| Test goal with DbUnit plugin dependence [message #6775] |
Wed, 26 March 2008 14:17  |
Hi again,
I'm trying to execute my project through "Run as"-> JUnit, but the dbunit
plugin isn't called.
While executing it through "Maven 2"->Execute Goal, give me this error:
Errors during Maven execution
org.apache.maven.lifecycle.LifecycleExecutionException: Internal error in
the plugin manager executing goal
'org.codehaus.mojo:dbunit-maven-plugin:1.0-beta-1:operation' : Mojo
execution failed.
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeG oalAndHandleFailures(DefaultLifecycleExecutor.java:551)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeT askSegments(DefaultLifecycleExecutor.java:332)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute( DefaultLifecycleExecutor.java:149)
at org.apache.maven.DefaultMaven.execute_aroundBody0(DefaultMav en.java:223)
at
org.apache.maven.DefaultMaven.execute_aroundBody1$advice(Def aultMaven.java:304)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:1)
at
org.apache.maven.embedder.MavenEmbedder.execute_aroundBody4( MavenEmbedder.java:880)
at
org.apache.maven.embedder.MavenEmbedder.execute_aroundBody5$ advice(MavenEmbedder.java:304)
at org.apache.maven.embedder.MavenEmbedder.execute(MavenEmbedde r.java:1)
at
org.devzuz.q.maven.embedder.internal.EclipseMaven.executeReq uest(EclipseMaven.java:279)
at
org.devzuz.q.maven.embedder.internal.EclipseMavenRequest.run (EclipseMavenRequest.java:71)
Caused by: org.apache.maven.plugin.PluginExecutionException: Mojo
execution failed.
at
org.apache.maven.plugin.DefaultPluginManager.executeMojo(Def aultPluginManager.java:571)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeG oalAndHandleFailures(DefaultLifecycleExecutor.java:544)
... 11 more
Caused by: org.apache.maven.plugin.MojoExecutionException: Error executing
database operation: CLEAN_INSERT
at org.codehaus.mojo.dbunit.OperationMojo.execute(OperationMojo .java:110)
at
org.apache.maven.plugin.DefaultPluginManager.executeMojo(Def aultPluginManager.java:549)
... 12 more
Caused by: org.dbunit.dataset.NoSuchTableException: inventario_categoria
at
org.dbunit.database.DatabaseDataSet.getTableMetaData(Databas eDataSet.java:192)
at
org.dbunit.operation.DeleteAllOperation.execute(DeleteAllOpe ration.java:98)
at
org.dbunit.operation.CompositeOperation.execute(CompositeOpe ration.java:67)
at org.dbunit.ant.Operation.execute(Operation.java:183)
at org.codehaus.mojo.dbunit.OperationMojo.execute(OperationMojo .java:101)
... 13 more
Any limitation here?
Gilberto
| Re: Test goal with DbUnit plugin dependence [message #17442 is a reply to message #6810] |
Thu, 05 March 2009 15:17  |
Is there a way I can see the tests log like we see on eclipse console
while running "Run As -> JUnit Test"?
IAM only shows this:
5:05:31 PM BRT Starting Starting phaseExecution test
5:05:31 PM BRT Starting Starting mojoExecution surefire:test
5:05:31 PM BRT info Surefire report directory:
/home/gilberto/dev/eclipse-config/workspace/gfi/core/target/ surefire-reports
5:05:35 PM BRT Finished Finished mojoExecution surefire:test
5:05:35 PM BRT Finished Finished phaseExecution test
5:05:35 PM BRT Finished Finished projectExecution Financas e Inventario -
Core
task-segment: [clean, test]
5:05:35 PM BRT Finished Finished mavenExecution
5:05:35 PM BRT Finished Finished reactorExecution
Sometimes we need increase the log to find some problem!
Gilberto C. Andrade
Analista de Sistemas/DBA
www.secad.to.gov.br
www.jroller.com/gilbertoca
| Re: Test goal with DbUnit plugin dependence [message #565490 is a reply to message #6775] |
Thu, 27 March 2008 12:23  |
Running the tests from Run as - JUnit wont invoke Maven, so dbunit
plugin wont be called
When you run Maven you can see either in the stack trace or in the Maven
Events view the output from Maven. For what I see it fails to do a clean
insert because the table inventario_categoria doesnt exist
> executing database operation: CLEAN_INSERT
> at
> ... 12 more
> at
Gilberto wrote:
> Hi again,
> dbunit plugin isn't called.
> in the plugin manager executing goal
> execution failed.
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> execution failed.
> at
> at
> ... 11 more
> at
> ... 12 more
> at
> at
> at
> ... 13 more
> Gilberto
| Re: Test goal with DbUnit plugin dependence [message #565556 is a reply to message #6775] |
Thu, 27 March 2008 12:37  |
Hi Gilberto,
Run as > JUnit invokes the default JUnit support in Eclipse, so no maven
plug-ins are run.
> execution failed.
Seems like the table was not created.
There's no known limitation with dbunit, but we'd like to increase our
integration with *unit plugins (starting with Surefire,
http://tinyurl.com/36npkz).
Yours,
Abel.
| Re: Test goal with DbUnit plugin dependence [message #568465 is a reply to message #6810] |
Core
Gilberto C. Andrade
www.secad.to.gov.br
FUDForum. Page generated in 0.06025 seconds
