Home » Archived » BIRT » Arrange Column data in a row(Arrange Column data in a row)
Arrange Column data in a row [message #559487] Thu, 16 September 2010 15:21 Go to next message
I am having some trouble with a BIRT report. I need the column data to be displayed in a row wise like below.Each row should contain only two elements as below.
What I have is this.
Code:
ID Code
A ABC
A DEF
B FGH
B GHI
Code:
ID Code
A ABC DEF
B FGH GHI
Please help me out.
Thanks.
Re: Arrange Column data in a row [message #559688 is a reply to message #559487] Fri, 17 September 2010 11:01 Go to previous message
You should be able to group on id and then add an aggregation element to
the group header that uses the concatenate function. Finally hide the
detail row. Attached is an example.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build &lt;2.5.2.v20100210-0630></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<script-data-source name="Data Source" id="7"/>
</data-sources>
<data-sets>
<script-data-set name="Data Set" id="8">
<list-property name="resultSetHints">
<structure>
<property name="position">0</property>
<property name="name">id</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">1</property>
<property name="name">code</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">id</property>
</structure>
<structure>
<property name="columnName">code</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
<property name="position">2</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<method name="open"><![CDATA[ii=0;]]></method>
<method name="fetch"><![CDATA[if( ii >= 4 ) return false;
if( ii == 0 ){
row["id"] = "A";
row["code"] = "ABC";
if( ii == 1 ){
row["id"] = "A";
row["code"] = "DEF";
if( ii ==2 ){
row["id"] = "B";
row["code"] = "FGH";
if( ii == 3 ){
row["id"] = "B";
row["code"] = "GHI";
ii++;
return true;]]></method>
</script-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<text id="34">
<property name="contentType">auto</property>
<text-property name="content"><![CDATA[Detail row is
hidden]]></text-property>
</text>
<table id="9">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property name="displayName">id</text-property>
<expression name="expression"
type="javascript">dataSetRow["id"]</expression>
</structure>
<structure>
<text-property name="displayName">code</text-property>
type="javascript">dataSetRow["code"]</expression>
</structure>
<structure>
<property name="name">Aggregation</property>
<simple-property-list name="aggregateOn">
<value>NewTableGroup1</value>
</simple-property-list>
<property
name="aggregateFunction">CONCATENATE</property>
<list-property name="arguments">
<structure>
<property name="name">Expression</property>
<expression name="value"
type="javascript">row["code"]</expression>
</structure>
<structure>
<property name="name">Separator</property>
type="javascript">", "</expression>
</structure>
<structure>
<property name="name">Max length</property>
</structure>
<structure>
<property name="name">Show all
values</property>
</structure>
</list-property>
</structure>
</list-property>
<column id="23"/>
<column id="24"/>
<header>
<row id="10">
<cell id="11">
<label id="12">
<text-property name="text">id</text-property>
</label>
</cell>
<cell id="13">
<label id="14">
<text-property name="text">code</text-property>
</label>
</cell>
</row>
</header>
<group id="25">
<property name="groupName">NewTableGroup1</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr"
type="javascript">row["id"]</expression>
<structure name="toc">
<expression name="expressionValue"
</structure>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property name="pageBreakAfter">auto</property>
<property name="pageBreakBefore">auto</property>
<property name="pageBreakInside">auto</property>
<header>
<row id="26">
<cell id="27">
<data id="32">
<property
name="resultSetColumn">id</property>
</data>
</cell>
<cell id="28">
<data id="33">
<property
name="resultSetColumn">Aggregation</property>
</data>
</cell>
</row>
</header>
<footer>
<row id="29">
<cell id="30"/>
<cell id="31"/>
</row>
</footer>
</group>
<detail>
<row id="15">
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr"
type="javascript">true</expression>
</structure>
</list-property>
<cell id="16">
<data id="17">
<property name="resultSetColumn">id</property>
</data>
</cell>
<cell id="18">
<data id="19">
<property
name="resultSetColumn">code</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="20">
<cell id="21"/>
<cell id="22"/>
</row>
</footer>
</table>
</body>
</report>
On 9/16/2010 3:21 PM, Veena wrote:
> elements as below.
> Code:
> ID Code
> A ABC
> A DEF
> B FGH
> B GHI
> Code:
> ID Code
> A ABC DEF
> B FGH GHI
> Please help me out.
> Thanks.
Previous Topic:Problem with Sorting table data
Next Topic:Bug in word exporter?
Current Time: Sat Jul 26 08:59:00 EDT 2025
Powered by FUDForum. Page generated in 0.05087 seconds
