Home » Modeling » Epsilon » Loading multiple model instances, for translation
Loading multiple model instances, for translation [message #7007] Mon, 15 December 2008 06:27 Go to next message
I've so far been using ETL to transform a model A to model B (through
Ant). In general, the transformation needs to be applied to several source
models of A, to progressively build up the target model (which
accommodates this). I guess this is a common scenario, but am not sure of
the right way to do it.. Any ideas? I assumed I'd be able to perform
<epsilon.loadModel name="A" ... to load the first instance of A, then
perform the translation, and then <epsilon.loadModel name="A" ... again,
to load the second instance of A, perform translation, etc. However, this
approach only loads the first instance of A. Any help/pointers would be
very handy.
Ta,
Edd
Re: Loading multiple model instances, for translation [message #7034 is a reply to message #7007] Mon, 15 December 2008 07:28 Go to previous messageGo to next message
Hi Edd,
I suspected that a model.dispose between the two model.load would sort
thit out - but this doesn't seem to be the case. Could you please file a
bug against this? I'll start looking for a solution asap.
Dimitris
> source models of A, to progressively build up the target model (which
> of the right way to do it.. Any ideas? I assumed I'd be able to perform
> this approach only loads the first instance of A. Any help/pointers
> would be very handy.
> Ta,
> Edd
Re: Loading multiple model instances, for translation [message #7058 is a reply to message #7034] Mon, 15 December 2008 11:02 Go to previous messageGo to next message
Hi Edd,
I've fixed this problem and committed changes to the SVN. Are you using
Epsilon from source (SVN) or through the update site?
Dimitris
Dimitrios Kolovos wrote:
> Hi Edd,
> Cheers,
> Dimitris
>> perform <epsilon.loadModel name="A" ... to load the first instance of
>> A, then perform the translation, and then <epsilon.loadModel name="A"
>> ... again, to load the second instance of A, perform translation, etc.
>> However, this approach only loads the first instance of A. Any
>> help/pointers would be very handy.
>> Ta,
>> Edd
Re: Loading multiple model instances, for translation [message #7081 is a reply to message #7058] Mon, 15 December 2008 11:26 Go to previous messageGo to next message
Further to my previous email, to load a model with the same name, you'll
still need to first dispose the previous one e.g:
<epsilon.loadModel name="A" type="EMF">
</epsilon.loadModel>
<epsilon.disposeModel model="A"/>
Dimitris
> Hi Edd,
> Cheers,
> Dimitris
>> Hi Edd,
>> a bug against this? I'll start looking for a solution asap.
>> Cheers,
>> Dimitris
>>> sure of the right way to do it.. Any ideas? I assumed I'd be able to
>>> etc. However, this approach only loads the first instance of A. Any
>>> Ta,
>>> Edd
Re: Loading multiple model instances, for translation [message #7104 is a reply to message #7081] Mon, 15 December 2008 12:14 Go to previous messageGo to next message
Wow, that was quite a speedy fix :), haven't had time yet to submit a bug
report. Would you like me to do this still, for your records?
By the way, I've been using Epsilon via the update site. Should I use it
via the SVN (and if so are there some instructions on how to use it like
that) -- sorry, in meeting at mo...
Edd
Re: Loading multiple model instances, for translation [message #7127 is a reply to message #7104] Mon, 15 December 2008 13:31 Go to previous messageGo to next message
> bug report. Would you like me to do this still, for your records?
That'd be great!
No worries. Since waiting for the next version release is probably not
an option, you could either switch to the SVN version (see
http://www.eclipse.org/gmt/epsilon/doc/EpsilonSVN.pdf) or patch your
existing installation. To patch your installation you'd need to replace
\plugins\org.eclipse.epsilon.workflow_xxx\lib\org.eclipse.ep silon.workflow.jar
with the newer version available under
http://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.epsi lon/trunk/plugins/org.eclipse.epsilon.workflow/lib/
> Cheers,
> Edd
Dimitris
Re: Loading multiple model instances, for translation [message #7150 is a reply to message #7127] Wed, 17 December 2008 04:49 Go to previous message
Thanks a lot for filing
https://bugs.eclipse.org/bugs/show_bug.cgi?id=258912.
Dimitris
> That'd be great!
>> it via the SVN (and if so are there some instructions on how to use it
>> like that) -- sorry, in meeting at mo...
>> Cheers,
>> Edd
> Cheers,
> Dimitris
Re: Loading multiple model instances, for translation [message #563121 is a reply to message #7007] Mon, 15 December 2008 07:28 Go to previous message
Hi Edd,
Dimitris
> Ta,
> Edd
Re: Loading multiple model instances, for translation [message #563143 is a reply to message #7034] Mon, 15 December 2008 11:02 Go to previous message
Hi Edd,
Dimitris
> Hi Edd,
> Cheers,
> Dimitris
>> Ta,
>> Edd
Re: Loading multiple model instances, for translation [message #563171 is a reply to message #7058] Mon, 15 December 2008 11:26 Go to previous message
Dimitris
> Hi Edd,
> Cheers,
> Dimitris
>> Hi Edd,
>> Cheers,
>> Dimitris
>>> Ta,
>>> Edd
Re: Loading multiple model instances, for translation [message #563192 is a reply to message #7081] Mon, 15 December 2008 12:14 Go to previous message
Edd
Re: Loading multiple model instances, for translation [message #563217 is a reply to message #7104] Mon, 15 December 2008 13:31 Go to previous message
That'd be great!
> Cheers,
> Edd
Dimitris
Re: Loading multiple model instances, for translation [message #563242 is a reply to message #7127] Wed, 17 December 2008 04:49 Go to previous message
Dimitris
> That'd be great!
>> Cheers,
>> Edd
> Cheers,
> Dimitris
Previous Topic:Loading multiple model instances, for translation
Next Topic:@gmf not recognized - setup problem?
Current Time: Thu Nov 06 15:01:32 EST 2025
Powered by FUDForum. Page generated in 0.05197 seconds
