Home » Eclipse Projects » DSDP - Target Management » Customizing New Connection Wizard
Customizing New Connection Wizard [message #10743] Wed, 13 June 2007 16:48 Go to next message
Hello!
I am in the process of researching everything that needs to be done to
create a custom RSE service. I understand how create the service itself
after looking at the SSH, FTP, and dstore implementations, but now I have
a question about UI customization for the service.
In the New Connection Wizard, which lists all available connection types,
say you select "SSH Only" and click Next. Is the following wizard page
customizable? In my case, the connection I'm creating will not have a host
name and instead the user will need to select a virtual machine.
Thanks!
Re: Customizing New Connection Wizard [message #10775 is a reply to message #10743] Wed, 13 June 2007 18:04 Go to previous messageGo to next message
I see from the post "How to open a new connection wizard for a particular
system type?" that it is indeed possible to customize the new connection
wizard.
Are there any example classes in the RSE source tree that customize the
new connection wizard? My searches have come up empty.
Thanks!
Troy
Re: Customizing New Connection Wizard [message #10806 is a reply to message #10775] Thu, 14 June 2007 07:37 Go to previous message
Hi Troy,
> wizard.
The extension point you are looking for is
org.eclipse.ui.newConnectionWizards. The plugin org.eclipse.rse.discovery
contains a example of contributing a wizard for a specific system type. See
the extension point documentation for details on the extension point
attributes.
Best regads, Uwe
Uwe Stieber, Member of Technical Staff - Sys, Wind River
Re: Customizing New Connection Wizard [message #568286 is a reply to message #10743] Wed, 13 June 2007 18:04 Go to previous message
wizard.
Thanks!
Troy
Re: Customizing New Connection Wizard [message #568304 is a reply to message #10775] Thu, 14 June 2007 07:37 Go to previous message
Hi Troy,
> wizard.
attributes.
Best regads, Uwe
Previous Topic:Customizing New Connection Wizard
Next Topic:Old HP NetBeans plug-in
Current Time: Tue Jul 22 00:56:27 EDT 2025
Powered by FUDForum. Page generated in 0.13361 seconds
