Home » Archived » MOFScript » Sequence of Transformation
Sequence of Transformation [message #469382] |
Wed, 11 March 2009 09:41  |
I want to know if I can call two or more *.m2t files in the transformation
process, because in the most of time I need it and do one by one isn't
very practical.
Thanks for the attention.
Re: Sequence of Transformation [message #469405 is a reply to message #469399] |
Mon, 23 March 2009 14:24  |
Hi again,
I had seen the samples of inheritance and I understood, but I didn't see
much diference between import a transformation file and extends to other
transformation. Because if I do a import, I have all the acess to the
imported transformation, so why extends? the only diference wich I could
see was the override.
Am I wrong?
Gøran K. Olsen wrote:
> Hello Fabrico,
> Have to look into this in detail, it might be a bug.
> When it comes to transformation inheritance it is works quite as usual.
> A transformation may extends another transformation using the extends
> keyword. Only single inheritance is allowed.
> The sub transformation inherits all rules of the super transformation, may
> override these and call the rules of the super using the 'super' keyword.
> The example copied from "help->mofcsript" in eclipse, and also described in
> User Manual section 5.15 Transformation inheritance.
> import "TestInheritanceSuper.m2t"
> texttransformation TestInheritanceSub (in ecmodel:ecore) extends
> TestInheritanceSuper {
> ecmodel.EPackage::main() {
> self.printMe()
> ecmodel.EPackage::printMe() {
> stdout.println ("TestIneritanceSub::printMe<")
> super.printMe();
> stdout.println ("TestIneritanceSub::printMe>")
> Cheers,
> Gøran
> "Fabricio Pellegrini" <fabricio.pellegrini@gmail.com> wrote in message
> news:8d0eb19d47e5856929d87e5f737ed140$1@www.eclipse.org...
>> Hi,
>> It was the second case, now I have one transformation which import all
>> other rules, but I have a problem in same cases when I tried to do a
>> import in one file which already had being imported, for exemple:
>> File A import B and C.
>> File B import D.
>> When I compile B, no error appear, but when I compile A it says that can't
>> find D.
>> other thing that I want know is "When I need to extend one transformation
>> to other?" I tried to do a exemple with extend, but I needed to import the
>> other file which have the transformation. So with the import I already
>> have the acess to the rules of the other transformation. Can you show me a
>> exemple when extend can be used?
>> Thanks
Re: Sequence of Transformation [message #567977 is a reply to message #469382] |
Sun, 15 March 2009 05:34  |
Hello Fabricio,
If I understrand you correctly, you will like to call differernt
transformations with different source models.
To accomplish this you will have to write a small Jave program, in the help
section, you will find a simple example for calling one transformation.
If it is the same source, you can just use the import mechanism.
/G
Re: Sequence of Transformation [message #568009 is a reply to message #469389] |
Wed, 18 March 2009 09:11  |
File B import D.
find D.
to other?"
I tried to do a exemple with extend, but I needed to import the other file
which have the transformation. So with the import I already have the acess
Can you show me a exemple when extend can be used?
Re: Sequence of Transformation [message #568041 is a reply to message #469395] |
Sat, 21 March 2009 22:41  |
Hello Fabrico,
self.printMe()
super.printMe();
G
Re: Sequence of Transformation [message #568066 is a reply to message #469399] |
Hi again,
Am I wrong?
> Hello Fabrico,
> self.printMe()
> super.printMe();
> Cheers,
> Gøran
>> Hi,
>> File B import D.
>> find D.
>> Thanks
Current Time: Thu Jul 24 21:53:03 EDT 2025
Powered by FUDForum. Page generated in 0.10836 seconds
