Home » Archived » BIRT » Birt + Excel
Birt + Excel [message #557689] Wed, 08 September 2010 10:16 Go to next message
I'm new to birt. I have to make dynamic reports using Birt. My reports must be in XLS.
I worh with an Eclipse Birt distribution.
I tried some tutorials etc. and I had a problem with to general reports with, images, charts, several sheets.
It seems I need a more powerfull emiter than the one I have with my distribution.
The Tribix emiter is not considered for now
So I am here for that I would like to use the Actuate solution in trial in order to validate if it feets my needing.
I would like your suggestions on that.
Anthony
Re: Birt + Excel [message #557766 is a reply to message #557689] Wed, 08 September 2010 15:02 Go to previous messageGo to next message
Anthony,
Have you seen this post?
http://birtworld.blogspot.com/2010/06/birt-excel-output.html
Jason
On 9/8/2010 10:16 AM, Anthony S wrote:
> Hi
> must be in XLS.
> distribution.
> Anthony
Re: Birt + Excel [message #557786 is a reply to message #557766] Wed, 08 September 2010 18:34 Go to previous messageGo to next message
Yes I saw this post and reoriented my work on Actuate. It's the purpose
of my question. I didn't find an Actuate Eclipse distribution that allow
me to put images, charts etc. in an XLS report file whereas it would be.
My computer at work do not allow me (no admin rights) to install
actuate executable programs. I will try with my own computer but I am
looking for a plugin, or an eclipse, that could reach my needs even if a
payable license is necessary.
[Updated on: Wed, 08 September 2010 18:34] by Moderator
Re: Birt + Excel [message #558092 is a reply to message #557689] Fri, 10 September 2010 03:48 Go to previous messageGo to next message
I managed to generate images&charts in XLS with Birt-Actuate designer V11 (trial version, testing before buying) but not with the V10.
I tought the Birt-Acutate report designer 10 was able to to generate images, charts etc. in XLS ? Someone has already tried ?
Re: Birt + Excel [message #558234 is a reply to message #558092] Fri, 10 September 2010 11:28 Go to previous messageGo to next message
The A11 version has the improved xls emitter. A10 does not.
Jason
Re: Birt + Excel [message #558282 is a reply to message #558234] Fri, 10 September 2010 15:20 Go to previous messageGo to next message
Thank you. Now I understand better. I think i am in the good direction with Actuate 11.
Is there tutorials on Actuate somewhere ?
Re: Birt + Excel [message #558639 is a reply to message #558282] Mon, 13 September 2010 14:26 Go to previous messageGo to next message
We should have some video recording demos up this week.
Jason
> with Actuate 11.
Re: Birt + Excel [message #558738 is a reply to message #558639] Tue, 14 September 2010 05:13 Go to previous message
I am interested in, when you have links.
Previous Topic:BIRT vs. Pentaho
Next Topic:Modify the "Business Intelligence and Reporting Tools -> New Report" wizard?
Current Time: Sat Jul 26 10:08:51 EDT 2025
Powered by FUDForum. Page generated in 0.06956 seconds
