Home » Archived » ATF » I must install ATF with file copy
I must install ATF with file copy [message #562617] Sun, 31 January 2010 23:19 Go to next message
Thank you for your help in Bugzira.
Of course, I already succeeded in the installation of ATF in accordance with your installation guide.
However, now, I must install ATF not with network installation but with file copy.
Therefore, I would be very happy if you would send me file lists including files of Xule necessary for ATF installation
at your earliest convenience.
Re: I must install ATF with file copy [message #562703 is a reply to message #562617] Sat, 06 February 2010 10:21 Go to previous messageGo to next message
Hello
I would like to specifically explain the situation regarding the question dated 31 January 2010.
I am the member of a team for making a system that helps integrators in developing business applications quickly.
In the system to be made, we want to use ATF as the test tool.
We need to build our original plug-in together with files necessary for ATF (Xule etc).
We cannot apply "network install" to our system. So, we need the file list for ATF.
Further, if there are other processes for installing ATF, please inform the same to us.
I hate to bother you, but please send me your reply as soon as possible.
Re: I must install ATF with file copy [message #562721 is a reply to message #562703] Mon, 08 February 2010 03:34 Go to previous message
hi,
you will need XULRunner plug-ins as described on following ATF wiki
page: http://wiki.eclipse.org/ATF/Installing
Additionally, if you use WTP you might want to include org.eclipse.atf
feature, which includes integration with WTP.
Otherwise I'd suggest to use only org.eclipse.atf.mozilla.ide feature,
which does not depend on WTP.
The only question is, how are you going to build your tool. Personally I
would use P2 mirror tool to make a copy of XULRunner and ATF update
sites, merge them into single P2 repository and distribute internally.
Later on your users could install ATF by pointing P2 Update Manager to
the zipped P2 repository.
Let me know if you have any concerns.
Jacek
for_rak@ytv.home.ne.jp wrote:
> Hello
> for ATF (Xule etc).
> list for ATF.
Previous Topic:Browser proxy configuration
Next Topic:I must install ATF with file copy
Current Time: Sat Jul 26 03:21:23 EDT 2025
Powered by FUDForum. Page generated in 0.03844 seconds
