Home » Archived » AMP » BIRT Report Development
BIRT Report Development [message #542431] Thu, 24 June 2010 15:26 Go to next message
I have been asked to produce some BIRT reports to support the communication of results from some proof of concept modeling based on the ASPIN economic model, I note that you have a requirement for report development, has this been documented anywhere? or are there any ideas floating around that may make my efforts generally useful.
So far two mechanisms have been discussed internally: a simple reporting attachment to a function which creates a simple, maybe simplistic report of the given data set based on a collection of fixed templates to a specific media, PDF DITA Docbook etc. The second approach is two stage; first a collection of functions (snapshot filter etc.) is used to prepare the data for the report; this stage being performed by the MetaABM editor, on completion the BIRT template editor is invoked to design and edit the presentation of the data, the MetaABM editor providing the prepossessing of the data, the report template editor defining how the data will be shown, both contained in the AMP IDE producing a seamless application. The first concept as the advantage of simplicity and requires no knowledge of BIRT, the second released the full potential of the BIRT system and any future developments
Re: BIRT Report Development [message #542472 is a reply to message #542431] Thu, 24 June 2010 20:49 Go to previous messageGo to next message
Kennedy wrote on Thu, 24 June 2010 15:26
First I'm assuming you know about the export to adata feature? That's a gap in the documentation but it creates an ecore .adata file.
That second approach sounds really cool! The first one is one that I think I might try myself just because it does an endrun around BIRT complexity. After all, XPand templates are super efficient at processing data. You could even add some tools to the .adata editor to allow users to select say flattened selections of the data.
But the intermediate approach is what I've been working on mostly. I haven't had enough success at this approach to have a good enough practice to document! But the basic idea here is simply to use the data as is along with a DTP driver. The real problem with this approach is that believe it or not there really isn't a good driver for ecore models despite a couple of strong efforts.
I first tried just using the XML drivers using the adata XMI as the schema just to exercise the adata model. This worked but the metadata is only for generic adata models -- what you really want to be able to do is get the associated .metaabm data such as attribute labels, etc..
Then I tried the ecore drivers. The original Ecore driver worked well but the representation of the data was still pretty indirect -- you could get the info from the metaabm model but that required doing manual data-source mapping for each new model.
The newer driver was really nice, you actually had access to the entire ecore data model and that made it much easier to do ocl based queries. But there were significant technical issues that I couldn't get around. Part of the issue has to do with BIRT caching issues -- AFAICT it seems that a lot of the BIRT data integration stuff is designed with web style access envisioned and there are issues with dealing with EMF objects..see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=132958
In all of these the issue is to provide end-users / model explorers with easy to grok methods for creating reports. You and I can create them with the tools at hand but its a PITA and not something that you could expect a general user to figure out.
So my current thinking is that what would actually be really cool is to either create a custom adata data provider that could give users high level access to the metaabm meta-data or create templates that already had all of the data mappings. Probably the latter would be easiest but that would mean living with the issues above.
Or even simply create complete reports based on a cusotm interface. That's not as crazy s it sounds as the dimensions of data you'd want form an AMP model is not that extensive. I'd thought even of say taking something like the chart customizer and allowing people to get a data set form that.
Anyway, a lot of possibilities here. It would be really great to have more data handling capabilities available native from AMP! If you see any low-hanging fruit that it would be helpful to have to support an implementation for or if you want to get involved in AMP proper let me know.
cheers,
Miles
Re: BIRT Report Development [message #542499 is a reply to message #542472] Fri, 25 June 2010 02:15 Go to previous messageGo to next message
OK I will carry on with the second approach and leave you with the first and report back when progress is made or hanging fruit discovered
Re: BIRT Report Development [message #542737 is a reply to message #542499] Fri, 25 June 2010 14:29 Go to previous messageGo to next message
Kennedy wrote on Fri, 25 June 2010 02:15
Cool. And of course feel free to drop patches / feature requests into bugzilla. I didn't mean to imply btw that I'm actually planning to do anything on option 1 in the near term so that might be an avenue that you would still find useful to explore.
One other variation would be to do some kind of M2M thing from AMP -> BIRT. Unfortuntaly, BIRT is not an ecore model, its just XML schema...so you could either do a transform to XML for templates / reports, or transform to XML and then export from that -- MoDisco might provide some tools for that I'm not sure. But the BIRT *Chart* API is all EMF so that would be pretty straightforward. The nice thing about that is that you would get charts and so on that you could use in Dynamic sharting as well.
BTW< have a look at the IDataProvider in o.e.a.agf.chart -- its pretty simple right now, but my idea here is to provide a generic (not even AMF specific) API for dynamic data. Yet another possibility would be to provide some kind of interface to the output of such a provider. That would be cool because it could be very generic yet still provide labels for output columns.
Re: BIRT Report Development [message #542785 is a reply to message #542737] Fri, 25 June 2010 23:25 Go to previous messageGo to next message
I was joking, I'm sure you have more than enough to do dealing with Eclipse project management, and of course the function approach is the first step on the road to complete BIRT integration. Anyway thanks for the information; in the coming week I will forward my project plan for the reporting exercise and some tech info I will put that on the dev site
Re: BIRT Report Development [message #542789 is a reply to message #542431] Sat, 26 June 2010 00:16 Go to previous messageGo to next message
Right. Wink I've created a Wiki page to put this stuff:
http://wiki.eclipse.org/AMP/Reporting
Or set it up however you want. (Wiki is open to anyone with bugzilla access.) We can discuss development details on dev list if you'd like.
Re: BIRT Report Development [message #559151 is a reply to message #542789] Wed, 15 September 2010 15:08 Go to previous messageGo to next message
Hi Miles
Some Progress on the reporting front since my original thoughts a PoC has been produced and incorporated in various modelling projects; it would seem my original thoughts were woefully inadequate. We now have a three way / four way split in reporting:
The first an agent reporting function much as discussed in earlier posts
Second a progress error reporting function embedded in the experiment control function which in our case is based
mylin, more on this in another thread.
Third an enhanced reporting function based on the first but with text mining functionality.
Fourth a post simulation reporting facility which can cope with the large output volume of some of the longer simulations (TB simulation simplified is 200 days) and analyze and visualize the post-simulation output of multiple ABM's with an enhanced text mining functionality.
If you like I can start (or get some one to start using the wiki ) with some docs and examples as a straw-man to see if any further ideas spring up particularly in your GIS arena not yet covered by ourselves.
Re: BIRT Report Development [message #559443 is a reply to message #559151] Thu, 16 September 2010 11:45 Go to previous message
Hi Tony,
please see responses below..
Tony Kennedy wrote on Wed, 15 September 2010 15:08
Great, and Smile would be a most welcome contribution..
Mylyn integration.. that would be a truly important differentiator.
I'm interested to hear more about use cases for how the Text Mining functionality is used vs. configuring the output generated in the first place.
Yes, as with GIS I think that would be really helpful. One thing I'd really like to begin thinking about is a feature set for Indigo release train / 1.0.0 release. If we don't start thinking about this seriously now, the train will leave the station. So any requirements effort should definitely involve some kind of ranking and triage I'd think.
Also, I don't know if this goes without saying, but please do open bugzillas for these pieces of functionality. Its fine to do so for higer level / somewhat vague functionality as we can always fill that out with more specific bugs.
Please see https://bugs.eclipse.org/bugs/show_bug.cgi?id=318274 for a very relevant discussion on all of this.
Previous Topic:AMP is Unavailable
Next Topic:Model/Experiment Management For AMP
Current Time: Wed Jul 23 08:02:04 EDT 2025
Powered by FUDForum. Page generated in 0.09446 seconds
