Home » Eclipse Projects » Spatiotemporal Epidemiological Modeler (STEM) » Web interface?
Web interface? [message #562680] Fri, 19 March 2010 10:16 Go to next message
I downloaded and have been getting familiar with creating diseases/infectors/inoculators/models/scenarios/triggers/... I am interested in integrating STEM into a web project - are existing projects/plugins working in that area?
At first I would like to just allow users to be able to run scenarios on a remote server through a web interface, and eventually would like to expose portions of the UI to allow them to modify runs by adding modifiers/triggers/inoculators...
I don't want to repeat effort so if there are existing projects, or anyone could point to where would be the best place to hook into STEM, I'd appreciate it. I am grabbing the source at the moment. Even a command-line execution format to pick the scenario to run would be a useful start, but I couldn't find any info about a command line execution.
Doug
Re: Web interface? [message #562706 is a reply to message #562680] Fri, 19 March 2010 12:17 Go to previous messageGo to next message
Hi Doug,
We have some internal work on a Web-based STEM interface, but it's not really in a condition for public release at this time. It's really more of a proof-of-concept/what we can do. Right now, it's just a collection of JSON-generating servlets with a Dojo interface and visualizer built with Google Maps. Simulation controls are mainly related to state (start, stop, etc). The underlying container is running Jetty as an Eclipse plug-in. See: http://www.eclipse.org/equinox/server/
As for the hooks to control STEM through an API, my recommendation is that you start by looking at the SimulationManager and Simulation classes in in the org.eclipse.stem.jobs plug-in.
To initialize and run a headless simulation, pulling from our Web code, here's a very simple set of steps. Obviously any real system will be more advanced, but this is a basic startup. Note that the project name and scenario name correspond to projects and scenarios you created using the STEM UI.
import org.eclipse.emf.common.util.URI;
import org.eclipse.stem.core.Utility;
import org.eclipse.stem.core.scenario.Scenario;
import org.eclipse.stem.jobs.simulation.SimulationManager;
import org.eclipse.stem.jobs.simulation.ISimulation;
import org.eclipse.stem.jobs.simulation.Simulation;
String projectName = "somestemproject";
String scenarioName = "somescenarioname.scenario";
// Get the internal URI to the Scenario resource file in the workspace
URI scenarioUri = URI.createURI("platform:/resource/"+ projectName +"/scenarios/"+ scenarioName);
// Load the scenario from file
Scenario scenario = (Scenario)Utility.getIdentifiable(scenarioUri);
// Get the simulation manager
SimulationManager mgr = SimulationManager.getManager();
// Create a runnable simulation from the given scenario
ISimulation sim = mgr.createSimulation(scenario);
// Run the simulation
mgr.runSimulation(sim);
Re: Web interface? [message #562729 is a reply to message #562706] Mon, 22 March 2010 07:45 Go to previous messageGo to next message
Thanks for the pointers!
Re: Web interface? [message #562964 is a reply to message #562729] Tue, 30 March 2010 09:51 Go to previous messageGo to next message
By the way, is there any planned timeframe for when pieces of the web interface will be available?
Re: Web interface? [message #563107 is a reply to message #562706] Tue, 06 April 2010 17:41 Go to previous message
I am still having trouble with this... I have what are probably lots of very basic questions. I have very limited time available to try to learn Eclipse and STEM, so perhaps this just isn't going to work out right now.
To simplify, I dropped the web app part for now and just want to create a standalone, command line version of STEM where parameters can be passed to specify the scenario, for example. I started with the code from Matt above, but swapped the last 4 lines for:
// Create a runnable simulation from the given scenario and run it
mgr.createAndRunSimulation(scenario);
(the version above was causing errors, but I don't recall what off the top of my head)
I assume I want to develop my command line driver as a plug-in, then set up a product configuration to export it as a standalone Eclipse application (I still can't seem to get that working for STEM itself, per http://www.eclipse.org/forums/index.php?t=msg&th=165083& amp;start=0&).
I have scenarios created from the version of STEM I downloaded, but can't seem to load them. Where would I need to copy/import/??? my "US-Flu" project in order to load its "test.scenario"?
If I run as a Java application, my working directory = C:\Documents and Settings\drafalsk\workspace\headlessSTEM, and
scenarioUri.toString() = platform:/resource/US-Flu/scenarios/test.scenario
scenarioUri.toFileString() = null
The code
Then fails withQuote:
> The serialized instance of an Identifiable at "platform:/resource/USFlu/scenarios/test.scenario" was not found or was of the wrong format
Previous Topic:Japanese STEM tutorial now available on YouTube
Next Topic:Build from Source Qs
Current Time: Sun Jul 20 22:42:43 EDT 2025
Powered by FUDForum. Page generated in 0.05495 seconds
