Home » Archived » BIRT » How do debug AssertionError cannot be cast to Exception?(How can I debug AssertionError cannot be cast to Exception comming when loading a report?)
How do debug AssertionError cannot be cast to Exception? [message #541802] Tue, 22 June 2010 10:56 Go to next message
Birt loads up find but when we try to load a report we get the following error. How can we go about figuring out what we made wrong? Googling for something like this is sadly not so easy and my attempts has not come up with anything.
org.apache.axis.AxisFault: ; nested exception is:
java.lang.ClassCastException: java.lang.AssertionError cannot be cast to java.lang.Exception
at org.apache.axis.AxisFault.makeFault(AxisFault.java:101) ~[axis.jar:na]
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:333) ~[axis.jar:na]
at org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32) ~[axis.jar:na]
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118) ~[axis.jar:na]
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83) ~[axis.jar:na]
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:454) ~[axis.jar:na]
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 ) ~[axis.jar:na]
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699) ~[axis.jar:na]
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(BirtSoapMessageDispatcherServlet.java:265) [viewservlets.jar:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727) [javax.servlet_2.5.0.v200806031605.jar:na]
at org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327) [axis.jar:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) [javax.servlet_2.5.0.v200806031605.jar:na]
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122) [viewservlets.jar:na]
at org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180) [org.eclipse.equinox.http.registry_1.0.200.v20090520-1800.ja r:na]
at org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90) [org.eclipse.equinox.http.servlet_1.0.200.v20090520-1800.jar :na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111) [org.eclipse.equinox.http.servlet_1.0.200.v20090520-1800.jar :na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59) [org.eclipse.equinox.http.servlet_1.0.200.v20090520-1800.jar :na]
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:318) [org.eclipse.equinox.http.jetty_2.0.0.v20090520-1800.jar:na]
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:502) [org.mortbay.jetty.server_6.1.15.v200905151201.jar:na]
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:380) [org.mortbay.jetty.server_6.1.15.v200905151201.jar:na]
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandl er.java:181) [org.mortbay.jetty.server_6.1.15.v200905151201.jar:na]
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandl er.java:765) [org.mortbay.jetty.server_6.1.15.v200905151201.jar:na]
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapp er.java:152) [org.mortbay.jetty.server_6.1.15.v200905151201.jar:na]
at org.mortbay.jetty.Server.handle(Server.java:324) [org.mortbay.jetty.server_6.1.15.v200905151201.jar:na]
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnectio n.java:535) [org.mortbay.jetty.server_6.1.15.v200905151201.jar:na]
at org.mortbay.jetty.HttpConnection$RequestHandler.content(Http Connection.java:880) [org.mortbay.jetty.server_6.1.15.v200905151201.jar:na]
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:748) [org.mortbay.jetty.server_6.1.15.v200905151201.jar:na]
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java: 219) [org.mortbay.jetty.server_6.1.15.v200905151201.jar:na]
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java: 404) [org.mortbay.jetty.server_6.1.15.v200905151201.jar:na]
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:409) [org.mortbay.jetty.server_6.1.15.v200905151201.jar:na]
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThr eadPool.java:520) [org.mortbay.jetty.util_6.1.15.v200905182336.jar:na]
Caused by: java.lang.ClassCastException: java.lang.AssertionError cannot be cast to java.lang.Exception
at org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(AbstractBaseComponentProcessor.java: 116) ~[viewservlets.jar:na]
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(BirtSoapBindingImpl.java:66) ~[viewservlets.jar:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.6.0_20]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39) ~[na:1.6.0_20]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25) ~[na:1.6.0_20]
at java.lang.reflect.Method.invoke(Method.java:597) ~[na:1.6.0_20]
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397) ~[axis.jar:na]
at org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186) ~[axis.jar:na]
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323) ~[axis.jar:na]
... 30 common frames omitted
Re: How do debug AssertionError cannot be cast to Exception? [message #541806 is a reply to message #541802] Tue, 22 June 2010 11:11 Go to previous messageGo to next message
Does this happen with all reports? How are you running them?
Jason
> with anything.
> java.lang.Exception
> ~[axis.jar:na]
> ~[axis.jar:na]
> ~[na:1.6.0_20]
Re: How do debug AssertionError cannot be cast to Exception? [message #545400 is a reply to message #541806] Wed, 07 July 2010 12:05 Go to previous messageGo to next message
Yes our project (Bioclipse) have at least two features with plugins that use Birt for generating reports and we get the same error message in both cases. As for the question of how they are run I guess the best I can do is point at this code which is one example of how one report is run:
< http://github.com/jonalv/bioclipse.brunn/blob/master/plugins /net.bioclipse.brunn.ui/src/net/bioclipse/brunn/ui/editors/m asterPlateEditor/MasterPlateReport.java#L224-234>
Sadly I did not write this code. It used to work earlier when we had Birt installed locally in Eclipse, now we have them in a separate target.platform and somewhere in this move this problem turned up. It's very difficult to know how to debug something like this though...
Do you have any suggestions?
Re: How do debug AssertionError cannot be cast to Exception? [message #545404 is a reply to message #545400] Wed, 07 July 2010 12:20 Go to previous messageGo to next message
Do you get the error on all reports? Have you tried using the sample db
as a test?
Jason
Re: How do debug AssertionError cannot be cast to Exception? [message #559197 is a reply to message #545404] Wed, 15 September 2010 18:30 Go to previous messageGo to next message
Jason,
I have just completed building the birt_web application from the 2.5.2 release source using the following directions. ( http://wiki.eclipse.org/BIRT/FAQ/Birt_Project#Q:_How_do_I_ex port_the_2.5_BIRT_web_viewer.3F)
When trying to run the included sample reports, test.rptdesign and test1.rptdesign, I too get the java.lang.ClassCastException: java.lang.AssertionError cannot be cast to java.lang.Exception error.
What is missing?
Re: How do debug AssertionError cannot be cast to Exception? [message #559453 is a reply to message #559197] Thu, 16 September 2010 12:57 Go to previous messageGo to next message
Don,
Can you post the complete stacktrace?
Jason
On 9/15/2010 6:30 PM, Don Bergstrom wrote:
> Jason,
> What is missing?
Re: How do debug AssertionError cannot be cast to Exception? [message #559498 is a reply to message #559197] Thu, 16 September 2010 16:44 Go to previous messageGo to next message
The error does not produce a stacktrace, or at least the one that is produced for my is is blank.
It appears that the 2.5.2 version of the web viewer does not run when the -enableassertations flag is set. Setting the -disableassertations flag seems to ensure that the reports run with out the class cast exception for the assertation error.
This is also reproducable using the WebViewerExample app in the birt-runtime-2-5-2.zip file.
[Updated on: Thu, 16 September 2010 16:50] by Moderator
Re: How do debug AssertionError cannot be cast to Exception? [message #559680 is a reply to message #559498] Fri, 17 September 2010 10:52 Go to previous messageGo to next message
Can you log a bug for this?
Jason
> flag ensures that the reports run with out the class cast exception for
Re: How do debug AssertionError cannot be cast to Exception? [message #559975 is a reply to message #559680] Mon, 20 September 2010 11:13 Go to previous message
Bug has been logged for this issue.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=325769
Previous Topic:Pagebreak if not enough space left
Next Topic:SQL error #1: Incorrect syntax near ','.
Current Time: Fri Jul 25 19:46:29 EDT 2025
Powered by FUDForum. Page generated in 0.04964 seconds
