Home » Modeling » Amalgam » Cannot find workflow for tooltip in solution directory
Cannot find workflow for tooltip in solution directory [message #525142] Tue, 12 May 2009 03:57 Go to next message
Regarding the workflow for tooltip,I have noticed that the xpand template
is a little different between the book and what exists in CVS
(org.eclipse.amalgam/examples/org.eclipse.amalgam.examples.d sl.requirements/templates-diagram).
So I took the one from CVS. But I didn't find the corresponding workflow
file in CVS (tooltip.mwe). Because the one that I copied from the book
gives me parsing errors when running.
Is there a corresponding solution workflow file for tooltip in CVS
repository ?
Re: Cannot find workflow for tooltip in solution directory [message #525143 is a reply to message #525142] Tue, 12 May 2009 06:31 Go to previous messageGo to next message
What are the errors? I just ran it successfully.
Note that your .xpt file will show errors in the editor, due to bugs in that
version of Xpand. If/when I update the examples to use the newer Xpand
OCL/QVTO, these will disappear and template invocation will use Ant files
instead of .mwe workflow files.
Best,
Rich
On 5/12/09 3:57 AM, in article
829d982c965c8e7a8b55acdc0d00cee1$1@www.eclipse.org, "Jean Michel Boulcourt"
> mplates-diagram).
> repository ?
Re: Cannot find workflow for tooltip in solution directory [message #525144 is a reply to message #525143] Tue, 12 May 2009 08:11 Go to previous messageGo to next message
My first errors came from a mistake in the book (I will post in a new
message, so it can help other users maybe)
But now I have the following error when running workflow:
GRAVE: Error in Component of type org.eclipse.xpand2.Generator:
EvaluationException : Unable to load extension file : Utils
TooltipEditPolicy.xpt[254,59] on line 15
'editpolicy.editPolicyQualifiedClassName.replace('\\.','/')'
TooltipEditPolicy.xpt[150,29] on line 10 'EXPAND EditPolicy FOR tooltip'
[23,40] on line 1 'EXPAND TooltipEditPolicy::Main FOR model'
I don't know what I miss to include/import Utils extension file. Neither
don't know where it is.
If I understand well, the HEAD version in CVS of xpt files, use the newer
Xpand (QVTO) which do not use mwe file but rather ant, right ?
> Best,
> Rich
>> mplates-diagram).
>> repository ?
Re: Cannot find workflow for tooltip in solution directory [message #525146 is a reply to message #525144] Tue, 12 May 2009 08:20 Go to previous message
Right, what's in HEAD is a work in progress.
Replace the solution to the only tag version: v20081115-1515
After that, it should work for you.
On 5/12/09 8:11 AM, in article
b763386e0c4bbb84b37dc53c9b905de0$1@www.eclipse.org, "Jean Michel Boulcourt"
>> Best,
>> Rich
>>> mplates-diagram).
>>> repository ?
Rich
Re: Cannot find workflow for tooltip in solution directory [message #566237 is a reply to message #525142] Tue, 12 May 2009 06:31 Go to previous message
Best,
Rich
> mplates-diagram).
> repository ?
Re: Cannot find workflow for tooltip in solution directory [message #566263 is a reply to message #525143] Tue, 12 May 2009 08:11 Go to previous message
> Best,
> Rich
>> mplates-diagram).
>> repository ?
Re: Cannot find workflow for tooltip in solution directory [message #566307 is a reply to message #525144] Tue, 12 May 2009 08:20 Go to previous message
>> Best,
>> Rich
>>> mplates-diagram).
>>> repository ?
Rich
Previous Topic:Possible Erratum in creating tooltip.xmi
Next Topic:Possible Erratum in creating tooltip.xmi
Current Time: Wed Jul 23 08:45:23 EDT 2025
Powered by FUDForum. Page generated in 0.14031 seconds
