Crawler - Configuration and behavior [message #564749] |
Mon, 09 August 2010 11:39  |
i'm new to SMILA, it is an impressive tool, but unfortunatly also a bit tricky to understand ;)
At the moment I am trying to understand the behavior of a crawler and how to configure it. I understand the attributes i can gather and what a collected record would look like. What I dont get yet is where "under the hood" the actual crawling is done and what possibilties to change that i have without changing the actual implementation. For example, when crawling a website, can i configure the format of the content? Is content necessarily an attachment? Can I get the full HTML-code of a website as content or for instance just the text between certain tags, or only the text and no HTML-code at all?
Are there easy answers to those question or is there a more specific description to crawlers than whats in the wiki? Would you be interested in comments on the wiki, btw.?
Thanks in advance!
Andrej
Re: Crawler - Configuration and behavior [message #564787 is a reply to message #564749] |
Tue, 10 August 2010 03:46   |
Hi Andreij,
thanks for your interest in SMILA.
A crawlers main purpose is to provide data "as is" from a specific data source. In case of the WebCrawler it means that it starts the crawling on a given start URL (called Seed) and returns the resource specified by this URL. You also get access to the available information within the HTTP header of the webserver's response when sending the resource. So far this is standard HTTP functionality.
Further steps depend on the mime-type of the resource:
- if the resource is an HTML document the Crawler extracts all links to other resources (documents, images, etc.) and follows those links in regards to your configuration. In addition information provided in META tags is extracted (e.g. content encoding of the HTML document). The HTML document itself remains unmodified
- if the resource is not an HTML document no further steps are done
Within your Crawler configuration you can specify how to map the possible information provided for a crawled object to record attributes and/or attachments. Note that not all information may be available for every crawled object.
If you store the content as a record attribute or attachment depends on what you are crawling. If you know that you can only receive HTML documents it's ok to use an attribute. However, if you do not provide rules to filter everything else a Crawler run may also return images, PDFs and so on. For binary data you have to use an attachment.
What the Crawler does not provide is content extraction. So you cannot specify in the Crawler configuration to return only a specific part of the HTML, like a section, paragraph or page. Therefore you have to configure a BPEL pipeline that does the processing of the data provided by a Crawler. A BPEL pipeline gives you much more flexibility and control of what to do with the data, this would not be possible within the Crawler configuration. It also allows reuse, for example the processing of an HTML document may be identical whether it comes form a WebCrawler or FilesystemCrawler.
For more information about Crawlers and the configuration options check out the documentation in our wiki:
http://wiki.eclipse.org/SMILA/Documentation/ConnectivityFram ework
http://wiki.eclipse.org/SMILA/Documentation/Crawler
http://wiki.eclipse.org/SMILA/Documentation/Web_Crawler
I hope this helps!
Bye,
Daniel
Re: Crawler - Configuration and behavior [message #564850 is a reply to message #564841] |
Tue, 10 August 2010 05:06  |
Hi Andreij,
with "as is" I meant the unmodified content as sent by the webserver. In case of an HTML document it is the complete markup (html tags + text).
I don't think that there is an example on the wiki but take a look at the default pipelines that are shiped with SMILA ( SMILA.application\configuration\org.eclipse.smila.processing .bpel\pipelines). The addpipeline.bpel contains conditions that checkj if there is a mimetype attribute set and selects alternative processing for HTML/XML and plain text content. For HTNL/XML the HtmlToTextPipelet is called in order to extract the plain text from the content (removing all markup). I guess that this is the functionality you where looking for.
Bye,
Daniel
FUDForum. Page generated in 0.05016 seconds
