Home » Archived » MOFScript » Sequence of Transformation
Sequence of Transformation [message #469382] Wed, 11 March 2009 09:41 Go to next message
I want to know if I can call two or more *.m2t files in the transformation
process, because in the most of time I need it and do one by one isn't
very practical.
Thanks for the attention.
Re: Sequence of Transformation [message #469389 is a reply to message #469382] Sun, 15 March 2009 05:34 Go to previous messageGo to next message
Hello Fabricio,
If I understrand you correctly, you will like to call differernt
transformations with different source models.
To accomplish this you will have to write a small Jave program, in the help
section, you will find a simple example for calling one transformation.
If it is the same source, you can just use the import mechanism.
/G
Re: Sequence of Transformation [message #469395 is a reply to message #469389] Wed, 18 March 2009 09:11 Go to previous messageGo to next message
It was the second case, now I have one transformation which import all
other rules, but I have a problem in same cases when I tried to do a
import in one file which already had being imported, for exemple:
File A import B and C.
File B import D.
When I compile B, no error appear, but when I compile A it says that can't
find D.
other thing that I want know is "When I need to extend one transformation
to other?"
I tried to do a exemple with extend, but I needed to import the other file
which have the transformation. So with the import I already have the acess
to the rules of the other transformation.
Can you show me a exemple when extend can be used?
Re: Sequence of Transformation [message #469399 is a reply to message #469395] Sat, 21 March 2009 22:41 Go to previous messageGo to next message
Hello Fabrico,
Have to look into this in detail, it might be a bug.
When it comes to transformation inheritance it is works quite as usual.
A transformation may extends another transformation using the extends
keyword. Only single inheritance is allowed.
The sub transformation inherits all rules of the super transformation, may
override these and call the rules of the super using the 'super' keyword.
The example copied from "help->mofcsript" in eclipse, and also described in
User Manual section 5.15 Transformation inheritance.
import "TestInheritanceSuper.m2t"
texttransformation TestInheritanceSub (in ecmodel:ecore) extends
TestInheritanceSuper {
ecmodel.EPackage::main() {
self.printMe()
ecmodel.EPackage::printMe() {
stdout.println ("TestIneritanceSub::printMe<")
super.printMe();
stdout.println ("TestIneritanceSub::printMe>")
G
Re: Sequence of Transformation [message #469405 is a reply to message #469399] Mon, 23 March 2009 14:24 Go to previous message
Hi again,
I had seen the samples of inheritance and I understood, but I didn't see
much diference between import a transformation file and extends to other
transformation. Because if I do a import, I have all the acess to the
imported transformation, so why extends? the only diference wich I could
see was the override.
Am I wrong?
Gøran K. Olsen wrote:
> Hello Fabrico,
> self.printMe()
> super.printMe();
> Cheers,
> Gøran
> "Fabricio Pellegrini" <fabricio.pellegrini@gmail.com> wrote in message
> news:8d0eb19d47e5856929d87e5f737ed140$1@www.eclipse.org...
>> Hi,
>> File B import D.
>> find D.
>> to other?" I tried to do a exemple with extend, but I needed to import the
>> other file which have the transformation. So with the import I already
>> have the acess to the rules of the other transformation. Can you show me a
>> Thanks
Re: Sequence of Transformation [message #567977 is a reply to message #469382] Sun, 15 March 2009 05:34 Go to previous message
Hello Fabricio,
/G
Re: Sequence of Transformation [message #568009 is a reply to message #469389] Wed, 18 March 2009 09:11 Go to previous message
File B import D.
find D.
to other?"
Re: Sequence of Transformation [message #568041 is a reply to message #469395] Sat, 21 March 2009 22:41 Go to previous message
Hello Fabrico,
self.printMe()
super.printMe();
G
Re: Sequence of Transformation [message #568066 is a reply to message #469399] Mon, 23 March 2009 14:24 Go to previous message
Hi again,
Am I wrong?
> Hello Fabrico,
> self.printMe()
> super.printMe();
> Cheers,
> Gøran
>> Hi,
>> File B import D.
>> find D.
>> Thanks
Previous Topic:Sequence of Transformation
Next Topic:Contribution for MOFScript project
Current Time: Sat Jul 26 11:14:58 EDT 2025
Powered by FUDForum. Page generated in 0.26586 seconds
