Home » Eclipse Projects » Nebula » ExtendedCellDialog
ExtendedCellDialog [message #56456] Mon, 21 July 2008 06:07 Go to next message
Hi all,
I've just discovered this technology and I was wondering if it was
possible with a cell to offer an extended cell dialog or if it was not
included at all in the widget.
Thanks in advance,
Aline
Re: ExtendedCellDialog [message #56537 is a reply to message #56456] Tue, 22 July 2008 10:26 Go to previous messageGo to next message
I forgot to add but I was talking about the CTableTree widget ^^!
I managed to have an extended dialog cell editor with the grid viewer
widget but i think I can't add a table in a row with this widget. And I
also wanted spanned cells, so that the second table will occupied an
entire row, and it seems that it is available only with the grid widget.
Is that right ?
I also noticed that a grid viewer is an instance of a viewer and the two
others are Composite. So, the cells are differently managed.
Is there a way to mix the three behaviors in a single table with Nebula ?
Thanks in advance,
Re: ExtendedCellDialog [message #57046 is a reply to message #56537] Mon, 04 August 2008 09:34 Go to previous message
I have no idea how CTableTree and CTable. Your summary is correct
GridTableViewer/GridTreeViewer and Grid-Widget are like
TableViewer/Table and TreeViewer/Tree in native SWT.
You can't mix them. You can show whichever widget you want in a
CellEditor but they have the limitation to only show one editor at a
time for a discussion what it is not a good idea to use native
components inside tables/trees please take a look at:
http://wiki.eclipse.org/index.php/Tables_And_Trees_And_Nativ eControls
Tom
Aline schrieb:
> Is that right ?
> Thanks in advance,
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: ExtendedCellDialog [message #591256 is a reply to message #56456] Tue, 22 July 2008 10:26 Go to previous message
Is that right ?
Thanks in advance,
Re: ExtendedCellDialog [message #591460 is a reply to message #56537] Mon, 04 August 2008 09:34 Go to previous message
Tom
Aline schrieb:
> Is that right ?
> Thanks in advance,
Previous Topic:FormattedText without DataBinding Clashes - Sample Code
Next Topic:Problems with accuracy of getBounds method in GridCellRenderer
Current Time: Fri Oct 31 21:03:33 EDT 2025
Powered by FUDForum. Page generated in 0.31145 seconds
