| Home » Language IDEs » AspectJ » ClassFormatError
 Goto Forum:|
| ClassFormatError [message #56104] | Mon, 29 August 2005 12:26  |  |
| Eclipse User  |  |  |  |  | Originally posted by: schulz78.gmx.net
 I am using AJDT 1.3 (20050729161227) with Eclipse 3.1 in a multiproject
 setup. One plugin defines aspects that are woven into the class files
 produced when compiling other plugins. The projects are linked via the
 aspectpath option. Classes within the aspect-defining plugin are woven
 correctly. However, when the aspects are applied to the classes of
 another plugin things go wrong. When I start up my application the VM
 moans about classes with duplicate interfaces (ClassFormatError).
 Decompiling my classes with JAD unveils that in fact classes are defined
 to implement one and the same interface twice. Furthermore fields are
 generated twice, which would produce an error too, if the verification
 wouldn't stumble across the duplicate interface. I guess that the class
 is woven twice, but I don't know why? It might be a bug, too! I'm using
 annotation style aspects.
 Here is a woven decompiled sample class:
 Original:
 @Managed
 public class Test {
 public Test() {
 Woven (decompiled):
 public class Test
 implements de.cohesion.lmf.ManagementAspect.ajcMightHaveAspect,
 public Test()
 JoinPoint joinpoint = Factory.makeJP(ajc$tjp_0, this, this);
 ManagementAspect.ajc$perObjectBind(this);
 init$_aroundBody1$advice(this, joinpoint,
 CallstackAspect.aspectOf(), this, null, joinpoint);
 public ManagementAspect
 ajc$de_cohesion_lmf_ManagementAspect$perObjectGet()
 return ajc$de_cohesion_lmf_ManagementAspect$perObjectField;
 public void
 ajc$de_cohesion_lmf_ManagementAspect$perObjectSet(Management Aspect
 managementaspect)
 ajc$de_cohesion_lmf_ManagementAspect$perObjectField =
 managementaspect;
 private static final void init$_aroundBody0(Test test, JoinPoint
 joinpoint)
 if(ManagementAspect.hasAspect(test))
 ManagementAspect.aspectOf(test).ajc$before$de_cohesion_lmf_M anagementAspect$1$2e8d3d(test);
 private static final Object
 init$_aroundBody1$advice(CallstackAspect this, Object o, AroundClosure
 ajc_aroundClosure, JoinPoint thisJoinPoint, Stack stack, JoinPoint
 joinpoint)
 Stack stack1;
 stack1 =
 (Stack)CallstackAspect.ajc$inlineAccessFieldGet$de_cohesion_ lmf_trace_CallstackAspect$de_cohesion_lmf_trace_CallstackAsp ect$stacks(ajc_aroundClosure).get();
 stack1.push(new Invocation(thisJoinPoint,
 JoinPoints.getConstructor(joinpoint), joinpoint.getArgs()));
 Object obj;
 Stack stack2 = stack;
 JoinPoint joinpoint1 = thisJoinPoint;
 init$_aroundBody0((Test)joinpoint1, ((JoinPoint) (o)));
 obj = null;
 stack1.pop();
 return obj;
 Exception exception;
 exception;
 stack1.pop();
 throw exception;
 public void
 managementaspect)
 managementaspect;
 private transient ManagementAspect
 private static final org.aspectj.lang.JoinPoint.StaticPart ajc$tjp_0;
 static
 Factory factory = new Factory("Test.java",
 Class.forName("de.cohesion.test.Test"));
 ajc$tjp_0 = factory.makeSJP("constructor-execution",
 factory.makeConstructorSig("1--de.cohesion.test.Test----"), 31);
| Re: ClassFormatError [message #56301 is a reply to message #56132] | Tue, 30 August 2005 14:47   |  |
 Adrian Colyer wrote:
 >> multiproject setup. One plugin defines aspects that are woven into the
 >> class files produced when compiling other plugins. The projects are
 >> linked via the aspectpath option. Classes within the aspect-defining
 >> plugin are woven correctly. However, when the aspects are applied to
 >> the classes of another plugin things go wrong. When I start up my
 >> application the VM moans about classes with duplicate interfaces
 >> (ClassFormatError). Decompiling my classes with JAD unveils that in
 >> fact classes are defined to implement one and the same interface
 >> twice. Furthermore fields are generated twice, which would produce an
 >> error too, if the verification wouldn't stumble across the duplicate
 >> interface. I guess that the class is woven twice, but I don't know
 >> why? It might be a bug, too! I'm using annotation style aspects.
 > I'm suspicious of some kind of incremental compilation bug here. Do
 > things get better if you do a "clean" of the workspace (project menu)?
 > Regardless, this is definitely a bug of some kind so please raise a
 > bugzilla report. Anything you can do to narrow down the set of
 > circumstances needed to reproduce the bug would be much appreciated.
 > Thanks, Adrian.
 Hi Adrian,
 doing a clean rebuild is of no success. Even deactivating incremental
 compilation does not change anything. Currently I have no spare time to
 raise a bug or even narrow done the context.
 However, for all of those experiencing the same problem, there's a
 workaround. Just use the inpath feature instead of the aspectpath.
 By the way, changing to a up-to-date developer build is of no help
 either, since then compilation fails at all, stating some problem with
 undeclared in a generic class. No clue, what the hell is causing this.
 Thanks, Sven
| Re: ClassFormatError [message #56361 is a reply to message #56301] | Wed, 31 August 2005 15:02  |  |
| Eclipse User  |  |  |  |  | Originally posted by: adrian_colyer.uk.ibm.com
 > Thanks, Sven
 I fixed a couple of bugs raised in the last few days that were causing
 messages about "undeclared type variables" when trying to parse the
 generic signature of generic and parameterized types, so hopefully that
 error you saw will be fixed in the latest builds of AspectJ. I'll keep
 my eye out for any problem like the one you were seeing before and run
 some basic tests to try and reproduce it. If you do ever get the chance
 to narrow it down any, just jot the details down in a bug report please.
 Thanks, Adrian.
| Re: ClassFormatError [message #589926 is a reply to message #56104] | Tue, 30 August 2005 12:22  |  |
| Eclipse User  |  |  |  |  | Sven Schulz wrote: > I am using AJDT 1.3 (20050729161227) with Eclipse 3.1 in a multiproject
 Thanks, Adrian.
| Re: ClassFormatError [message #589945 is a reply to message #56132] | Tue, 30 August 2005 14:47  |  |
 > Thanks, Adrian.
 Hi Adrian,
 Thanks, Sven
| Re: ClassFormatError [message #589975 is a reply to message #56301] | Wed, 31 August 2005 15:02  |  |
 > Thanks, Sven
 Thanks, Adrian.
 Current Time: Thu Oct 30 22:38:03 EDT 2025
 Powered by FUDForum . Page generated in 0.03978 seconds |
