Home » Archived » GEF3D » Some refactoring, standalone draw3d viewers.
| Some refactoring, standalone draw3d viewers. [message #3884] |
Tue, 02 June 2009 19:13  |
Hi everyone,
just a quick pointer that I have refactored some gef3d and draw3d code.
I have created a new plugin called org.eclipse.draw3d.ui, which you
need to check out (from eclipse.org) in order to compile everything the
next time you update (if you are using SVN Head).
This was neccessary in order to support standalone draw3d viewers with
a working camera without duplicating lots of code. I will check in
another project containing the base classes and an example
implementation of such a viewer soon.
I hope I haven't broken anything - it seems to work fine on my system.
Miles: I will work on shapes after I finished the draw3d viewer. I will
add cones and cylinders first. Is there anything in particular that you
need?
Oh, and I have implemented the 3.5 Graphics methods, but will not
commit this until 3.5 is out. If you need patches against current SVN
for this, let me know.
Best regards
Kristian
| Re: Some refactoring, standalone draw3d viewers. [message #4422 is a reply to message #3884] |
Tue, 02 June 2009 21:04   |
On 2009-06-02 16:13:02 -0700, Kristian Duske
<kristian.duske@fernuni-hagen.de> said:
> Hi everyone,
Nice.. The whole IEditPart vs. IViewPart thing is really a relic at
this point. I find views to be much more suitable for a lot of stuff.
I just wrote one as well, but it's tied into all of the AGF pieces.
Found it really simple to do though. Unfortuntaly I don't have my CQs
for initial contributions in yet so I can't point to the code. But see
below..
For camera all I needed was to
CameraTool camera = new CameraTool();
getEditDomain().setActiveTool(camera);
> need?
Thanks for asking. :)
One thing that I'd like though I don't know if it would be useful for
anyone else is the ability to supply a 2D figure and then either rotate
it or
The obvious hacks are working just fine.. I'm away for a week or so, btw..
package org.eclipse.amp.agf3d;
import org.eclipse.amp.agf.gef.EditPartListener;
import org.eclipse.amp.agf.gef.EditPartViewPart;
import org.eclipse.amp.axf.view.IModelPart;
import org.eclipse.gef.EditPartViewer;
import org.eclipse.gef.RootEditPart;
import org.eclipse.gef3d.preferences.ScenePreferenceListener;
import org.eclipse.gef3d.tools.CameraTool;
import org.eclipse.gef3d.ui.parts.GraphicalViewer3DImpl;
import org.eclipse.gef3d.ui.parts.IScene;
import org.eclipse.swt.widgets.Composite;
public class GEF3DViewPart extends EditPartViewPart {
* The preference listener for this editor.
protected ScenePreferenceListener sceneListener;
public void createPartControl(Composite parent) {
super.createPartControl(parent);
parent.addDisposeListener(((GraphicalViewer3DImpl)
viewer).getLightweightSystem3D());
if (viewer instanceof IScene) {
sceneListener = new ScenePreferenceListener((IScene) viewer);
sceneListener.start();
EditPartListener rootListener;
public void createModelListeners() {
if (viewer.getContents() instanceof IModelPart) {
((IModelPart) viewer.getContents()).createModelListeners();
protected void createZoomer(RootEditPart rootEditPart) {
protected EditPartViewer createViewer() {
return new GraphicalViewer3DImpl();
* {@inheritDoc}
* @see org.eclipse.gef.ui.parts.GraphicalEditor#dispose()
public void dispose() {
if (sceneListener != null) {
sceneListener.stop();
super.dispose();
[Note for below ModelViewPart can be ignored -- it does some AGF stuff
and extends ViewPart implements IPropertyChangeListener.]
* <copyright>
* Copyright (c) 2009 Metascape, LLC.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Metascape - Initial API and Implementation
* </copyright>
package org.eclipse.amp.agf.gef;
import java.util.Collections;
import java.util.List;
import org.eclipse.amp.axf.view.ModelViewPart;
import org.eclipse.draw2d.IFigure;
import org.eclipse.gef.DefaultEditDomain;
import org.eclipse.gef.EditPart;
import org.eclipse.gef.GraphicalEditPart;
import org.eclipse.gef.editparts.ScalableFreeformRootEditPart;
import org.eclipse.gef.editparts.ZoomManager;
import org.eclipse.gef.ui.parts.ScrollingGraphicalViewer;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.ISelectionChangedListener;
import org.eclipse.jface.viewers.ISelectionProvider;
import org.eclipse.jface.viewers.SelectionChangedEvent;
import org.eclipse.jface.viewers.StructuredSelection;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.IWorkbenchPart;
public abstract class EditPartViewPart extends ModelViewPart {
private final class PropertySelectionListener implements
ISelectionChangedListener {
public void selectionChanged(SelectionChangedEvent event) {
if (!event.getSelection().isEmpty() && event.getSelection()
instanceof StructuredSelection) {
StructuredSelection sel = (StructuredSelection)
event.getSelection();
propertySheetPage.selectionChanged(EditPartViewPart.this, new
StructuredSelection(sel
.getFirstElement()));
private DefaultEditDomain editDomain;
protected EditPartViewer viewer;
private EditPartListener rootListener;
public static double[] ZOOM_LEVELS = { .125, .25, .5, .75, 1.0,
1.25, 1.5, 2.0, 2.5, 3, 4, 6, 8 };
private ZoomManager zoomer;
private PropertySelectionListener selectionListener;
public EditPartViewPart() {
super();
setEditDomain(new DefaultEditDomain(null));
viewer = createViewer();
viewer.createControl(parent);
getEditDomain().addViewer(viewer);
createSelectionListener(viewer);
protected void createSelectionListener(ISelectionProvider provider) {
super.createSelectionListener(provider);
selectionListener = new PropertySelectionListener();
provider.addSelectionChangedListener(selectionListener);
return new ScrollingGraphicalViewer();
public void setInput(IEditorInput input) {
super.setInput(input);
final ModelEditPartInput mInput = (ModelEditPartInput) input;
// setPartName(getName());
if (input != null) {
RootEditPart rootEditPart = mInput.getRootEditPart();
if (rootEditPart != null) {
viewer.setRootEditPart(rootEditPart);
createZoomer(rootEditPart);
viewer.setEditPartFactory(mInput.getFactory());
viewer.setContents(getModel());
} else {
// viewer.setContents(null);
if (rootEditPart instanceof ScalableFreeformRootEditPart) {
zoomer = ((ScalableFreeformRootEditPart)
rootEditPart).getZoomManager();
zoomer.setZoomLevels(ZOOM_LEVELS);
zoomer.setZoomLevelContributions(Collections.singletonList(Z oomManager.FIT_ALL));
super.createModelListeners();
rootListener = new EditPartListener(viewer.getControl(),
getEditPart());
rootListener.setWaitForPaint(false);
addModelListener(rootListener);
viewer.getControl().addPaintListener(new PaintListener() {
public void paintControl(PaintEvent e) {
rootListener.endPainting();
public EditPart getEditPart() {
List children = viewer.getRootEditPart().getChildren();
if (children.size() > 0) {
return (EditPart) children.get(0);
return null;
public Object getAdapter(Class type) {
if (type == ISelectionProvider.class) {
return getViewer();
if (type == EditPartViewer.class) {
return getViewer();
// TODO -- this should really be the child..
if (type == EditPart.class && getViewer() != null) {
return getViewer().getRootEditPart();
if (type == IFigure.class && getViewer() != null) {
return ((GraphicalEditPart)
getViewer().getRootEditPart()).getFigure();
if (type == ZoomManager.class) {
return getZoomer();
return super.getAdapter(type);
public EditPartViewer getViewer() {
return viewer;
public EditPartListener getRootListener() {
return rootListener;
* Sets the EditDomain for this EditorPart.
* @param ed
* the domain
protected void setEditDomain(DefaultEditDomain ed) {
this.editDomain = ed;
public void selectionChanged(IWorkbenchPart part, ISelection selection) {
super.dispose();
removeSelectionListener(viewer);
((ISelectionProvider)
viewer).removeSelectionChangedListener(selectionListener);
* Returns the edit domain.
* @return the edit domain
protected DefaultEditDomain getEditDomain() {
return editDomain;
public ZoomManager getZoomer() {
return zoomer;
| Re: Some refactoring, standalone draw3d viewers. [message #4698 is a reply to message #4630] |
Wed, 03 June 2009 06:09  |
> I would expect a new plugin called org.eclipse.draw3d.examples for that
> purpose? You could move my viewer part demo from the gef3 examples to
> that new plugin (or remove it, if it is only a duplicate).
No, the viewer base class should go into draw3d.ui I think. It's not an
example, but a base class that everyone can use to implement their
viewer.
> ehe... Although I'm not Miles I would like to vote for spheres :-D
Okay!
Kristian
| Re: Some refactoring, standalone draw3d viewers. [message #561955 is a reply to message #3884] |
> Hi everyone,
below..
> need?
it or
* {@inheritDoc}
super.dispose();
* <copyright>
* Contributors:
* </copyright>
super();
} else {
getEditPart());
return null;
return getViewer();
return getViewer();
return getZoomer();
return viewer;
* @param ed
* the domain
super.dispose();
return editDomain;
return zoomer;
| Re: Some refactoring, standalone draw3d viewers. [message #561972 is a reply to message #4422] |
Tue, 02 June 2009 21:13  |
>> need?
> it or
I forgot to finish my sentance!
...just place it on an x, y or z oriented plane. Of course we already
have Z :) But this would allow the simple creation of "cutouts".
As far as actual shapes go, for now I'm just using the LGWL primitives
which works but as the render context isn't passed in and based on your
previous comments that won't be a good solution for future.
It seems that spheres are expensive in 3D graphics! Hemispheres would
be really useful as well and regular polyhedra.
| Re: Some refactoring, standalone draw3d viewers. [message #562010 is a reply to message #3884] |
Wed, 03 June 2009 05:37  |
Hi Kristian,
On 2009-06-03 01:13:02 +0200, Kristian Duske
> need?
Hehe... Although I'm not Miles I would like to vote for spheres :-D
Cheers
Jens
| Re: Some refactoring, standalone draw3d viewers. [message #562031 is a reply to message #4630] |
viewer.
Okay!
Kristian
Current Time: Thu Nov 06 17:27:02 EST 2025
Powered by FUDForum. Page generated in 0.05809 seconds
