Home » Archived » BIRT » Difference between sorting in BIRT 2.5 and 2.6 (Grouping and sorting in charts)
Difference between sorting in BIRT 2.5 and 2.6 (Grouping and sorting in charts) [message #558820] |
Tue, 14 September 2010 10:17  |
I'm using a chart with a DateTime X-Axis in a grouped table. In my
report template created with version 2.5 I got all values sorted by
date, now with 2.6, this doesn't work any more.
Opening the "Group and sorting" dialog, I'm not able to chose
"Ascending" or "Descending" (the combo isn't enabled). I can chose
Locale and Strength but I don't understand these new options (the help
isn't very helpful).
Can somebody explain the new sorting options and tell me how to achieve
the old behaviour?
Helmut
Re: Difference between sorting in BIRT 2.5 and 2.6 (Grouping and sorting in charts) [message #559015 is a reply to message #558878] |
Wed, 15 September 2010 06:34   |
Jason,
thanks for your answer. With BIRT 2.6 you introduced locale-sensitive
String sorting. Now I have some questions:
1. The dialog seems only to provide sorting of Strings (you always have
to choose a localization or AUTO and a sorting strength). I have other
data types like DateTimes. Does the sorting work with other data types?
Perhaps the dialogs should adapt to the datatype of the chosen column. I
assume I have to chose the sorting strengh IDENTICAL and it will work
with DateTime columns?
2. The Java Collator class only provides PRIMARY, SEDONCARY, TERTIARY
and IDENTICAL, so I want to know what ASCII and QUATERNARY means. I
assume ASCII is the normal String sorting independent of locale? What
means QUATERNARY?
3. Now I was able to solve my problem in my report template, but I have
some questions. I tried to reproduce the problem in a new example report
(created with BIRT 2.6) to explain them (my report template is very
large and needs special data). I have attached it to this report.
I'm using a table with two groups and a chart placed in the footer of
the inner group (have a look at my report).
The chart inherits data from the container. I used a DateTime X-Axis. In
BIRT 2.5 I was able to choose the sorting in the "Group and sorting"
dialog, now in BIRT 2.6 all widgets in the dialog are disabled.
So as workaround, I tried to use the Sorting tab in the Group Details
dialog of the inner group and added the sorting there (have a look). The
generated report doesn't show any sorted series in my chart.
Now I tried to add the sorting to the binding of the whole table (not in
my example report I attached) and now the sorting works. The second
possibility is to add the sorting to the query of the data set.
I'm not sure if I have done all correctly. Perhaps you can explain, why
the two first tries failed?
4. In my old BIRT 2.5 report template (using the 2.6 report designer),
I'm able to chose the sorting in the "Group and sorting" dialog of the
chart, but I'm not able to remove the sorting and the combo for
ascending and descending is disabled. I tried to remove the chart and
added it againg and now the widgets are disabled like in my attached
example report. Perhaps there is a compatibilty problem between 2.5 and 2.6?
5. The workarounds described in 3. work partially in my old BIRT 2.5
report template. Adding the sorting to the table binding works.
I'm using scripted CSV file data sets. Now my last question: Is it
possible to add a sorting to a scripted query like a SQL database query
(order by ...)? If yes, can you give me an example?
Helmut
Now the report:
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.6.0.v20100531 Build <2.6.0.v20100609-1613></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">120</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<list-property name="privateDriverProperties">
<ex-property>
<name>contentBidiFormatStr</name>
<value>ILYNN</value>
</ex-property>
<ex-property>
<name>metadataBidiFormatStr</name>
</ex-property>
</list-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="8">
<list-property name="computedColumns">
<structure>
<property name="name">Group</property>
<expression name="expression">if (row["AMOUNT"] >
10000)
1
else 2</expression>
<property name="dataType">integer</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">CHECKNUMBER</property>
<text-property
name="displayName">CHECKNUMBER</text-property>
<text-property
name="heading">CHECKNUMBER</text-property>
<property name="displayLength">50</property>
<property name="horizontalAlign">justify</property>
<property name="wordWrap">false</property>
</structure>
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property
name="displayName">CUSTOMERNUMBER</text-property>
<text-property
name="heading">CUSTOMERNUMBER</text-property>
<property name="displayLength">11</property>
</structure>
<structure>
<property name="columnName">PAYMENTDATE</property>
<text-property
name="displayName">PAYMENTDATE</text-property>
<text-property
name="heading">PAYMENTDATE</text-property>
<property name="displayLength">10</property>
</structure>
<structure>
<property name="columnName">AMOUNT</property>
<text-property name="displayName">AMOUNT</text-property>
<text-property name="heading">AMOUNT</text-property>
<property name="displayLength">22</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CHECKNUMBER</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNUMBER</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">PAYMENTDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">AMOUNT</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CHECKNUMBER</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
</structure>
<structure>
<property name="nativeName">PAYMENTDATE</property>
</structure>
<structure>
<property name="nativeName">AMOUNT</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select
CLASSICMODELS.PAYMENTS.CHECKNUMBER,
CLASSICMODELS.PAYMENTS.CUSTOMERNUMBER,
CLASSICMODELS.PAYMENTS.PAYMENTDATE, CLASSICMODELS.PAYMENTS.AMOUNT
from CLASSICMODELS.PAYMENTS]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>PAYMENTDATE</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>PAYMENTDATE</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>PAYMENTDATE</design:label>
<design:formattingHints>
<design:displaySize>10</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>AMOUNT</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>AMOUNT</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>AMOUNT</design:label>
<design:displaySize>22</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="9">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
type="javascript">dataSetRow["CUSTOMERNUMBER"]</expression >
</structure>
<structure>
type="javascript">dataSetRow["PAYMENTDATE"]</expression >
</structure>
<structure>
type="javascript">dataSetRow["AMOUNT"]</expression>
</structure>
<structure>
type="javascript">dataSetRow["CHECKNUMBER"]</expression >
</structure>
<structure>
type="javascript">dataSetRow["Group"]</expression>
</structure>
</list-property>
<column id="16"/>
<header>
<row id="10">
<cell id="11"/>
</row>
</header>
<group id="30">
<property name="groupName">NewTableGroup2</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr"
type="javascript">row["Group"]</expression>
<structure name="toc">
<expression name="expressionValue"
</structure>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property name="pageBreakAfter">auto</property>
<property name="pageBreakBefore">auto</property>
<property name="pageBreakInside">auto</property>
<header>
<row id="31">
<cell id="32">
<data id="35">
<property
name="resultSetColumn">Group</property>
</data>
</cell>
</row>
</header>
<footer>
<row id="33">
<cell id="34"/>
</row>
</footer>
</group>
<group id="17">
<property name="groupName">NewTableGroup1</property>
type="javascript">row["CUSTOMERNUMBER"]</expression>
</structure>
<list-property name="sort">
<structure>
<expression name="key"
type="javascript">row["PAYMENTDATE"]</expression>
<property name="direction">asc</property>
<property name="strength">15</property>
</structure>
</list-property>
<header>
<row id="18">
<cell id="19">
<data id="22">
<property
name="resultSetColumn">CUSTOMERNUMBER</property>
</data>
</cell>
</row>
</header>
<footer>
<row id="20">
<cell id="21">
<extended-item extensionName="Chart" id="23">
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Version>2.5.1</Version>
<Type>Scatter Chart</Type>
<SubType>Standard Scatter Chart</SubType>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value>Scatter Chart Title</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Series</ItemType>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>568.8000000000001</Width>
<Height>131.4</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<ExtendedProperties>
<Name>enable.area.alt</Name>
<Value>false</Value>
</ExtendedProperties>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>01/05/2000,02/01/2000,04/12/2000,03/12/2000,02/29/2000 </DataSetRepresentation>
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>6,4,12,8,10</DataSetRepresentation>
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
</SampleData>
<Interactivity/>
<EmptyMessage>
<Caption>
<Value>This chart contains no data.</Value>
<Font>
<Alignment>
</Alignment>
</Font>
</Caption>
<Transparency>64</Transparency>
<Red>127</Red>
<Green>127</Green>
<Blue>127</Blue>
</Background>
<Outline>
<Color>
<Transparency>128</Transparency>
<Red>127</Red>
<Green>127</Green>
<Blue>127</Blue>
</Color>
</Outline>
<Insets>
<Top>10.0</Top>
<Left>10.0</Left>
<Bottom>10.0</Bottom>
<Right>10.0</Right>
</Insets>
</EmptyMessage>
<Axes>
<Type>DateTime</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:ScatterSeries">
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["AMOUNT"]</Definition>
<Grouping>
<Enabled>false</Enabled>
<GroupType>Text</GroupType>
<AggregateExpression xsi:nil="true"/>
</Grouping>
</DataDefinition>
<SeriesIdentifier>Series 1</SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Above</LabelPosition>
<Stacked>false</Stacked>
<Markers>
<Type>Crosshair</Type>
<Size>4</Size>
<Outline>
</Outline>
</Markers>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
</Series>
<Grouping>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
</SeriesDefinitions>
<LineAttributes>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Min</Type>
<Value xsi:type="data:NumberDataElement">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>false</Percent>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
Re: Difference between sorting in BIRT 2.5 and 2.6 (Grouping and sorting in charts) [message #559163 is a reply to message #559015] |
Wed, 15 September 2010 15:42   |
Helmut
I believe the class used is
http://icu-project.org/apiref/icu4j/com/ibm/icu/text/Collato r.html
QUATERNARY is described there. For normal date sorts I do not think
anything is changed
On number 3 this is the proper approach:
4 - does sound like compat bug. Can you log this?
5 - We currently do not have an order by for csv, just the sorting on a
table when it is used.
Jason
On 9/15/2010 6:34 AM, Helmut Neubauer wrote:
> Jason,
> means QUATERNARY?
> Helmut
> Now the report:
> id="1">
> 2.6.0.v20100531 Build<2.6.0.v20100609-1613></property>
> <data-sources>
> <oda-data-source
> id="7">
> <ex-property>
> </ex-property>
> <ex-property>
> </ex-property>
> </list-property>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> <expression name="expression">if (row["AMOUNT"]>
> 10000)
> 1
> else 2</expression>
> </structure>
> </list-property>
> <structure>
> <text-property
> <text-property
> </structure>
> <structure>
> <text-property
> <text-property
> </structure>
> <structure>
> <text-property
> <text-property
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:criteria/>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="9">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <column id="16"/>
> <header>
> <row id="10">
> <cell id="11"/>
> </row>
> </header>
> <group id="30">
> </structure>
> <header>
> <row id="31">
> <cell id="32">
> <data id="35">
> <property
> </data>
> </cell>
> </row>
> </header>
> <footer>
> <row id="33">
> <cell id="34"/>
> </row>
> </footer>
> </group>
> <group id="17">
> </structure>
> <structure>
> </structure>
> </list-property>
> <header>
> <row id="18">
> <cell id="19">
> <data id="22">
> <property
> </data>
> </cell>
> </row>
> </header>
> <footer>
> <row id="20">
> <cell id="21">
> <xml-property
> <Block>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Label>
> <Caption>
> <Font>
> <Size>16.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>0.0</Left>
> <Right>0.0</Right>
> </Insets>
> </ClientArea>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>2.0</Top>
> <Left>2.0</Left>
> <Right>2.0</Right>
> </Insets>
> </ClientArea>
> <Text>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Text>
> <Separator>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Separator>
> <Title>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> </Block>
> <SampleData>
> <BaseSampleData>
> </BaseSampleData>
> </SampleData>
> <Interactivity/>
> <EmptyMessage>
> <Caption>
> <Font>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>127</Red>
> <Green>127</Green>
> <Blue>127</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>127</Red>
> <Green>127</Green>
> <Blue>127</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>10.0</Top>
> <Left>10.0</Left>
> <Right>10.0</Right>
> </Insets>
> </EmptyMessage>
> <Axes>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <AssociatedAxes>
> <Type>Linear</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <SeriesDefinitions>
> <Query>
> </Query>
> <SeriesPalette>
> <Red>80</Red>
> <Green>166</Green>
> <Blue>218</Blue>
> </Entries>
> <Red>242</Red>
> <Green>88</Green>
> <Blue>106</Blue>
> </Entries>
> <Red>232</Red>
> <Green>172</Green>
> <Blue>57</Blue>
> </Entries>
> <Red>128</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>64</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>170</Red>
> <Green>85</Green>
> <Blue>85</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>192</Red>
> <Green>192</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>192</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>7</Red>
> <Green>146</Green>
> <Blue>94</Blue>
> </Entries>
> <Red>0</Red>
> <Green>128</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>0</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>0</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>255</Red>
> <Green>0</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>128</Red>
> <Green>64</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>80</Red>
> <Green>240</Green>
> <Blue>120</Blue>
> </Entries>
> <Red>0</Red>
> <Green>64</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>0</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>255</Red>
> <Green>0</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>0</Red>
> <Green>64</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> </SeriesPalette>
> <Label>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <DataDefinition>
> <Grouping>
> </Grouping>
> </DataDefinition>
> <DataPoint>
> <Components>
> </Components>
> <Separator>,</Separator>
> </DataPoint>
> <Markers>
> <Size>4</Size>
> <Outline>
> </Outline>
> </Markers>
> <LineAttributes>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> <Visible>t
Re: Difference between sorting in BIRT 2.5 and 2.6 (Grouping and sorting in charts) [message #559613 is a reply to message #559163] |
Fri, 17 September 2010 07:24   |
Jason,
I'm not sure why there is the possibility to change the sorting on
grouping level (it doesn't work in my example). I have to do it on table
level. Can you explain me?
Helmut
Am 15.09.2010 21:42, schrieb Jason Weathersby:
> Helmut
> anything is changed
> Jason
>> Jason,
>> means QUATERNARY?
>> and 2.6?
>> Thanks,
>> Helmut
>> Now the report:
>> <?xml version="1.0" encoding="UTF-8"?>
>> id="1">
>> <data-sources>
>> <oda-data-source
>> id="7">
>> <ex-property>
>> </ex-property>
>> <ex-property>
>> </ex-property>
>> </list-property>
>> <property
>> <property
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <oda-data-set
>> <structure>
>> 10000)
>> 1
>> else 2</expression>
>> </structure>
>> </list-property>
>> <structure>
>> <text-property
>> <text-property
>> </structure>
>> <structure>
>> <property
>> <text-property
>> <text-property
>> </structure>
>> <structure>
>> <text-property
>> <text-property
>> </structure>
>> <structure>
>> <text-property
>> </structure>
>> </list-property>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> <property
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> <model:DesignValues
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> <design:criteria/>
>> </oda-data-set>
>> </data-sets>
>> <styles>
>> </style>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <table id="9">
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> <column id="16"/>
>> <header>
>> <row id="10">
>> <cell id="11"/>
>> </row>
>> </header>
>> <group id="30">
>> </structure>
>> <header>
>> <row id="31">
>> <cell id="32">
>> <data id="35">
>> <property
>> </data>
>> </cell>
>> </row>
>> </header>
>> <footer>
>> <row id="33">
>> <cell id="34"/>
>> </row>
>> </footer>
>> </group>
>> <group id="17">
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> <header>
>> <row id="18">
>> <cell id="19">
>> <data id="22">
>> <property
>> </data>
>> </cell>
>> </row>
>> </header>
>> <footer>
>> <row id="20">
>> <cell id="21">
>> id="23">
>> <xml-property
>> <Block>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> <Width>0.0</Width>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Label>
>> <Caption>
>> <Font>
>> <Size>16.0</Size>
>> <Bold>true</Bold>
>> <Alignment>
>> </Alignment>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Label>
>> </Children>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> <Width>0.0</Width>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <ClientArea>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>0.0</Left>
>> <Right>0.0</Right>
>> </Insets>
>> </ClientArea>
>> </Children>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> <Width>0.0</Width>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <ClientArea>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>2.0</Top>
>> <Left>2.0</Left>
>> <Right>2.0</Right>
>> </Insets>
>> </ClientArea>
>> <Text>
>> <Value></Value>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Text>
>> <Separator>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Separator>
>> <Title>
>> <Caption>
>> <Value></Value>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Title>
>> </Children>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> </Block>
>> <SampleData>
>> <BaseSampleData>
>> </BaseSampleData>
>> </SampleData>
>> <Interactivity/>
>> <EmptyMessage>
>> <Caption>
>> <Font>
>> <Alignment>
>> </Alignment>
>> </Font>
>> </Caption>
>> <Red>127</Red>
>> <Green>127</Green>
>> <Blue>127</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>127</Red>
>> <Green>127</Green>
>> <Blue>127</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>10.0</Top>
>> <Left>10.0</Left>
>> <Right>10.0</Right>
>> </Insets>
>> </EmptyMessage>
>> <Axes>
>> <Title>
>> <Caption>
>> <Font>
>> <Size>14.0</Size>
>> <Bold>true</Bold>
>> <Alignment>
>> </Alignment>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Title>
>> <AssociatedAxes>
>> <Type>Linear</Type>
>> <Title>
>> <Caption>
>> <Font>
>> <Size>14.0</Size>
>> <Bold>true</Bold>
>> <Alignment>
>> </Alignment>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Title>
>> <SeriesDefinitions>
>> <Query>
>> </Query>
>> <SeriesPalette>
>> <Red>80</Red>
>> <Green>166</Green>
>> <Blue>218</Blue>
>> </Entries>
>> <Red>242</Red>
>> <Green>88</Green>
>> <Blue>106</Blue>
>> </Entries>
>> <Red>232</Red>
>> <Green>172</Green>
>> <Blue>57</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>255</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>64</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>170</Red>
>> <Green>85</Green>
>> <Blue>85</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>0</Blue>
>> </Entries>
>> <Red>192</Red>
>> <Green>192</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>192</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>7</Red>
>> <Green>146</Green>
>> <Blue>94</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>128</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>0</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>64</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>80</Red>
>> <Green>240</Green>
>> <Blue>120</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>64</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>0</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>0</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>64</Green>
>> <Blue>0</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
Re: Difference between sorting in BIRT 2.5 and 2.6 (Grouping and sorting in charts) [message #559678 is a reply to message #559613] |
Fri, 17 September 2010 10:49  |
If the sort is on the group the sort happens after the group and if its
on the table it happens before the group. Look at the attached example
that shows the difference.
Jason
id="1">
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source
id="7">
<text-property name="displayName"></text-property>
<property
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<structure>
<property name="name">ORDERNUMBER</property>
</structure>
<structure>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="name">PRICEEACH</property>
</structure>
<structure>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails
where ordernumber < 10104]]></xml-property>
<model:DesignValues
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:displaySize>11</design:displaySize>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
<design:criteria/>
]]></xml-property>
</oda-data-set>
<oda-data-set
name="Data Set1" id="9">
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from orderdetails
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:criteria/>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
<style name="table-header" id="106">
<property name="backgroundColor">#6078BF</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="table-footer" id="107">
</style>
<style name="table-detail" id="108">
<property name="backgroundColor">#E6ECFF</property>
<property name="fontSize">x-small</property>
<property name="color">#000080</property>
</style>
<style name="table-group-header-1" id="109">
<property name="backgroundColor">#809FFF</property>
</style>
<style name="table-group-footer-1" id="110">
<property name="backgroundColor">#C0C0C0</property>
</style>
<style name="special-header" id="111">
<property name="fontSize">medium</property>
</style>
<style name="crosstab-detail" id="112">
</style>
<style name="crosstab-header" id="113">
</style>
<style name="mydata" id="114">
<property name="color">orange</property>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</page-setup>
<body>
<text id="115">
<property name="contentType">auto</property>
<text-property name="content"><![CDATA[Sorting on group.
Sort happens after group. First table product code is sorted after data
is grouped. Second table the sort is on the table so it sorts then
groups.]]></text-property>
</text>
<table id="10">
<structure>
<text-property
type="javascript">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<column id="43"/>
<header>
<row id="116">
<cell id="117">
<property name="colSpan">5</property>
<property name="rowSpan">1</property>
<label id="122">
<text-property
name="text">Table1</text-property>
</label>
</cell>
</row>
<row id="11">
<cell id="12">
<label id="13">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="18">
<label id="19">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="20">
<label id="21">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<group id="44">
type="javascript">row["ORDERNUMBER"]</expression>
</structure>
<structure>
type="javascript">row["PRODUCTCODE"]</expression>
<property name="strength">-1</property>
</structure>
</list-property>
<header>
<row id="45">
<cell id="46">
<data id="57">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="47"/>
<cell id="48"/>
<cell id="49"/>
<cell id="50"/>
</row>
</header>
<footer>
<row id="51">
<cell id="52"/>
<cell id="53"/>
<cell id="54"/>
<cell id="55"/>
<cell id="56"/>
</row>
</footer>
</group>
<detail>
<row id="22">
<cell id="23">
<data id="24">
<property
</data>
</cell>
<cell id="25">
<data id="26">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="27">
<data id="28">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="29">
<data id="30">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="31">
<data id="32">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="33">
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
<cell id="38"/>
</row>
</footer>
</table>
<table id="58">
<property name="dataSet">Data Set1</property>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
</list-property>
<column id="87"/>
<column id="88"/>
<column id="89"/>
<column id="90"/>
<column id="91"/>
<header>
<row id="123">
<cell id="124">
<label id="129">
<text-property
name="text">Table2</text-property>
</label>
</cell>
</row>
<row id="59">
<cell id="60">
<label id="61">
<text-property
</label>
</cell>
<cell id="62">
<label id="63">
<text-property
</label>
</cell>
<cell id="64">
<label id="65">
<text-property
</label>
</cell>
<cell id="66">
<label id="67">
<text-property
</label>
</cell>
<cell id="68">
<label id="69">
<text-property
</label>
</cell>
</row>
</header>
<group id="92">
</structure>
<header>
<row id="93">
<cell id="94">
<data id="105">
<property
</data>
</cell>
<cell id="95"/>
<cell id="96"/>
<cell id="97"/>
<cell id="98"/>
</row>
</header>
<footer>
<row id="99">
<cell id="100"/>
<cell id="101"/>
<cell id="102"/>
<cell id="103"/>
<cell id="104"/>
</row>
</footer>
</group>
<detail>
<row id="70">
<cell id="71">
<data id="72">
<property
</data>
</cell>
<cell id="73">
<data id="74">
<property
</data>
</cell>
<cell id="75">
<data id="76">
<property
</data>
</cell>
<cell id="77">
<data id="78">
<property
</data>
</cell>
<cell id="79">
<data id="80">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="81">
<cell id="82"/>
<cell id="83"/>
<cell id="84"/>
<cell id="85"/>
<cell id="86"/>
</row>
</footer>
</table>
</body>
</report>
On 9/17/2010 7:24 AM, Helmut Neubauer wrote:
> Jason,
> Helmut
>> Helmut
>> anything is changed
>> Jason
>>> Jason,
Current Time: Thu Jul 24 22:10:24 EDT 2025
Powered by FUDForum. Page generated in 0.03803 seconds
