Home » Eclipse Projects » Subversive » Team -> Apply patch after applying updates
Team -> Apply patch after applying updates [message #559204] Wed, 15 September 2010 20:14 Go to next message
Hi, I was using Subversive successfully with VisualSVN server until I did a "Check for updates..." in Eclipse and now all I see is Team->Apply patch. Another computer running XP using the same repository (with the same updates) still works fine.
Windows Vista
Eclipse 3.5.2
JNA library 3.2.3
Subcllipse 1.6.13
Subversion Client Adapter 1.6.12
SVNKit Library 1.3.3.6648
VisualSVN Server 1.5.3
Would appreciate any guidance! (I have tried uninstall/reinstall all components to no avail).
[Updated on: Wed, 15 September 2010 20:14] by Moderator
Re: Team -> Apply patch after applying updates [message #559274 is a reply to message #559204] Thu, 16 September 2010 04:55 Go to previous message
These lines:
Subcllipse 1.6.13
states that really you use not the Subversive plug-in, but Subclipse. So, it would be better if you ask Subclipse authors about the problem. Hope it will help you.
Previous Topic:WTH is the Subversive Plugin for Ganymede
Next Topic:Create branch from branch
Current Time: Fri Jul 25 10:27:14 EDT 2025
Powered by FUDForum. Page generated in 0.05156 seconds
