Home » Archived » EPF » epf doesn't run under 1.5.0_09 of jvm?
epf doesn't run under 1.5.0_09 of jvm? [message #21032] Fri, 06 October 2006 09:12 Go to next message
Originally posted by: me.me.com
Windows version of epf.exe is reporting;
"Version 1.3.1_01 of the jvm is not suitable for this product. Version:
1.4.1 or greater is required"
Yet Sun's jvm detector reports my system as having 1.5.0_09.
Can epf only be run with a specific version of the jvm, or have I missed
something when installing?
Thanks for any pointers.
Fraser
Re: epf doesn't run under 1.5.0_09 of jvm? [message #21111 is a reply to message #21032] Mon, 09 October 2006 12:23 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
EPF does need Sun JRE 1.4 onwards. You would have to check which JRE, EPF
is using on your system. Following message which you are getting leads me
to believe that EPF is picking 1.3.1_01 JVM on your system somehow.
So make sure you PATH variables are correct to point to correct SUN JVM.
Re: epf doesn't run under 1.5.0_09 of jvm? [message #21126 is a reply to message #21111] Mon, 09 October 2006 14:16 Go to previous message
Originally posted by: christopher.fuhrman.etsmtl.ca
> EPF is using on your system. Following message which you are getting
> leads me to believe that EPF is picking 1.3.1_01 JVM on your system
> somehow.
(Unfortunately?) installing a newer JRE/JDK doesn't remove the older
ones. I recall having a problem with an old install of 1.3.x of the JRE
that never quite got removed completely.
Prof. Christopher Fuhrman
Department of Software and IT Engineering
University of Quebec - École de technologie supérieure (ETS)
http://profs.logti.etsmtl.ca/cfuhrman/index.shtml?en
+1 (514) 396 8638
Re: epf doesn't run under 1.5.0_09 of jvm? [message #566696 is a reply to message #21032] Mon, 09 October 2006 12:23 Go to previous message
Re: epf doesn't run under 1.5.0_09 of jvm? [message #566728 is a reply to message #21111] Mon, 09 October 2006 14:16 Go to previous message
> somehow.
+1 (514) 396 8638
Previous Topic:About translations
Next Topic:EPF with Teneo
Current Time: Sun Nov 02 07:55:08 EST 2025
Powered by FUDForum. Page generated in 0.03415 seconds
