Home » Eclipse Projects » JavaServer Faces » Feedback on the proposal from the IBM team..
Feedback on the proposal from the IBM team.. [message #469066] Tue, 19 July 2005 14:28 Go to next message
Meeting notes from a conference call with the IBM team on the JSF Proposal.
Date: June 24th, 05
Attendees:
From Oracle: Raghu Srinivasan, Brian Fry, Stephen Tom and Ian Trimble
From IBM: Arthur Ryman, George DeCandio and team
Following are the comments on the proposal:
1) Add JSF Project nature to any Web Module
Instead of Nature, it should read Feature. This concept will be implemented
in WTP 1.0.
2) Graphical Editor for JSF page
This is a big ticket item. The proposal should be changed in one of the
following ways:
a) Drop it. This is a complex undertaking and may not be realistic. Also,
vendors use this feature as a value-add and may not be inclined to
participate in the project since it conflicts with their business interest.
b) Keep this feature for completeness, but move it to a future release. This
is not the first thing we will build.
3) Graphical Editor for faces-config.xml
a) This is more reasonable and a valid feature.
b) Include form-based editor . Investigate Lepido technology.
3) Wizard
The proposal should identify this as an extension point and also commit to
delivering related API's These can be used to generate the first cut of a
JSF page that can then be customized. Improves developer productivity.
Use cases:
a) WebServices project should be able to generate a default client in JSF.
Currently it generates in JSP.
b) Model Driven Development project: Generate JSF for a given model.
c) Generate a JSF page for a given backing bean.
4) Application Configuration - faces-config.xml
The proposal should say that there will be a Java model and associated API's
to manipulate this programmatically.
5)Tentative Schedule is to coincide with release of WTP 1.5
6) Solicit support from other vendors at JavaOne.
Re: Feedback on the proposal from the IBM team.. [message #469107 is a reply to message #469066] Wed, 27 July 2005 22:37 Go to previous messageGo to next message
"Raghu Srinivasan" <e_raghu@yahoo.com> wrote in message
news:dbjgni$dob$1@news.eclipse.org...
> Proposal.
> Date: June 24th, 05
> Attendees:
> implemented
> in WTP 1.0.
> following ways:
> interest.
> This
I agree with option (b)
What Lepido technology? Can you give a link or explain it somehow?
> 3) Wizard
> Use cases:
I think this use case is too wide, we need to identify way how to define the
model for JSF.
Interesting. I think we can explore possibility to "link" together JSF(JSP)
and Java editors and look to the page like a combination of JSP and java
class and sync changes somehow in both directions.
> API's
I agree.
Make sense...
You have it already :-)
Igor.
Re: Feedback on the proposal from the IBM team.. [message #469110 is a reply to message #469107] Thu, 28 July 2005 05:49 Go to previous message
in short: Lepido = "Tooling for Cocoon" .
There is eclipse newsgroup on Lepido.
project hompage: http://www.eclipse.org/lepido/
project proposal: http://www.eclipse.org/proposals/eclipse-lepido/
michael
"Igor Shabalov" <ishabalov@exadel.com> schrieb im Newsbeitrag
news:dc9ge7$jev$1@news.eclipse.org...
>> Proposal.
>> Date: June 24th, 05
>> Attendees:
>> implemented
>> in WTP 1.0.
>> following ways:
>> interest.
>> This
>> 3) Wizard
>> to
>> a
>> Use cases:
>> JSF.
> the model for JSF.
> JSF(JSP) and Java editors and look to the page like a combination of JSP
> and java class and sync changes somehow in both directions.
>> API's
> I agree.
> Make sense...
> Best regards,
> Igor.
Re: Feedback on the proposal from the IBM team.. [message #567175 is a reply to message #469066] Wed, 27 July 2005 22:37 Go to previous message
> Proposal.
> Date: June 24th, 05
> Attendees:
> implemented
> in WTP 1.0.
> following ways:
> interest.
> This
> 3) Wizard
> Use cases:
model for JSF.
> API's
I agree.
Make sense...
Igor.
Re: Feedback on the proposal from the IBM team.. [message #567194 is a reply to message #469107] Thu, 28 July 2005 05:49 Go to previous message
michael
>> Proposal.
>> Date: June 24th, 05
>> Attendees:
>> implemented
>> in WTP 1.0.
>> following ways:
>> interest.
>> This
>> 3) Wizard
>> to
>> a
>> Use cases:
>> JSF.
> the model for JSF.
>> API's
> I agree.
> Make sense...
> Best regards,
> Igor.
Previous Topic:Project creation wizard
Next Topic:[REQ] Application Configuration Resource File - Model with API
Current Time: Wed Jul 23 22:52:10 EDT 2025
Powered by FUDForum. Page generated in 0.04999 seconds
