Home » Archived » BIRT » Problem with Oracle sys_refcursor
Problem with Oracle sys_refcursor [message #559471] Thu, 16 September 2010 14:10 Go to next message
I'm using Birt report 2.6 and I have a problem with sys_refcursor in procedure when this procedure are include in packge.
First I had built a simple procedure for test
CREATE OR REPLACE Procedure PRC_TEST(refcur OUT sys_refcursor)
is
Begin
open refcur for
SELECT NOM , PRENOM FROM TEST_UTILISATEUR;
end PRC_TEST;
In my report
{call prc_test(?)}
This work fine !!!
Now I try to include my prc in a package
CREATE OR REPLACE PACKAGE "PKG_TEST" IS
Procedure PRC_TEST(refcur OUT sys_refcursor);
END PKG_TEST;
CREATE OR REPLACE PACKAGE BODY "PKG_TEST" IS
is
Begin
open refcur for
end PRC_TEST;
END PKG_TEST;
In my report
{call pkg_test.prc_test(?)}
This not work !!!
Give ORA-06550
PLS-00306 wrong number or types of arguments in call
Some one know why ?
Thanks for help.
[Updated on: Thu, 16 September 2010 14:23] by Moderator
Re: Problem with Oracle sys_refcursor [message #559690 is a reply to message #559471] Fri, 17 September 2010 11:02 Go to previous messageGo to next message
Can you post the log file?
Jason
> is
> Begin
> open refcur for
> SELECT NOM , PRENOM , unite_administrative FROM PIL_INFO_UTILISATEUR;
> end PRC_TEST;
> In my report {call prc_test(?)} This work fine !!!
> END PKG_TEST;
> is
> Begin
> open refcur for
> end PRC_TEST;
> END PKG_TEST;
> In my report {call pkg_test.prc_test(?)} This not work !!!
> Some one know why ?
> Thanks for help.
Re: Problem with Oracle sys_refcursor [message #636186 is a reply to message #559690] Fri, 29 October 2010 10:57 Go to previous messageGo to next message
I have no log file ... but I just want to know why when I use procedure my script work well and when I put the same procedure in package is not work.
Re: Problem with Oracle sys_refcursor [message #636213 is a reply to message #636186] Fri, 29 October 2010 12:06 Go to previous message
Can you log a bug for this?
Jason
> work.
Previous Topic:[Solved] fetch script and preview
Next Topic:Programmatic manipulation of report designs
Current Time: Fri Jul 25 21:38:56 EDT 2025
Powered by FUDForum. Page generated in 0.04913 seconds
