Home » Archived » BIRT » PDF rendering issue(PDF rendering is not proper)
PDF rendering issue [message #560112] Tue, 21 September 2010 05:05 Go to next message
Hi ,
While rendering PDF which has multiple pages,font size is changing in some pages. Can you please let us know the problem
Here i am sending the code for setting options ....
PDFRenderOption pdfOptions = new PDFRenderOption();
pdfOptions.setOutputFileName(outputFilePath);
pdfOptions.setSupportedImageFormats("JPG;PNG;BMP;SVG");
pdfOptions.setOutputFormat(OmegaConstants.PDF_EXT_STR);
pdfOptions.setOption(PDFRenderOption.FIT_TO_PAGE,Boolean.TRU E);
pdfOptions.setOption(PDFRenderOption.PAGEBREAK_PAGINATION_ON LY,Boolean.FALSE);
Please let us know any property we have missed
Thanks & Regards,
Laxmipathi Raju
Re: PDF rendering issue [message #560213 is a reply to message #560112] Tue, 21 September 2010 11:08 Go to previous messageGo to next message
Are you sure you are not changing style properties in the report?
BTW I do not know what OmegaConstants is.
Jason
Re: PDF rendering issue [message #624763 is a reply to message #560213] Wed, 22 September 2010 01:51 Go to previous messageGo to next message
Dear Jason,
Thanks for the reply.I am not changing the style any where. the options i am setting i have given in previous mail. In that "OmegaConstants.PDF_EXT_STR" will replace "pdf" . If i give the above setting i am getting the problem in rendering the PDF pages (with multiple page). Some pages fonts size is becoming small.
If i remove the below lines i am getting the problem with more columns. The report is not fitting to that page so i couldn't able to see some columns.
please check this once .
Thanks & Regards,
Laxmipathi Raju.
Re: PDF rendering issue [message #626322 is a reply to message #560112] Wed, 22 September 2010 10:23 Go to previous messageGo to next message
What version of BIRT are you using?
BIRT 2.6 deprecated some of the options you are using. Here are the new ones:
* Properties to control how to output the content
* if the content exceeds the page-size.
* CLIP_CONTENT: clip the content
* FIT_TO_PAGE_SIZE: scale the content to fit into the page
* OUTPUT_TO_MULTIPLE_PAGES: divided the content into multiple pages
* ENLARGE_PAGE_SIZE: enlarge the page size to contain all the content.
public static final String PAGE_OVERFLOW = "pdfRenderOption.pageOverflow";
public static final int CLIP_CONTENT = 1;
public static final int FIT_TO_PAGE_SIZE = 2;
public static final int OUTPUT_TO_MULTIPLE_PAGES = 4;
public static final int ENLARGE_PAGE_SIZE = 8;
Jason
Re: PDF rendering issue [message #628175 is a reply to message #626322] Thu, 23 September 2010 05:57 Go to previous messageGo to next message
Dear jason,
Thanks again for reply and i am using BIRT 2.5 and can you give an example how to use the above values in my code.
Thanks & Regards,
Laxmipathi Raju
Re: PDF rendering issue [message #628692 is a reply to message #628175] Thu, 23 September 2010 13:04 Go to previous messageGo to next message
Use it like:
PDFRenderOption pdfOptions = new PDFRenderOption( options );
pdfOptions.setOption(IPDFRenderOption.PAGE_OVERFLOW,
IPDFRenderOption.FIT_TO_PAGE_SIZE);
Jason
On 9/23/2010 5:57 AM, laxmipathi raju wrote:
> Dear jason,
> Thanks & Regards,
> Laxmipathi Raju
Re: PDF rendering issue [message #641164 is a reply to message #560112] Wed, 24 November 2010 08:16 Go to previous messageGo to next message
Dear Jason,
We are facing an issue in PDF redering. If we have lengthy data say some 100 characters and there are no spaces in the data then while downloading the report in PDF formate we could not able to see full content. Can you please provide me how can we over come this issue.
Thanks & Regards,
Laxmipathi Raju
Re: PDF rendering issue [message #641219 is a reply to message #641164] Wed, 24 November 2010 10:05 Go to previous message
The only way I know to handle this is to use a javascript function on
the data item to insert new lines so the text wraps.
Take a look at this thread:
http://www.birt-exchange.org/org/forum/index.php/topic/13587 -not-able-to-wrap-dynamic-text-in-a-cell/
Jason
On 11/24/2010 8:16 AM, laxmipathi raju wrote:
> Dear Jason,
> Thanks & Regards,
> Laxmipathi Raju
Previous Topic:Y-axis format
Next Topic:Scripted Data Set Parameters dont work in Designer 2.6.1
Current Time: Thu Jul 24 23:34:41 EDT 2025
Powered by FUDForum. Page generated in 0.11516 seconds
