Home » Eclipse Projects » Memory Analyzer » Get Heap Dumps From Remote Server
icon5.gif  Get Heap Dumps From Remote Server [message #549720] Tue, 27 July 2010 12:51 Go to next message
HI friends
I am trying to get heap dumps from a remote server(WEBLOGIC)
Is it possible to do this with MAT plugin from eclipse??
if not can someone please suggest me some tool (other then VIsualVM and jmap)
Thanks in advance
Vamsy
Re: Get Heap Dumps From Remote Server [message #550112 is a reply to message #549720] Thu, 29 July 2010 03:54 Go to previous messageGo to next message
Hi Vamsy,
MAT can only trigger heap dumps from processes on the same box where the tool is running. Triggering dumps on a remote machine is not possible. Internally we also call jmap to get the dumps.
As for the question about a different tool - if you manage to connect remotely with jconsole you can use then one of the MBeans to dump the heap - com.sun.management / HotSpotDiagnostic, operations -> dumpHeap.
http://java.sun.com/javase/6/docs/technotes/guides/managemen t/jconsole.html
However, then you'll have to copy the dump to a place where MAT can open it on your own.
Hope this helps.
Krum
Re: Get Heap Dumps From Remote Server [message #558044 is a reply to message #550112] Thu, 09 September 2010 18:32 Go to previous messageGo to next message
Thanks for the help..
Re: Get Heap Dumps From Remote Server [message #565057 is a reply to message #549720] Thu, 29 July 2010 03:54 Go to previous messageGo to next message
Hi Vamsy,
Hope this helps.
Krum
Re: Get Heap Dumps From Remote Server [message #565234 is a reply to message #550112] Thu, 09 September 2010 18:32 Go to previous message
Previous Topic:ECLIPSE MAT FAILS TO OPEN DUMPS > 1.8 GB
Next Topic:memory allocation problem
Current Time: Sun Jul 20 23:12:31 EDT 2025
Powered by FUDForum. Page generated in 0.08090 seconds
