Home » Eclipse Projects » Babel » Language only in my rcp application, not in PDE
Language only in my rcp application, not in PDE [message #9814] Mon, 05 May 2008 15:14 Go to next message
Originally posted by: nzelan.gmail.com
Hi folks,
I highly appreciate your efforts regarding translations: thank you all !
My question now:
I'd like to enable french language in my rcp application BUT still want to
run PDE in english ( otherwise I'm completely lost ...)
How can I setup this?
I downloaded the french translations : the next time i restarted eclipse
was in french... I tried to force english by using -nl en_EN : still in
french.
The major problem I face is an exception when rendering the plugin.xml
editor in french, thus making the PDE unusable in french ...
THanks for your help !
NZ
short trace when opening plugin.xml in french language :
java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.swt.SWT.error(SWT.java:3547)
at org.eclipse.swt.SWT.error(SWT.java:3481)
at
org.eclipse.ui.internal.forms.widgets.FormTextModel.parseInp utStream(FormTextModel.java:114)
at
org.eclipse.ui.internal.forms.widgets.FormTextModel.parseTag gedText(FormTextModel.java:93)
at org.eclipse.ui.forms.widgets.FormText.setText(FormText.java: 668)
at
org.eclipse.pde.internal.ui.editor.plugin.DependencyManageme ntSection.createClient(DependencyManagementSection.java:212)
at
org.eclipse.pde.internal.ui.editor.StructuredViewerSection.<init >(StructuredViewerSection.java:45)
at
org.eclipse.pde.internal.ui.editor.TableSection.<init>(TableSection.java:89)
Re: Language only in my rcp application, not in PDE [message #9836 is a reply to message #9814] Tue, 06 May 2008 13:17 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
Hi noem,
I really can't answer your question, but I'm hoping someone here can.
As this is a generic Eclipse question, and not necessarily related to
Babel, you could perhaps ask on eclipse.platform too. If they answer
over there, feel free to repost the answer here for completeness.
Denis
noem wrote:
> Hi folks,
> My question now:
> to run PDE in english ( otherwise I'm completely lost ...)
> french.
> NZ
> at
> at
> at
> at
> at
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: Language only in my rcp application, not in PDE [message #9856 is a reply to message #9836] Tue, 06 May 2008 14:57 Go to previous messageGo to next message
Hi Denis,
Thanks for replying,
I understand,
I will post a message and let you know about any results..
noem
Re: Language only in my rcp application, not in PDE [message #9877 is a reply to message #9836] Wed, 07 May 2008 10:01 Go to previous messageGo to next message
hi,
here is the result of my findings:
1) run eclipse in english : be sure the OS regional settings are set to
english ( in my case it was french ...)
2 from platform.rcp newsgroup:
When using PDE, in the target platform preference page, there should be an
"environment tab" where you can select which language you would be
developing against. So when you go to launch your application, PDE would
use the proper language. That way, you can run PDE in any language.
~ Chris
All that solved my problem !
enjoy,
noem
Re: Language only in my rcp application, not in PDE [message #9900 is a reply to message #9877] Wed, 07 May 2008 11:07 Go to previous message
Thanks for that!!
noem wrote:
> hi,
> an "environment tab" where you can select which language you would be
> Cheers,
> ~ Chris
> enjoy, noem
Re: Language only in my rcp application, not in PDE [message #569994 is a reply to message #9814] Tue, 06 May 2008 13:17 Go to previous message
Hi noem,
Denis
noem wrote:
> Hi folks,
> My question now:
> french.
> NZ
> at
> at
> at
> at
> at
Re: Language only in my rcp application, not in PDE [message #570048 is a reply to message #9836] Tue, 06 May 2008 14:57 Go to previous message
Hi Denis,
I understand,
noem
Re: Language only in my rcp application, not in PDE [message #570163 is a reply to message #9836] Wed, 07 May 2008 10:01 Go to previous message
hi,
~ Chris
enjoy,
noem
Re: Language only in my rcp application, not in PDE [message #570177 is a reply to message #9877] Wed, 07 May 2008 11:07 Go to previous message
Thanks for that!!
noem wrote:
> hi,
> Cheers,
> ~ Chris
> enjoy, noem
Previous Topic:Language only in my rcp application, not in PDE
Next Topic:How complete is the Japanese translation?
Current Time: Wed Nov 05 19:48:47 EST 2025
Powered by FUDForum. Page generated in 0.06522 seconds
