Home » Modeling » M2T (model-to-text transformation) » [xpand] problem calling xpand from Java
[xpand] problem calling xpand from Java [message #559366] Thu, 16 September 2010 09:31 Go to next message
I keep getting the following exception when calling Xpand from a Java program:
Exception in thread "main" EvaluationException : No Definition templates::Template::main for idl::Interface could be found!
	Internal error : element was null
However I am sure I pass an object of type Interface to Xpand AND the template containing a definition
main FOR Interface is found by Xpand.
My code:
          ResourceSet resourceSet = new ResourceSetImpl();
            URI uri = URI.createFileURI(InputFileName);
            Resource resource = resourceSet.getResource(uri, true);
            Model model = (Model) resource.getContents().get(0);
            // XPand
            String outputFolder = "output";
            OutputImpl output = new OutputImpl();
            Outlet outlet = new Outlet(outputFolder);
            outlet.setOverwrite(true);
            output.addOutlet(outlet);
            EmfMetaModel metaModel = new EmfMetaModel(IdlPackage.eINSTANCE);
            XpandExecutionContextImpl executionContext = new XpandExecutionContextImpl(output, null);
            executionContext.registerMetaModel(metaModel);
            XpandFacade facade = XpandFacade.create(executionContext);
            facade.evaluate("templates::Template::main", model.getInterfaces().get(0));
My template file Template.xpt:
«IMPORT org::xtext::example::idl::idl»
«EXTENSION templates::Extensions»
«DEFINE main FOR Interface-»
«REM»  TODO only for non-local interfaces!!  «ENDREM»
«EXPAND header FOR this»
«EXPAND proxy  FOR this»
«EXPAND stub   FOR this»
«ENDDEFINE»
«DEFINE header FOR Interface»
«FILE this.name + "_PS.h"-»
«EXPAND Header::header FOR this-»
«ENDFILE»
«ENDDEFINE»
«DEFINE proxy FOR Interface»
«FILE this.name + "_Proxy.c"-»
«EXPAND Proxy::proxy FOR this-»
«ENDFILE»
«ENDDEFINE»
«DEFINE stub FOR Interface»
«FILE this.name + "_Stub.c"-»
«EXPAND Stub::stub FOR this-»
«ENDFILE»
«ENDDEFINE»
I did some debugging and I stepped into:
XpandFacade.evaluate
-> XpandFacade.evaluate2
---> XpandExecutionContextImpl.findDefinition (public)
-----> XpandExecutionContextImpl.findDefinition (private) :
 private XpandDefinition findDefinition(final XpandDefinition[] definitions, final String name, final Type target,
            Type[] paramTypes, final XpandExecutionContext ctx) {
        if (paramTypes == null) {
            paramTypes = new Type[0];
        final Set<Callable> features = new HashSet<Callable>();
        for (int i = 0; i < definitions.length; i++) {
            final XpandDefinition def = definitions[i];
            if (def.getParams().length == paramTypes.length) {
                final List<Type> defsParamTypes = new ArrayList<Type>();
                Type t = null;
                boolean complete = true;
                for (int j = 0; j < paramTypes.length && complete; j++) {
                    t = ctx.getTypeForName(def.getParams()[j].getType().getValue());
                    if (t == null) {
                        complete = false;
                    defsParamTypes.add(t);
                t = ctx.getTypeForName(def.getTargetType());
                if (t == null) {
                    complete = false;
                if (complete) {
                    features.add(new DefinitionOperationAdapter(def, def.getName(), t, defsParamTypes));
        final DefinitionOperationAdapter defAdapter = (DefinitionOperationAdapter) PolymorphicResolver.getOperation(
                features, XpandUtil.getLastSegment(name), target, Arrays.asList(paramTypes));
        if (defAdapter != null)
            return defAdapter.def;
        return null;
I notice the following:
- first loop is taken 4 times since 4 definitions were found in my template (which is ok) main, header, proxy and stub For Interface
- 2nd loop is always false, since paramTypes.length is 0 for all definitions
- ctx.getTypeForName returns false every time (for Interface). So "complete" is always false, and features.add is never called
- defAdapter is null, so finddefinition returns null always resulting in the exception
I don't know which of the observations above are expected or not, but I do know that findDefinition should not return null ......
Any idea what is going wrong here?
Re: [xpand] problem calling xpand from Java [message #559368 is a reply to message #559366] Thu, 16 September 2010 09:33 Go to previous messageGo to next message
you call the generator with EmfMetaModel but the template uses JavaBeansMetamodel. The error message should hint you to it Wink
~Christian
Re: [xpand] problem calling xpand from Java [message #559373 is a reply to message #559368] Thu, 16 September 2010 09:38 Go to previous messageGo to next message
Thanks for the quick response!
So the quickest solution is to register a JavaBeansMetamodel to my executionContext?
Is that possible? So far I only found examples using EmfMetaModel.
Re: [xpand] problem calling xpand from Java [message #559378 is a reply to message #559373] Thu, 16 September 2010 09:45 Go to previous messageGo to next message
yes or you change the import to «IMPORT idl»
~Christian
Re: [xpand] problem calling xpand from Java [message #559386 is a reply to message #559378] Thu, 16 September 2010 09:56 Go to previous message
I did register the JavaBeansMetaModel and it works perfectly now! Thanks! Smile
	        executionContext.registerMetaModel(new JavaBeansMetaModel());
Previous Topic:[Acceleo 3] Calling MTL queries from java code
Next Topic:[XPAND] Problems with getting started with defining extension
Current Time: Sat Jul 19 01:46:22 EDT 2025
Powered by FUDForum. Page generated in 0.04910 seconds
