Home » Archived » IAM (Eclipse Integration for Apache Maven) » IAM doesnt run surefire-report:report correctly
IAM doesnt run surefire-report:report correctly [message #569032] Mon, 18 May 2009 21:13
IAM doesnt run "surefire-report:report" the same way as it executes from
the command line.
The problem arises when tests fail. The point of the report is to tell you
what tests failed. But IAM seems to stop the build early, because the
tests failed. So you dont get a report. :(
When I run maven from command line, this does not happen.
Previous Topic:Further problems running jetty:run and jetty:stop in q4e 0.9
Next Topic:IAM doesnt run surefire-report:report correctly
Current Time: Fri Jul 18 12:07:54 EDT 2025
Powered by FUDForum. Page generated in 0.45797 seconds
