| Unable to login to Bugzilla [message #5168] | Fri, 29 June 2007 17:42  |  |
| Eclipse User  |  |  |  |  | I'm using the final Eclipse 3.3 with Mylyn 2.0 and I'm trying to connect it to my company Bugzilla account.  In the Task Repositories view, I can enter in the server URL and my authentication info, when I click the Validate Settings button it says "Authentication credentials are valid", but as soon as I try to do a query I get a dialog that says
 Unable to login to https://<my bugzilla URL>.
 log in to bugzilla
 Please validate credentials via Task Repositories view.
 How do I fix this issue?  I've never used the Mylyn plugin before, but it seems really interesting and I'd love to get it working.  Thanks for any help!
| Re: Unable to login to Bugzilla [message #6737 is a reply to message #5237] | Mon, 02 July 2007 07:50  |  |
| Eclipse User  |  |  |  |  | I'm facing the same Problem. Bugzilla 2.22.1 with a self signed certificate. There was never a question for accepting the certificate like in subclipse.
 No http authentication.
 Tried with and without proxy from two different places. Both resulted in an
 error.
 I switched in 'additional settings' to repository version 2.22
 Now I changed to a free test certificate from radpidssl that is fully
 functional. Still the same error.
 Anonymous access to https://bugs.eclipse.org/bugs works fine.
 I filled in a bug report:
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=195113
 Tobias
 "Robert Elves" <rob.elves@eclipse.org> schrieb im Newsbeitrag
 news:f644ue$582$1@build.eclipse.org...
 > Joshua,
 > The Bugzilla connector does have shortcomings when dealing with some
 > customized Bugzilla installs. One side effect can be failure to
 > authenticate (or recognize successful authentication). A few things to
 > try:
 > - If using a proxy ensure it is set either in your Workspace preferences
 > or within the Task Repository settings page.
 > - If the company Bugzilla site is protected via http authentication,
 > ensure your username and password are set in the Task Repository settings
 > page.
 > If this doesn't result in success, please open a bug report
 > (https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Mylyn) and we can
 > continue debugging there.
 > -Rob
 >> but as soon as I try to do a query I get a dialog that says Unable to
 >> login to https://<my bugzilla URL>.  log in to bugzilla
 >> help!
| Re: Unable to login to Bugzilla [message #569043 is a reply to message #5168] | Fri, 29 June 2007 19:34  |  |
| Eclipse User  |  |  |  |  | Joshua,
 authenticate (or recognize successful authentication). A few things to try:
 settings page.
 -Rob
 > log in to bugzilla
| Re: Unable to login to Bugzilla [message #569164 is a reply to message #5237] | Fri, 29 June 2007 21:30  |  |
| Eclipse User  |  |  |  |  | Thank you for the feedback.  I am not using a proxy, it's not using any HTTP authentication and it's not a customized Bugzilla install.  It is a stock 2.22.2 installation.  The only thing I can think of is that it is using a self-signed SSL certificate (HTTPS), though that will be changing shortly.  If this scenario should work, then I'll file a bug report.  Thanks again for your help. |  |  |  |
| Re: Unable to login to Bugzilla [message #569353 is a reply to message #5237] | Mon, 02 July 2007 07:50  |  |
 error.
 Tobias
 > Joshua,
 > try:
 > page.
 > -Rob
 >> help!
FUDForum. Page generated in 0.04681 seconds
