Home » Archived » BIRT » Where can i find the Birt 2.5.2 report engine api documentation?(Birt 2.5.2 report engine api documentation.)
Where can i find the Birt 2.5.2 report engine api documentation? [message #558582] Mon, 13 September 2010 11:16 Go to next message
The integration tutorial offers code snippets on how to accomplish certain tasks in report engine, but I haven't be able to find a complete api doc for release 2.5.2. There is a link points to a wiki page that shows bits and pieces of some sample code for 2.2 release...
Is there a 2.5 api documentation somewhere for the report engine? If not, what will my best option?
thanks,
kenny
Re: Where can i find the Birt 2.5.2 report engine api documentation? [message #558621 is a reply to message #558582] Mon, 13 September 2010 13:32 Go to previous messageGo to next message
Kenny,
We have them online at
http://www.birt-exchange.com/be/downloads/documentation/#cur rentdocs
but they need to be updated. If you download sdk
here:
http://download.eclipse.org/birt/downloads/build.php?build=R -R1-2_5_2-201002221500
You will find three doc plugins and 3 doc features that you can add to
your eclipse install and they will show up in your help.
They are named (plugins and features)
org.eclipse.birt.chart.doc.isv
org.eclipse.birt.doc.isv
Jason
On 9/13/2010 11:16 AM, dash wrote:
> thanks,
> kenny
Re: Where can i find the Birt 2.5.2 report engine api documentation? [message #558665 is a reply to message #558621] Mon, 13 September 2010 16:24 Go to previous messageGo to next message
Jason,
Good to hear from you! After digging thru the docs a bit, I can't find what I'm looking for. I would like to hear your advice on what I would like to implement.
Instead of writing the report to the disk, I would like to get
the report binary and store it into a byte array in the RunReportResponse object, that needs to be populated with other data before sending it back to the client.
I've only found an api that does
options.setOutputStream(response); where response is an HttpServletResponse object.
I don't want to stream the report back to the client right away.
I could do the dumb way by writing the report out to a file and reading it back to the byte array, but it's an unnecessary IO that hammers the performance.
Any suggestion or workaround?
kenny
// code snippets
public class RunReportResponse extends ReportResponse
private byte[] reportData;
publi
Re: Where can i find the Birt 2.5.2 report engine api documentation? [message #558667 is a reply to message #558621] Mon, 13 September 2010 16:34 Go to previous messageGo to next message
Jason,
the report binary and store it into a byte array in an RunReportResponse object, our custom response object, that needs to be populated with other data before sending it back to the client.
options.setOutputStream(response); where response is an HttpServletResponse object. I don't want to stream the report back to the client right away.
I could do the dumb way by writing the report out to a file and reading it back to a byte array in the RunReportResponse, but it's an unnecessary IO that hammers the performance.
kenny
// code snippets
public void setReportData(byte[] reportData)
this.reportData = reportData;
public byte[] getReportData()
return reportData;
@WebMethod
public RunReportResponse runReport(RunReportRequest request) {
String reportName = request.getName();
if (reportFormat.equalsIgnoreCase(PDF_FORMAT)) {
PDFRenderOption options = new PDFRenderOption();
options.setOutputFileName(REPORTS_PATH + "/" + reportName + "." + PDF_FORMAT);
options.setOutputFormat(PDF_FORMAT);
task.setRenderOption(options);
Re: Where can i find the Birt 2.5.2 report engine api documentation? [message #558864 is a reply to message #558667] Tue, 14 September 2010 11:50 Go to previous message
Kenny,
The setOutputStream method can use any OutputStream. If you just want
the bytes, create a new ByteArrayOutputStream and use it.
ByteArrayOutputStream baos= new ByteArrayOutputStream();
options.setOutputStream(baos);
mybytearray = baos.getBytes();
Jason
On 9/13/2010 4:34 PM, dash wrote:
> Jason,
> like to implement.
> Instead of writing the report to the disk, I would like to get the
> I've only found an api that does options.setOutputStream(response);
> kenny
> // code snippets
> return reportData;
> @WebMethod
> PDF_FORMAT);
Previous Topic:Modify the "Business Intelligence and Reporting Tools -> New Report" wizard?
Next Topic:BIRT and iText (or other GPL libraries)
Current Time: Wed Jul 23 04:03:57 EDT 2025
Powered by FUDForum. Page generated in 0.32600 seconds
