Home » Archived » M2M (model-to-model transformation) » [ATL] auto-completion
[ATL] auto-completion [message #556630] Thu, 02 September 2010 03:27 Go to next message
Hi all,
I wonder if auto-completion in ATL editor is working !!
Is there such a feature as same as what in java editor ?
If yes I wonder how can I enable it !!
Re: [ATL] auto-completion [message #556643 is a reply to message #556630] Thu, 02 September 2010 04:05 Go to previous messageGo to next message
When you create an ATL transformation using the wizard and if you indicate the meta-models, it will automatically initialize the transformation with the informations needed for the auto-completion.
That is :
-- @nsURI nameOfTheMetaModel=uri
before the ATL module declaration
Re: [ATL] auto-completion [message #556660 is a reply to message #556630] Thu, 02 September 2010 04:40 Go to previous messageGo to next message
Le 02/09/2010 09:27, ebtesam a écrit :
> Hi all,
You need to declare your metamodels at the beginning of the module file:
-- @path InMM=/org.eclipse.myproject/model/MyMM.ecore
-- @nsURI OutMM=http://org.eclipse.AnotherMM/1.0/toto
The first form is for metamodels in the workspace, second for registered
metamodels.
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: [ATL] auto-completion [message #557146 is a reply to message #556630] Sun, 05 September 2010 02:32 Go to previous messageGo to next message
THANKS for your answers
I did the same as what you suggested
I used the editor wizards and i declare it by hand
but still not working !!
-- @path A=/projectQ/SS.ecore
-- @path B=/projectQ/MM.ecore
module m;
create OUT : B from IN : A;
rule ABC{
from
s:A!NODE
to
mo: B!Model (
rate<- s. (here I don't know why i did not get autocompletion when i write dot . )
I have this issue in both eclipse 3.5 and 3.4
[Updated on: Sun, 05 September 2010 02:36] by Moderator
Re: [ATL] auto-completion [message #560134 is a reply to message #557146] Tue, 21 September 2010 06:00 Go to previous message
you can try to go to "preferences" and you will find a tab ATL->Editor->codeAssist and you will find a checkbox "enable auto activation".
perhaps it will work wit this
Cordialement
Mahmoud
Previous Topic:ATL - if then else
Next Topic:[ATL] Lazy rules and multiple instantiations
Current Time: Mon Jul 21 00:10:22 EDT 2025
Powered by FUDForum. Page generated in 0.48654 seconds
