Home » Eclipse Projects » Linux Tools Project » Installing LTTv library for Eclipse LTTng plugin
Installing LTTv library for Eclipse LTTng plugin [message #506141] Wed, 06 January 2010 05:42 Go to next message
Originally posted by: frederic.thomas.obeo.fr
Hi guys !
I have some problems to install the LTTv library for Eclipse. I am
following the instructions in the help contents page. I have downloaded
the last lttv source master from the git repository
(http://lttng.org/cgi-bin/gitweb.cgi?p=lttv.git;a=summary -> Mon, 4 Jan
2010 18:53:58).
When I make, I get this error :
jni_interface.c: In function
'Java_org_eclipse_linuxtools_lttng_jni_JniTracefile_ltt_1pri ntTracefile':
jni_interface.c:504: erreur: structure n'a pas de membre nommé « buf_size »
Which version of the repository I must compile to get the lttv in Eclipse ?
Thanks a lot.
Fred
Re: Installing LTTv library for Eclipse LTTng plugin [message #506227 is a reply to message #506141] Wed, 06 January 2010 10:45 Go to previous messageGo to next message
Hi Frederic,
Congratulations, you are on the bleeding edge of the project...
The venerable LTTng trace format was recently changed in preparation for a number of upcoming features (e.g. streaming).
Unfortunately, the LTTv git (out of our direct control Smile has not yet been updated to include the patches required by the "new and improved" JNI integration.
To make a long story short, you will have to use the Beta JNI build (available at: http://git.dorsal.polymtl.ca/?p=liblttngtrace.git;a=summary). For more details, refer to the Help page.
Note that this library works only with the latest LTTng patches as we don't yet support heterogeneous trace formats (we bleed enough as it is with just the latest format Smile
If you need a sample trace (new format), just let us know.
Hope this helps,
Francois
Re: Installing LTTv library for Eclipse LTTng plugin [message #506262 is a reply to message #506227] Wed, 06 January 2010 12:36 Go to previous message
Hi Francois,
I succeed in installing the liblttngtrace.
I have now a second problem. When I click on the experiment folder I
have this exception in eclipse :
** (Eclipse:4154): WARNING **: Unsupported trace version : 2.3
** (Eclipse:4154): WARNING **: parse_trace_header error
** (Eclipse:4154): WARNING **: Trace
Test_trace/Traces/trace-618339events-1293lost-1cpu has no metadata tracefile
org.eclipse.linuxtools.lttng.trace.LTTngTraceException: Error while
opening trace. Is the tracepath correct? (openTrace)
at
org.eclipse.linuxtools.lttng.trace.LTTngTrace.<init>(LTTngTrace.java:116)
at org.eclipse.linuxtools.lttng.trace.LTTngTrace.<init>(LTTngTrace.java:97)
Do you have a trace example that it's working with the liblttngtrace and
the last eclipse repository ?
Best regards.
Frédéric
Francois Chouinard a écrit :
> Hi Frederic,
> Unfortunately, the LTTv git (out of our direct control :) has not yet
> JNI integration.
> (available at:
> with just the latest format :)
> Hope this helps,
> Francois
Re: Installing LTTv library for Eclipse LTTng plugin [message #568085 is a reply to message #506141] Wed, 06 January 2010 10:45 Go to previous message
Hi Frederic,
Unfortunately, the LTTv git (out of our direct control :) has not yet been updated to include the patches required by the "new and improved" JNI integration.
Note that this library works only with the latest LTTng patches as we don't yet support heterogeneous trace formats (we bleed enough as it is with just the latest format :)
Hope this helps,
Francois
Re: Installing LTTv library for Eclipse LTTng plugin [message #568116 is a reply to message #568085] Wed, 06 January 2010 12:36 Go to previous message
Hi Francois,
at
Best regards.
Frédéric
> Hi Frederic,
> JNI integration.
> (available at:
> Hope this helps,
> Francois
Previous Topic:Installing LTTv library for Eclipse LTTng plugin
Next Topic:using libhover for 3rd party documentation
Current Time: Wed Jul 23 13:30:48 EDT 2025
Powered by FUDForum. Page generated in 0.47357 seconds
