to use ATL 3.0.
>>>>>>> have doubts on a particular piece of code.
>>>>>>> this one:
>>>>>>> if(vm == null)
>>>>>> it is necessary to modify the current structure of the plugin, at
>>>>>> Cheers,
>>>>>> Hugo
>>>>>>> Thanks,
>>>>>>> Juan Pedro
Ecole des Mines de Nantes
Re: Refactoring deprecated AM3 branch and AMW model handler to use ATL 3.0 API [message #491705 is a reply to message #487148] |
Thu, 15 October 2009 10:08  |
Sorry Kelly and Hugo for not responding this earlier.
Hugo already contacted me, so I believe you are tracking this issue back
in INRIA now.
I'm posting this so everybody else knnows it's still ongoing.
Juan Pedro
Kelly Garces escribió:
> Hi Juan Pedro,
> on ATL 3.0?
> not available in ATL 3.0. Do you plan to settle these functionalities?
> Regards,
>> Hi Juan Pedro,
>>> appropriated):
>>> try
>>> list of modules where the first module of the set is overriden by
>>> the next ones
>>> ILauncher atlL =
>>> e);
>>> e);
>>> know.
>> simple way of validating your new implementation is to manually test
>> each of the injectors, extractors, and other converters (concerning
>> KM3, ATL, XML, etc) on a given set of files/models/metamodels. Thus,
>> you will be able to ensure that the general behavior of these
>> plug-ins has not been altered.
>> available from the AMW website using both ATL 3.0 and your new
>> implementation of the AMW model handler.
>>> Merçi ;-),
>> Cheers,
>> Hugo
>>> Juan Pedro
>>>> Hi Juan,
>>>>> options);
>>>>> or
>>>>> convert them.
>>>>> is the default one), and not regular VM.
>>>> Cheers,
>>>> Hugo
>>>>> Regards,
>>>>> Juan Pedro
>>>>>> Hi Juan,
>>>>>> will be used by many AM3 & ATL developers :-)
>>>>>>> this one:
>>>>>>> if(vm == null)
>>>>>> upgrades by submitting a patch via Bugzilla!
>>>>>> Cheers,
>>>>>> Hugo
>>>>>>> Thanks,
>>>>>>> Juan Pedro
Re: Refactoring deprecated AM3 branch to use ATL 3.0 API [message #570298 is a reply to message #482682] |
Hi Juan,
> if(vm == null)
first time.
Hugo
> Juan Pedro
Re: Refactoring deprecated AM3 branch to use ATL 3.0 API [message #570318 is a reply to message #482946] |
monitor,
or
and not regular VM.
Juan Pedro
Re: Refactoring deprecated AM3 branch to use ATL 3.0 API [message #570329 is a reply to message #483228] |
Hi Juan,
> monitor,
> or
> and not regular VM.
Hugo
> Regards,
> Juan Pedro
>> Hi Juan,
>>> one:
>>> if(vm == null)
>> first time.
>> Cheers,
>> Hugo
>>> Thanks,
>>> Juan Pedro
Re: Refactoring deprecated AM3 branch to use ATL 3.0 API [message #570343 is a reply to message #483633] |
appropriated):
try
by the next ones
ILauncher atlL =
Mer
Re: Refactoring deprecated AM3 branch and AMW model handler to use ATL 3.0 API [message #570352 is a reply to message #483669] |
Hi Juan Pedro,
> appropriated):
> try
> by the next ones
> ILauncher atlL =
altered.
> Merçi ;-),
Hugo
> Juan Pedro
>> Hi Juan,
>>> options);
>>> or
>>> them.
>> Cheers,
>> Hugo
>>> Regards,
>>> Juan Pedro
>>>> Hi Juan,
>>>>> this one:
>>>>> if(vm == null)
>>>> in a first time.
>>>> Cheers,
>>>> Hugo
>>>>> Thanks,
>>>>> Juan Pedro
Re: Refactoring deprecated AM3 branch and AMW model handler to use ATL 3.0 API [message #570375 is a reply to message #484148] |
Hi Juan Pedro,
ATL 3.0?
> Hi Juan Pedro,
>> appropriated):
>> try
>> ones
>> ILauncher atlL =
> altered.
>> Merçi ;-),
> Cheers,
> Hugo
>> Juan Pedro
>>> Hi Juan,
>>>> options);
>>>> or
>>>> convert them.
>>> Cheers,
>>> Hugo
>>>> Regards,
>>>> Juan Pedro
>>>>> Hi Juan,
>>>>>> this one:
>>>>>> if(vm == null)
>>>>> Cheers,
>>>>> Hugo
>>>>>> Thanks,
>>>>>> Juan Pedro
Re: Refactoring deprecated AM3 branch and AMW model handler to use ATL 3.0 API [message #570390 is a reply to message #487148] |
Hi Juan Pedro,
"old" AM3?
Hugo
> Hi Juan Pedro,
> ATL 3.0?
> Regards,
>> Hi Juan Pedro,
>>> appropriated):
>>> try
>>> ones
>>> ILauncher atlL =
>> been altered.
>>> Merçi ;-),
>> Cheers,
>> Hugo
>>> Juan Pedro
>>>> Hi Juan,
>>>>> options);
>>>>> or
>>>>> convert them.
>>>> Cheers,
>>>> Hugo
>>>>> Regards,
>>>>> Juan Pedro
>>>>>> Hi Juan,
>>>>>>> this one:
>>>>>>> if(vm == null)
>>>>>> Cheers,
>>>>>> Hugo
>>>>>>> Thanks,
>>>>>>> Juan Pedro
Re: Refactoring deprecated AM3 branch and AMW model handler to use ATL 3.0 API [message #570402 is a reply to message #487148] |
in INRIA now.
Juan Pedro
> Hi Juan Pedro,
> on ATL 3.0?
> Regards,
>> Hi Juan Pedro,
>>> appropriated):
>>> try
>>> the next ones
>>> ILauncher atlL =
>>> e);
>>> e);
>>> know.
>>> Merçi ;-),
>> Cheers,
>> Hugo
>>> Juan Pedro
>>>> Hi Juan,
>>>>> options);
>>>>> or
>>>>> convert them.
>>>> Cheers,
>>>> Hugo
>>>>> Regards,
>>>>> Juan Pedro
>>>>>> Hi Juan,
>>>>>>> this one:
>>>>>>> if(vm == null)
>>>>>> Cheers,
>>>>>> Hugo
>>>>>>> Thanks,
>>>>>>> Juan Pedro
Current Time: Fri Jul 18 19:57:59 EDT 2025
Powered by FUDForum. Page generated in 0.05338 seconds
