Home » Eclipse Projects » eRCP » eSWT -- MouseEvents
eSWT -- MouseEvents [message #564397] Tue, 09 March 2010 19:33 Go to next message
On S60 5th Edition eSWT SDK I want to know that if one is guarenteed that while services mouseevent another will not happen while I am servicing event?
For example;public class Fubar implements MouseListener, MouseEventListener {
private Point mouseLoc = new Point(-1,-1);
public void mouseDoubleClick(MouseEvent e){
public void mouseDown(MouseEvent e)
mouseLoc.x = e.x;
mouseLoc.y = e.y;
* do other processing:
* ANOTHER EVENT OCCUR AND CHANGE mouseLoc?
public void mouseUp(MouseEvent e)
* do other processing (maybe change mouseLoc):
public void mouseMove(MouseEvent e)
}Am I ok as long as another mouseevent is not invoked while i am in one because need to use value. I thought about locks but if I don't need why bother.
Re: eSWT -- MouseEvents [message #564607 is a reply to message #564397] Thu, 17 June 2010 09:10 Go to previous message
In eSWT all the UI access is limited to a single thread that is the UI thread. That means that all the listeners are also called on that same single thread. Since it is not possible for a thread to execute code pieces of code at the same time it is guaranteed that only a single event is serviced at a time.
Gorkem
Previous Topic:Display html-text in eSWT-Label
Next Topic:eSWT -- MouseEvents
Current Time: Fri Jul 18 21:03:55 EDT 2025
Powered by FUDForum. Page generated in 0.03106 seconds
