Home » Archived » DSDP - Real-Time Software Components (RTSC) » Bug in xdc_runtime_Registry_addModule function ?(Bug ?)
Bug in xdc_runtime_Registry_addModule function ? [message #557809] Thu, 09 September 2010 00:39 Go to next message
Champs I am using xdc 3.20.01.51 and my application crashes on invoking Registry_addModule function. My application is built for
GCArmv5T target.I suspect this crash to be due to the following piece of code in function Registry_addModule:
desc->mask = *Module__DGSMASK;
Module__DGSMASK is defined as below in
#undef Module__DGSMASK
#define Module__DGSMASK &xdc_runtime_Registry_CURDESC.mask
in Registry__epilogue.h followed by
#define Module__DGSMASK xdc_runtime_Registry_Module__diagsMask__C
in "package\internal\Registry.xdc.h"
This effectively makes
In my app xdc_runtime_Registry_Module__diagsMask__C is set to zero so the code
would result in dereferencing NULL pointer.
Can you please review the function Registry_addModule() and either confirm that this is the reason for the crash or let me know what else could cause crash in this function.FYI I am passing a valid values for
Registry_Desc *desc & String modName which are the function arguments.
Badri
Re: Bug in xdc_runtime_Registry_addModule function ? [message #558660 is a reply to message #557809] Mon, 13 September 2010 16:14 Go to previous messageGo to next message
This is definitely a bug. The line in question should be:
desc->mask = Registry_getMask();
However, simply fixing this line may not fix your problem (I think). If
the pointer is NULL, then you have a configuration which disables
Registry diagnostics which, in turn, is responsible for handling all Log
calls from modules added via Registry_addModule().
To ensure Registry Logging is enabled make sure your configuration
script has something like the following:
var Registry = xdc.useModule("xdc.runtime.Registry");
Registry.common$.logger = Logger.create();
where Logger is the logger of your choice (e.g., xdc.runtime.LoggerBuf).
> Registry_addModule function. My application is built for GCArmv5T
> Module__DGSMASK is defined as below in #undef Module__DGSMASK
> This effectively makes #define Module__DGSMASK
> the code
> Regards
> Badri
Re: Bug in xdc_runtime_Registry_addModule function ? [message #558821 is a reply to message #558660] Tue, 14 September 2010 10:26 Go to previous message
Actually it should be:
desc->mask = Registry_Module_getMask();
Anyway, it's been fixed and will be in the 3.20.004 release coming up in
about a week (in time for the CCS5 release at the end of the month).
Previous Topic:accessing runSegment/loadSegment addresses in an assembly file
Next Topic:issue with packages having name linux
Current Time: Sat Jul 19 23:20:42 EDT 2025
Powered by FUDForum. Page generated in 0.03805 seconds
