Home » Archived » GEF3D » Progress on update site?
Progress on update site? [message #479679] Tue, 11 August 2009 19:58 Go to next message
OK guys, I don't feel bad asking this as I'm going through the pain
myself right now. Do you expect to have an update site available
sometime in the near future? I can't include my 3D component until the
GEF3D component is available through an update site. Unless.. hmm, I
suppose I could just make the plugins available at my update site for
now..?
-Miles
(Eclipse AMP lead)
Re: Progress on update site? [message #479685 is a reply to message #479679] Tue, 11 August 2009 20:34 Go to previous messageGo to next message
> now..?
I'd probably get the GEF3D team to take advantage of Athena CBI for
their build...
http://wiki.eclipse.org/Common_Build_Infrastructure/Getting_ Started/Build_In_Eclipse
http://wiki.eclipse.org/Common_Build_Infrastructure/Getting_ Started/Build_In_Hudson
They can take advantage of the common build infrastructure at
Eclipse.org to build and publish GEF3D. It just takes a bit of time to
setup.
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
[OT] Re: Progress on update site? [message #479686 is a reply to message #479685] Tue, 11 August 2009 20:49 Go to previous messageGo to next message
Chris,
When did you last use this? I tried CBI early this year along with a
bunch of other stuff but the only thing that I was able to get working
in the end was the PDE Automated Build Process. It wasn't so bad
really, especially after the week or two I spent banging my head
against the wall on other alternatives.
So.. as I'm in a cruch to get my own udpate site up, can I ask.. if it
were you, and you had a very large set of projects with new namespaces,
organization, etc.., would you try to get your existing releng
converted, or would you just go with CBI. IOTW, is it really as easy as
that doc makes it sound? ;)
thanks,
Miles
>> now..?
> their build...
They
> can take advantage of the common build infrastructure at Eclipse.org to
> build and publish GEF3D. It just takes a bit of time to setup.
> Cheers,
Re: [OT] Re: Progress on update site? [message #479688 is a reply to message #479686] Tue, 11 August 2009 21:30 Go to previous messageGo to next message
Miles Parker wrote:
> Chris,
> in the end was the PDE Automated Build Process. It wasn't so bad really,
> especially after the week or two I spent banging my head against the
If you're an Eclipse project, I recommend using Athena because it works
pretty well. Once you get it working locally (wasn't that much of pain,
I had some issues with downloading files that caused some unzipping
errors which were related due to the integrity of the files... stupid
incomplete downloads), it's pretty easy to setup on the Athena build
server at Eclipse:
https://build.eclipse.org/hudson/view/Athena%20CBI/
In the end, you'll have a main build file for build.eclipse.org and a
local one for you based on your OS and all that good stuff. It took me
about half a day to get everything working.
Re: [OT] Re: Progress on update site? [message #479689 is a reply to message #479688] Tue, 11 August 2009 21:34 Go to previous messageGo to next message
Thanks Chris, this is extremely helpful and timely! It looks like a lot
of modeling projects are adopting it as well. If it works as advertised
this is exactly what's been needed.
On 2009-08-11 18:30:18 -0700, Chris Aniszczyk <zx@eclipsesource.com> said:
> Miles Parker wrote:
>> Chris,
> server at Eclipse:
> Cheers,
Re: Progress on update site? [message #479734 is a reply to message #479679] Wed, 12 August 2009 05:07 Go to previous messageGo to next message
Hi Miles,
actually I have the code ready to set up an update site, but I'm not
sure yet if setting up an update site confirms with Eclipse process (as
we do not have a release yet). Anyhow, we have a problem with LWJGL or
JOGL respectively. We need one of these libraries for OpenGL. LWJGL did
not get legally approved, thus we weren't able to put it into the
Eclipse orbit. We are currently waiting for JOGL do get approved. So,
the problem is that at the moment we have to refer to an external
update site (lwjgl.org). I have asked Chris about that, and I will
proceed as soon as I know how to do that according to the Eclipse
process.
Cheers
Jens
BTW: We have changed a lot of things in GEF3D in the last days, which
may have implications on client code (your code) as well. We will add a
posting here explaining the changes, and if you have any problems I
will be happy to help you.
> now..?
> -Miles
> (Eclipse AMP lead)
Re: Progress on update site? [message #479805 is a reply to message #479685] Wed, 12 August 2009 10:53 Go to previous messageGo to next message
Hi Chris,
thanks for the links. I tried to set up a releng project for GEF3D, but
I get an error message after downloading some necessary files (as
defined in build.properties, dependencyURLs):
[build] BUILD FAILED
[build]
/Users/jpilgrim/workspaces/org.eclipse.gef3d/org.eclipse.das h.common.releng/buildAll.xml:331:
The following error occurred while executing this line:
[build]
/Users/jpilgrim/workspaces/org.eclipse.gef3d/org.eclipse.das h.common.releng/buildAll.xml:368:
[build]
/Users/jpilgrim/workspaces/org.eclipse.gef3d/org.eclipse.das h.common.releng/tools/scripts/buildAllHelper.xml:574:
[build]
/Users/jpilgrim/workspaces/org.eclipse.gef3d/org.eclipse.das h.common.releng/tools/scripts/buildAllHelper.xml:851:
[build]
/Users/jpilgrim/workspaces/org.eclipse.gef3d/org.eclipse.das h.common.releng/build.xml:24:
[build]
/Users/jpilgrim/workspaces/org.eclipse.gef3d/org.eclipse.rel eng.basebuilder/plugins/org.eclipse.pde.build_3.5.0.v2009031 2-1500/scripts/build.xml:22:
[build]
/Users/jpilgrim/workspaces/org.eclipse.gef3d/org.eclipse.rel eng.basebuilder/plugins/org.eclipse.pde.build_3.5.0.v2009031 2-1500/scripts/build.xml:43:
[build]
/Users/jpilgrim/workspaces/org.eclipse.gef3d/org.eclipse.das h.common.releng/builder/all/customTargets.xml:68:
[build]
/Users/jpilgrim/workspaces/org.eclipse.gef3d/org.eclipse.das h.common.releng/tools/scripts/getDependencies.xml:17:
[build]
/Users/jpilgrim/workspaces/org.eclipse.gef3d/org.eclipse.das h.common.releng/tools/scripts/getDependenciesHelper.xml:16:
[build]
/Users/jpilgrim/workspaces/org.eclipse.gef3d/org.eclipse.das h.common.releng/tools/scripts/getDependenciesHelper.xml:81:
java.net.MalformedURLException: no protocol: ${eclipse.SDK.url}
[build] Total time: 2 seconds
Apparently, ${eclipse.SDK.url} isn't defined. I assume this is not the
right newsgroup to ask questions like this. Which mailinglist or
newsgroup can I ask instead? Would it help to check in my releng
project into GEF3D's svn, and you'd might have a look at it?
Cheers
Jens
Re: Progress on update site? [message #479885 is a reply to message #479734] Wed, 12 August 2009 17:48 Go to previous messageGo to next message
Hi Jens,
Thanks for the update. I think that is fine to use LWJGL during build
process, but you can't have it on Eclipse hosted VCS or deliver it in a
download of course. Then you can do like subversive does (hmmm.. I'm
not sure this is a compelling example!) and let people know they need
to add the additional update site. But I was just realizing that I'll
have the same issue for the AGF3D as I'll also need to refer to a
different website for that. If I can suggest you might have the
o.e.draw3d.lwjgl in a seperate feature so that people can get the rest
w/o the dependency though of course that prob. wouldn't be that useful..
Miles
On 2009-08-12 02:07:06 -0700, Jens v.P. <developer@jevopi.de> said:
> Hi Miles,
> process.
> Cheers
> Jens
>> now..?
>> -Miles
>> (Eclipse AMP lead)
Re: Progress on update site? [message #480110 is a reply to message #479805] Thu, 13 August 2009 17:00 Go to previous messageGo to next message
Yeah, I just got the same issue. I'll let you know if I find a solution.
On 2009-08-12 07:53:45 -0700, Jens v.P. <developer@jevopi.de> said:
> ipse.gef3d/org.eclipse.dash.common.releng/tools/scripts/getD ependenciesHelper.xml:16:
> [build]
> Cheers
> Jens
Re: Progress on update site? [message #480113 is a reply to message #479805] Thu, 13 August 2009 17:23 Go to previous message
Hey Jens,
I bet you're using OS X as well, huh? I looks like its something really
silly, actually. I rechecked my URL and remember that that OS X
download has that click-through notice? If I use the target of that
then instead, then I get to the next issue. :) I'll try to write up the
rest of the experience in my blog.
Miles
> Hi Chris,
> [build]
> [build]
> [build]
> [build]
> [build]
> [build]
> [build]
> [build]
> [build]
> [build]
> [build]
> Cheers
> Jens
Re: Progress on update site? [message #562701 is a reply to message #479679] Tue, 11 August 2009 20:34 Go to previous message
> now..?
their build...
setup.
[OT] Re: Progress on update site? [message #562720 is a reply to message #479685] Tue, 11 August 2009 20:49 Go to previous message
Chris,
thanks,
Miles
>> now..?
> their build...
They
> Cheers,
Re: [OT] Re: Progress on update site? [message #562748 is a reply to message #479686] Tue, 11 August 2009 21:30 Go to previous message
Miles Parker wrote:
> Chris,
server at Eclipse:
Re: [OT] Re: Progress on update site? [message #562771 is a reply to message #479688] Tue, 11 August 2009 21:34 Go to previous message
> Miles Parker wrote:
>> Chris,
> server at Eclipse:
> Cheers,
Re: Progress on update site? [message #562794 is a reply to message #479679] Wed, 12 August 2009 05:07 Go to previous message
Hi Miles,
process.
Cheers
Jens
> now..?
> -Miles
> (Eclipse AMP lead)
Re: Progress on update site? [message #562807 is a reply to message #479685] Wed, 12 August 2009 10:53 Go to previous message
Hi Chris,
[build]
[build]
[build]
[build]
[build]
[build]
[build]
[build]
[build]
[build]
[build]
Cheers
Jens
Re: Progress on update site? [message #562831 is a reply to message #479734] Wed, 12 August 2009 17:48 Go to previous message
Hi Jens,
Miles
> Hi Miles,
> process.
> Cheers
> Jens
>> now..?
>> -Miles
>> (Eclipse AMP lead)
Re: Progress on update site? [message #562855 is a reply to message #479805] Thu, 13 August 2009 17:00 Go to previous message
> [build]
> Cheers
> Jens
Re: Progress on update site? [message #562880 is a reply to message #479805] Thu, 13 August 2009 17:23 Go to previous message
Hey Jens,
Miles
> Hi Chris,
> [build]
> [build]
> [build]
> [build]
> [build]
> [build]
> [build]
> [build]
> [build]
> [build]
> [build]
> Cheers
> Jens
Previous Topic:Progress on update site?
Next Topic:Changes in GEF3D API
Current Time: Sat Jul 26 13:01:07 EDT 2025
Powered by FUDForum. Page generated in 0.07657 seconds
