Eclipse plug-in: Invalid Activator [message #561390] |
Thu, 27 September 2007 10:34 |
Originally posted by: slider161.hotmail.com
I am writing an Ant script to run a JUnit test suite within an Eclipse
plug-in and generate a JUnit report outside of Eclipse. I am referring to
this tutorial http://dev.eclipse.org/viewcvs/index.cg ... ision=1.4. I
have written a test.xml file for my plug-in
which uses the org.eclipse.test library.xml file run the suite and
generate a report.
I am getting an error "org.osgi.framework.BundleException: The activator
com.propylon.core.tests.Activator for bundle com.propylon.core.Test is
invalid"
I have checked that all the require plug-ins are loaded in eclipse.
The Activator class autmatically generated when i created the plug-in,
yet it seems ok.
the manifest file seem to be correct.
Are there any other common causes for this error, and what are they?
Below is my Activator class.
Code:
package com.propylon.core.tests;
import org.eclipse.ui.plugin.AbstractUIPlugin;
import org.osgi.framework.BundleContext;
* The activator class controls the plug-in life cycle
public class Activator extends AbstractUIPlugin {
// The plug-in ID
public static final String PLUGIN_ID = "com.propylon.core.tests";
// The shared instance
private static Activator plugin;
* The constructor
public Activator() {
* (non-Javadoc)
* @see
org.eclipse.ui.plugin.AbstractUIPlugin#start(org.osgi.framew ork.BundleContext)
public void start(BundleContext context) throws Exception {
super.start(context);
plugin = this;
* (non-Javadoc)
* @see
org.eclipse.ui.plugin.AbstractUIPlugin#stop(org.osgi.framewo rk.BundleContext)
public void stop(BundleContext context) throws Exception {
plugin = null;
super.stop(context);
* Returns the shared instance
* @return the shared instance
public static Activator getDefault() {
return plugin;
Below is the Manifest file
Code:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: TestsPlug-in
Bundle-SymbolicName: com.propylon.core.Test;singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: com.propylon.core.tests.Activator
Bundle-Vendor: PROPYLON
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
com.propylon.core.repository,
org.eclipse.core.resources,
org.tmatesoft.svnkit,
org.eclipse.ui.navigator,
org.junit
Eclipse-LazyStart: true
Bundle-ClassPath: junit.plugin.jar,
Export-Package: com,
com.propylon,
com.propylon.core,
com.propylon.core.tests,
com.propylon.core.tests.testcase,
com.propylon.core.tests.testsuite,
org.eclipse.tptp.test.tools.junit.plugin.internal;x-internal :=true,
org.eclipse.tptp.test.tools.junit.plugin.internal.harness;x- internal:=true,
org.eclipse.tptp.test.tools.junit.plugin.internal.launch;x-i nternal:=true,
org.eclipse.tptp.test.tools.junit.plugin.internal.modelsync; x-internal:=true,
org.eclipse.tptp.test.tools.junit.plugin.internal.resources; x-internal:=true,
org.eclipse.tptp.test.tools.junit.plugin.internal.util;x-int ernal:=true,
org.eclipse.tptp.test.tools.junit.plugin.util
Are there any obvious flawes with my code that my be causing the problem?
thank you for your time.
slider
P.S. I am new to this newsgroup, and apologise if this post is in the
wrong forum.
FUDForum. Page generated in 0.23679 seconds
