Home » Language IDEs » AspectJ » AJDT Plugin Question3
| AJDT Plugin Question3 [message #22038] |
Fri, 16 May 2003 05:57  |
Originally posted by: delasoul.operamail.com
Hello again,
thanx very much for your fast answer, but I have already a new problem...
When running ant and the ajdt tasks in eclipse, I get error below.
The ant script works fine from command line.
I looked in Bugzilla and found the bug, but could not find out, if the
problem is solved now or not.
Thanks again for any help
delasoul
[ajc] ABORT
[ajc] Exception thrown from AspectJ 1.1rc2
[ajc]
[ajc] This might be logged as a bug already -- find current bugs
at
[ajc]
http://bugs.eclipse.org/bugs/buglist.cgi?product=AspectJ& ;component=Compiler
[ajc]
[ajc] Bugs for exceptions thrown have titles File:line from the
top stack,
[ajc] e.g., "SomeFile.java:243"
[ajc]
[ajc] If you don't find the exception below in a bug, please add
a new bug
[ajc] at
http://bugs.eclipse.org/bugs/enter_bug.cgi?product=AspectJ
[ajc] To make the bug a priority, please include a test program
[ajc] that can reproduce this exception.
[ajc] (class:
org/aspectj/ajdt/internal/compiler/lookup/AjLookupEnvironmen t, method:
createBinaryTypeFrom signature:
(Lorg/eclipse/jdt/internal/compiler/env/IBinaryType;Lorg/ecl ipse/jdt/internal/compiler/lookup/PackageBinding;Z)Lorg/ecli pse/jdt/internal/compilerX¤/ð®5À%?À%üÃ%ô?
[ajc] (class:
[ajc] java.lang.VerifyError: (class:
[ajc] at
org.aspectj.ajdt.internal.core.builder.AjBuildManager.perfor mCompilation(AjBuildManager.java:351)
[ajc] at
org.aspectj.ajdt.internal.core.builder.AjBuildManager.doBuil d(AjBuildManager.java:133)
[ajc] at
org.aspectj.ajdt.internal.core.builder.AjBuildManager.batchB uild(AjBuildManager.java:78)
[ajc] at
org.aspectj.ajdt.ajc.AjdtCommand.doCommand(AjdtCommand.java: 106)
[ajc] at
org.aspectj.ajdt.ajc.AjdtCommand.runCommand(AjdtCommand.java :60)
[ajc] at org.aspectj.tools.ajc.Main.run(Main.java:217)
[ajc] at
org.aspectj.tools.ant.taskdefs.Ajc10.spoon(Ajc10.java:598)
[ajc] at
org.aspectj.tools.ant.taskdefs.Ajc10.execute(Ajc10.java:484)
[ajc] at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:193)
[ajc] at org.apache.tools.ant.Task.perform(Task.java:341)
[ajc] at org.apache.tools.ant.Target.execute(Target.java:309)
[ajc] at
org.apache.tools.ant.Target.performTasks(Target.java:336)
[ajc] at
org.apache.tools.ant.Project.executeTarget(Project.java:1339 )
[ajc] at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:397)
[ajc] at
org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:143)
[ajc] at
[ajc] at
[ajc] at
org.apache.tools.ant.Project.executeTargets(Project.java:125 5)
[ajc] at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:569)
[ajc] at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:367)
[ajc] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
Method)
[ajc] at
[ajc] at
[ajc] at java.lang.reflect.Method.invoke(Method.java:324)
[ajc] at org.eclipse.ant.core.AntRunner.run(AntRunner.java:335)
[ajc] at
org.eclipse.ui.externaltools.internal.ant.launchConfiguratio ns.AntLaunchDelegate$1.run(AntLaunchDelegate.java:172)
[ajc] at java.lang.Thread.run(Thread.java:536)
[ajc]
[ajc] BUILD FAILED:
file:C:/java/eclipseWorkspace/workspace/test/build.xml:114: Compilation
error: 1
| Re: AJDT Plugin Question3 [message #22934 is a reply to message #22716] |
Wed, 04 June 2003 06:11  |
Andrew Clement wrote:
> delasoul wrote:
> > Hello again,
> Hmmm - from some other work I've been doing with Eclipse I've had problems
> with ANT in Eclipse. But I don't know if you are seeing the same problem
> here. Can you tell me which bugzilla bug you were looking at?
> To get you working ... I see you are using the ajc task for aspectj1.0 and
> it does mention in the 1.1 doc that this old task is deprecated (although
> it should still work...). Is there anyway you can move on to the AspectJ
> 1.1 task (called iajc) - you can find a readme about it in the aspectj1.1
> documentation.
> Andy.
> AJDT Development
thanx again for your answer..
I now tried the iajc task, but still get an error in eclipse (see below),
but
My compile target looks like this:
<target name="Ajx" depends="init"
description="compile {list} and run {class} of example">
<echo message="##### Ajx list=${list} class=${class}" />
<antcall target="clean" />
<!-- can use ajc or iajc here -->
<iajc destdir="${build.dir}" argfiles="${list}"
classpath="${aspectjrt.jar}"/>
<antcall target="Ajx-run" >
<param name="class" value="${class}"/>
</antcall>
</target>
Here comes the error:
[iajc] ABORT
[iajc] Exception thrown from AspectJ 1.1rc2
[iajc]
[iajc] This might be logged as a bug already -- find current bugs
at
[iajc]
[iajc]
[iajc] Bugs for exceptions thrown have titles File:line from the
top stack,
[iajc] e.g., "SomeFile.java:243"
[iajc]
[iajc] If you don't find the exception below in a bug, please add
a new bug
[iajc] at
[iajc] To make the bug a priority, please include a test program
[iajc] that can reproduce this exception.
[iajc] (class:
(Lorg/eclipse/jdt/internal/compiler/env/IBinaryType;Lorg/ecl ipse/jdt/internal/compiler/lookup/PackageBinding;Z)Lorg/ecli pse/jdt/internal/compilerÜ
[iajc] @Þ#p½?p½üs½Àó
[iajc] ¼?>m
[iajc] (class:
[iajc] ¼?>m
[iajc] java.lang.VerifyError: (class:
[iajc] ¼?>m
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at org.aspectj.tools.ajc.Main.run(Main.java:217)
[iajc] at org.aspectj.tools.ajc.Main.runMain(Main.java:155)
[iajc] at
org.aspectj.tools.ant.taskdefs.AjcTask.executeInSameVM(AjcTa sk.java:839)
[iajc] at
org.aspectj.tools.ant.taskdefs.AjcTask.execute(AjcTask.java: 783)
[iajc] at
[iajc] at org.apache.tools.ant.Task.perform(Task.java:341)
[iajc] at org.apache.tools.ant.Target.execute(Target.java:309)
[iajc] at
[iajc] at
[iajc] at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:397)
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
Method)
[iajc] at
[iajc] at
[iajc] at java.lang.reflect.Method.invoke(Method.java:324)
[iajc] at org.eclipse.ant.core.AntRunner.run(AntRunner.java:335)
[iajc] at
[iajc] at java.lang.Thread.run(Thread.java:536)
[iajc]
[iajc] BUILD FAILED:
file:C:/java/eclipseWorkspace/workspace/aspectjTests/bin/bui ld.xml:122:
fail due to VerifyError "(class:
@Þ#p½€p½üs½Àó
¼›>m""ABORT" (1 exceptions)
| Re: AJDT Plugin Question3 [message #567870 is a reply to message #22038] |
Fri, 30 May 2003 09:42  |
Originally posted by: clemas.hotmail.com
delasoul wrote:
> Hello again,
documentation.
Andy.
AJDT Development
| Re: AJDT Plugin Question3 [message #568073 is a reply to message #22716] |
> delasoul wrote:
> > Hello again,
> documentation.
> Andy.
> AJDT Development
but
</antcall>
</target>
[iajc] ABORT
[iajc]
at
[iajc]
[iajc]
top stack,
[iajc]
a new bug
[iajc] at
[iajc] (class:
[iajc] ¼?>m
[iajc] (class:
[iajc] ¼?>m
[iajc] ¼?>m
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
[iajc] at
Method)
[iajc] at
[iajc] at
[iajc] at
[iajc]
@Þ#p½€p½üs½Àó
Current Time: Sat Nov 01 11:17:54 EDT 2025
Powered by FUDForum. Page generated in 0.04087 seconds
