Home » Archived » IMP » Issue with IMP source code checkout and build
| Issue with IMP source code checkout and build [message #9824] |
Fri, 12 October 2007 14:48  |
Originally posted by: sandip.sahoo1980.gmail.com
I have made CVS checkout and import IMP source code from the site into fresh
Eclipse 3.2.2 as specified here http://sourceforge.net/cvs/?group_id=201858
But there are a lot of errors coming when building because the following
plug-ins which are referenced in this project not available.
** com.ibm.watson.smapifier
** polyglot
**java_cup.runtime.lr_parser (jar not available)
** lpg.runtime
** x10.compiler
** x10.runtime
Please suggest me how to resolve the above problem.
Sandip
| Re: Issue with IMP source code checkout and build [message #9868 is a reply to message #9846] |
Mon, 15 October 2007 18:43   |
As of a couple of hours ago we have some better documentation on how to
get the projects built:
http://eclipse-imp.sourceforge.net/developers/index.html
This is the start of documentation aimed at IMP developers (i.e., people
who will be developing for IMP), as opposed to IMP users (i.e., people
who will be using IMP to create a language IDE). In any case, it has
more extensive information about how to obtain and build the various
projects relating to IMP.
As Michael has already written, you have to separately obtain and
install lpg and polyglot. You can separately obtain the X10 projects if
you want to run X10 (from x10.sourceforge.net), but that's not a central
part of IMP--just an example of an IMP IDE (and there are others in the
release, such as the LPG IDE).
The big problem for the moment is that we originally neglected to
release three projects that should be on the repository:
org.eclipse.imp.smapi
(recently renamed from com.ibm.watson.smapi)
org.eclipse.imp.smapifier
(recently renamed from com.ibm.watson.smapifier)
org.eclipse.imp.lpg.metatooling
We have just submitted these to SourceForge to be included in our CVS
repository, so now it is a question of waiting for that to happen. I
will look into whether we can make these projects available separately.
Stan Sutton
Michael Strothjohann wrote:
> Building your own IMP from source you need to install lpg, polyglot, ...
> details: http://eclipse-imp.sourceforge.net/installing/index.html
> michael
> "Sandip Sahoo" <sandip.sahoo1980@gmail.com> schrieb im Newsbeitrag
> news:feofin$d1i$1@build.eclipse.org...
>> Hi,
>> fresh Eclipse 3.2.2 as specified here
>> following plug-ins which are referenced in this project not available.
>> ** polyglot
>> ** lpg.runtime
>> ** x10.compiler
>> ** x10.runtime
>> Regards,
>> Sandip
| Re: Issue with IMP source code checkout and build [message #9914 is a reply to message #9868] |
Tue, 16 October 2007 03:08  |
Thanks!
I will try to do the same as you suggested below and let you know.
"Stanley Sutton" <suttons@us.ibm.com> wrote in message
news:ff0qec$mps$1@build.eclipse.org...
> who will be developing for IMP), as opposed to IMP users (i.e., people who
> will be using IMP to create a language IDE). In any case, it has more
> extensive information about how to obtain and build the various projects
> relating to IMP.
> As Michael has already written, you have to separately obtain and install
> lpg and polyglot. You can separately obtain the X10 projects if you want
> to run X10 (from x10.sourceforge.net), but that's not a central part of
> IMP--just an example of an IMP IDE (and there are others in the release,
> The big problem for the moment is that we originally neglected to release
> repository, so now it is a question of waiting for that to happen. I will
> Regards,
> Stan Sutton
>> michael
>>> Hi,
>>> ** polyglot
>>> ** lpg.runtime
>>> ** x10.compiler
>>> ** x10.runtime
>>> Regards,
>>> Sandip
| Re: Issue with IMP source code checkout and build [message #567211 is a reply to message #9846] |
Stan Sutton
> michael
>> Hi,
>> ** polyglot
>> ** lpg.runtime
>> ** x10.compiler
>> ** x10.runtime
>> Regards,
>> Sandip
| Re: Issue with IMP source code checkout and build [message #567260 is a reply to message #9868] |
Thanks!
> relating to IMP.
> Regards,
> Stan Sutton
>> michael
>>> Hi,
>>> ** polyglot
>>> ** lpg.runtime
>>> ** x10.compiler
>>> ** x10.runtime
>>> Regards,
>>> Sandip
Current Time: Sun Nov 09 01:32:29 EST 2025
Powered by FUDForum. Page generated in 0.04400 seconds
