Home » Eclipse Projects » Eclipse 4 » XWT + DataBinding + TableViewer Issue
XWT + DataBinding + TableViewer Issue [message #499376] Sat, 21 November 2009 10:32 Go to next message
When using Databinding in XWT using an object ( Transaction.java ) I am
able to show the value of "price"
<Label text="Price:" />
<Label text="{Binding path=price}"/>
However, if I need to show the price in tableviewer
<TableViewer>
<TableViewer.columns>
<TableViewerColumn width="150" text="Price"
displayMemberPath="price" />
</TableViewer.columns>
<TableViewer.control.layoutData>
<GridData horizontalAlignment="FILL" verticalAlignment="FILL"
grabExcessVerticalSpace="true"
grabExcessHorizontalSpace="true" />
</TableViewer.control.layoutData>
</TableViewer>
The Data ( price ) is not rendered in the Table. Even the columns are not
shown.
I tried the following
1) XWT.load(parent, url, ( Transaction ) ( getT [ 0 ] ) ); => Shows up
correctly in Label but not in Table
2) XWT.load(parent, url, getT( ) ) ; => Doesnot show in Label ( correct
behaviour ? ) and does not show in Table
3) XWT.load(parent, url, getTinList ( ) ) ; => Here the object passed is a
List => similar behaviour as in 2).
I had tried even with
<TableViewer input="{Binding Path=transaction}">
Any help is much appreciated.
Best Regards,
Walter G. Prahakar.
Re: XWT + DataBinding + TableViewer Issue [message #499727 is a reply to message #499376] Mon, 23 November 2009 15:41 Go to previous messageGo to next message
Hi Walter,
It is about the "data context".
It expects the data context as an object (not a collection) with an
attribute "price".
As for TableViewer, it expects to have a collection to bind in ti "input".
In your code, the "input" specification is missing. If the data context is a
collection, you just need to indicate the input to use the data context like
this:
input="{Binding}"
If the data context of TableViewer is not a collection, you need to indicate
the collection viw path
input="{Binding path=orders}"
Regarding the table header, you need to add
<TableViewer.table headerVisible="true">
</TableViewer.table>
By defualt, it is false.
In general, I support you have a collection of Transaction. You want to
display the price when a transaction gets selected. It is the pure
Master/Detail presentation pattern. I suggest you llok at this example:
org.eclipse.e4.xwt.tests.jface.tableviewer.master.detail/Tab leViewer_MasterDetail.xwt:
The code is attached here. You can more examples in e4 CVS.
Yves YANG
"Walter Prabhakar" <kwchess@gmail.com> wrote in message
news:he916r$np$1@build.eclipse.org...
> <TableViewer>
> </TableViewer>
> not
> shown.
> a
> Best Regards,
> Walter G. Prahakar.
Re: XWT + DataBinding + TableViewer Issue [message #499728 is a reply to message #499727] Mon, 23 November 2009 15:44 Go to previous messageGo to next message
Sorry, somme correction of typo in my previous email
In general, I suppose you have a collection of Transaction. You want to
display the price when a transaction gets selected. It is a pure
Master/Detail presentation pattern. I suggest you look at this example:
The code is attached here. You can find more examples in e4 CVS.
"Yves YANG" <yves.yang@soyatec.com> wrote in message
news:hees2r$r1j$1@build.eclipse.org...
> Hi Walter,
> attribute "price".
> a collection, you just need to indicate the input to use the data context
> like this:
> input="{Binding}"
> indicate the collection viw path
> Regards
> Yves YANG
>> Hi,
>> <TableViewer>
>> </TableViewer>
>> not
>> shown.
>> correct
>> a
>> Thanks,
>> Best Regards,
>> Walter G. Prahakar.
Re: XWT + DataBinding + TableViewer Issue [message #499868 is a reply to message #499727] Tue, 24 November 2009 07:44 Go to previous messageGo to next message
Thanks Yves Yang. It works.
> Hi Walter,
> attribute "price".
> like this:
> input="{Binding}"
> Regards
> Yves YANG
>> Hi,
>> <TableViewer>
>> </TableViewer>
>> not
>> shown.
>> correct
>> a
>> Thanks,
>> Best Regards,
>> Walter G. Prahakar.
Re: XWT + DataBinding + TableViewer Issue [message #533703 is a reply to message #499868] Sat, 15 May 2010 15:23 Go to previous message
I have below code
label = (Label) XWT.load(parent, XWTLoader.class
.getResource("org/cord/client/dms/mainapp/ui/detailsViewer/ " + labelName ));
Now what happens, the getResource works fine in development environment, but when i try to export the project as product, getResource returns null
Can some body offer help
I too tired modifying build properties
Parvez Ahmad Hakim
Srinagar
Re: XWT + DataBinding + TableViewer Issue [message #565036 is a reply to message #499376] Mon, 23 November 2009 15:41 Go to previous message
Hi Walter,
attribute "price".
this:
input="{Binding}"
Yves YANG
> <TableViewer>
> </TableViewer>
> not
> shown.
> a
> Best Regards,
> Walter G. Prahakar.
Re: XWT + DataBinding + TableViewer Issue [message #565063 is a reply to message #499727] Mon, 23 November 2009 15:44 Go to previous message
> Hi Walter,
> attribute "price".
> like this:
> input="{Binding}"
> Regards
> Yves YANG
>> Hi,
>> <TableViewer>
>> </TableViewer>
>> not
>> shown.
>> correct
>> a
>> Thanks,
>> Best Regards,
>> Walter G. Prahakar.
Re: XWT + DataBinding + TableViewer Issue [message #565117 is a reply to message #499727] Tue, 24 November 2009 07:44 Go to previous message
> Hi Walter,
> attribute "price".
> like this:
> input="{Binding}"
> Regards
> Yves YANG
>> Hi,
>> <TableViewer>
>> </TableViewer>
>> not
>> shown.
>> correct
>> a
>> Thanks,
>> Best Regards,
>> Walter G. Prahakar.
Re: XWT + DataBinding + TableViewer Issue [message #576119 is a reply to message #499868] Sat, 15 May 2010 15:23 Go to previous message
I have below code
Parvez Ahmad Hakim
Srinagar
Previous Topic:Dynamically extending the workbench model
Next Topic:XWT not working in exports
Current Time: Wed Jul 23 09:29:04 EDT 2025
Powered by FUDForum. Page generated in 0.10838 seconds
