Home » Modeling » Epsilon » [Epsilon] Compare an enumeration value with a string in EVL
| [Epsilon] Compare an enumeration value with a string in EVL [message #8533] |
Mon, 12 January 2009 11:00  |
Hi!
I am still using EVL to validate UML (I say "still" becuase it has
passed a long time since my last question) and I have found something
wrong (or that I don't know how to do it).
The thing is that I tried to compare an enumeration value with a string,
because it was the first that came to my head, but didn't work. But I
never surrender, so I copied the check line and pasted it in the message
instrucction to watch what was returning my code, and to my surprise it
was indeed returning what I expected. However, the test failed. You'll
see what I mean with an example:
The constraint:
constraint isShared{
check: self.packagedElement.select(a: Association | a.name=
'Association1').first().ownedEnd.select(p: Property | p.name =
'dst').first().aggregation = 'shared'
message: 'The Associoation must have the field Aggregation = shared
and is ' + self.packagedElement.select(a: Association | a.name=
returns: 'The Associoation must have the field Aggregation = shared and
is shared
After confirming that there were no troubles with blank spaces next to
check were data types. And managed to compare them converting the
enumeration value into a string, through appending an string:
'dst').first().aggregation+'' = 'shared'
This workaround works fine, but I don't know if it is the best way to do
it. I tought you may want to know this.
Héctor Iturria
| Re: [Epsilon] Compare an enumeration value with a string in EVL [message #8565 is a reply to message #8533] |
Tue, 13 January 2009 05:17   |
Hi Hector,
The value of the .aggregation property is not a string; it is an
instance of class org.eclipse.uml2.uml.AggregationKind (you can see this
by doing a .aggregation.getClass().println()). To obtain the actual
string you should call .aggregation.literal . I've seen this before and
I think that it has to do with dynamic vs. generated EMF, but I have to
investigate more.
Dimitris
Héctor Iturria wrote:
> Hi!
> The constraint:
> shared and is ' + self.packagedElement.select(a: Association |
> a.name= 'Association1').first().ownedEnd.select(p: Property | p.name =
> is shared
> Best regards,
> Héctor Iturria
| Re: Compare an enumeration value with a string in EVL [message #8582 is a reply to message #8565] |
Tue, 13 January 2009 05:18  |
Forgot to mention that there is no reason to prefix messages with
[Epsilon] any more as this is a dedicated newsgroup.
Dimitris
Dimitrios Kolovos wrote:
> Hi Hector,
> investigate more.
> Cheers,
> Dimitris
>> Hi!
>> string, because it was the first that came to my head, but didn't
>> work. But I never surrender, so I copied the check line and pasted it
>> in the message instrucction to watch what was returning my code, and
>> to my surprise it was indeed returning what I expected. However, the
>> test failed. You'll see what I mean with an example:
>> The constraint:
>> Aggregation = shared and is ' + self.packagedElement.select(a:
>> Association | a.name= 'Association1').first().ownedEnd.select(p:
>> Property | p.name = 'dst').first().aggregation
>> and is shared
>> do it. I tought you may want to know this.
>> Best regards,
>> Héctor Iturria
| Re: [Epsilon] Compare an enumeration value with a string in EVL [message #563831 is a reply to message #8533] |
Hi Hector,
investigate more.
Dimitris
> Hi!
> The constraint:
> is shared
> Best regards,
> Héctor Iturria
| Re: Compare an enumeration value with a string in EVL [message #563855 is a reply to message #8565] |
Dimitris
> Hi Hector,
> investigate more.
> Cheers,
> Dimitris
>> Hi!
>> The constraint:
>> and is shared
>> Best regards,
>> Héctor Iturria
Current Time: Sat Nov 08 04:21:06 EST 2025
Powered by FUDForum. Page generated in 0.05568 seconds
